| DIY Subwoofers Finshing Sub BoxDiscuss Finshing Sub Box in the DIY Speakers and Subwoofers forum; Finshing Sub Box Hi guys
Currently have someone making up my sub enclosure from 18mm MDF. My new problem is trying to get ... |
Views: 444 - Replies: 4
| Finshing Sub Box Hi guys Currently have someone making up my sub enclosure from 18mm MDF. My new problem is trying to get a nice finish. I dont want carpet but i was thinking can i get a finish like this (Attched Supernova pic) with MDF or am i totally dreaming. If possible can someone explain how. Im assuming the box needs to be preped then coasted in some form of clear then paint. I dunno Also if anyone has any other CHEAP alternatives that would be great Cheers ken | ||||
| | #2 | ||||
| Re: Finshing Sub Box Yes it's possible to get a rich gloss black/piano black on MDF but it takes A LOT of hardwork and time to get it right. There's a couple "guides" to it, either on here or on the AVS DIY section. I'd do a search. I'd provide links but have to go eat. =O Just know what your getting into before you really start to want it otherwise you'll be disappointed and have to settle with something lesser. Trust me. *shrugs* | ||||
| | #3 | ||||
| Re: Finshing Sub Box Here are a few links that might help: http://www.avsforum.com/avs-vb/showthread.php?t=1019557 http://www.diyaudio.com/forums/showt...141&highlight= http://www.woodweb.com/knowledge_bas...sh_on_MDF.html http://www.diynot.com/forums/viewtopic.php?t=79568 The first two I think are the best tutorials. | ||||
| | #4 | ||||
| Re: Finshing Sub Box Thanks Canadian Dude, those first two were the ones I was thinking of. I hadn't seen the other though - maybe they have a short cut I haven't seen. =O One can only wish for an easy way out. | ||||
