DIY Subwoofers
Tang Band W69-1042M project
Discuss Tang Band W69-1042M project in the DIY Speakers and Subwoofers forum; Tang Band W69-1042M project Hi Mike, I as well am in the process of making a subwoofer, with the tang band woofers I have ...
Views: 2157 - Replies: 57
Old 08-18-09, 04:57 AM   #26
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Re: Tang Band W69-1042M project
Hi Mike, I as well am in the process of making a subwoofer, with the tang band woofers I have ordered, however, I am not a professional like you guys, I did a search on google..and found out that you are one of the best guys to help..could you please let me know what dimensions of the box I should use, does this have to be rectangular or square, Can I make it oval or round..what do you think.
Old 08-18-09, 06:49 AM   #27
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Are you using the same Tang Band driver?
We're all in this together!
Members DIY Subwoofer Database
Old 08-19-09, 07:39 AM   #28
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Yes Mike, It is the same one, Actually I have picked up 5 of them..plan to make a few for me, and the rest for a friend..can you tell me what is the best way I can get this fixed. Could you tell me what dimension I should have the box in and where exactly I can get the port fixed etc..As I said, i dont know much of this stuff, just trying something out, i am sure with your help should be able to...Thanks.
Old 08-19-09, 08:17 AM   #29
Alias: Mike
User: #8033
Since: Apr 2007
Do you want each driver in it's own box?
Old 08-19-09, 08:26 AM   #30
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Yes. Please , maybe I could have 2 woofers in 1 box and the remaining 3 in seperate boxes..Thanks.
Old 08-19-09, 08:38 AM   #31
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
I am using a Crown XLS 602D amplifier, which is 380 W RMS per channel stereo. Thanks,
Old 08-19-09, 12:48 PM   #32
Alias: Mike
User: #8033
Since: Apr 2007
There appears to be different specs listed for the the same driver from different websites. Do you have a link to where you got these drivers from?
Old 08-20-09, 12:28 AM   #33
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120460281951#ht_1590wt_864
Old 08-20-09, 12:31 AM   #34
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
All 5 drivers have the same specs, as in the attached link sent above..hope this helps.
Old 08-20-09, 08:33 AM   #35
Alias: Mike
User: #8033
Since: Apr 2007
Thanks for info. What are your plans for this driver, are you wanting to get the most bass possible from it?
Old 08-20-09, 02:46 PM   #36
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Yes, I would love to get the best bass from it..I was thinking of making them into just sub woofers, or maybe a pair in a tower, what do you think..with a mid and a tweeter,, so probably 2 subs and 2 towers...what do u suggest..Basically I have a lot of woofers, and tweeters and would love to make the best of it..thanks.
Old 08-20-09, 03:26 PM   #37
Alias: Mike
User: #8033
Since: Apr 2007
As for adding mids and tweeters you'll have to ask in the DIY Speakers forum as I'm not the one for that. I do know that depending on what mid and tweeter you use you'll need the proper crossover.
The sub models to 40 liters tuned to 38 hz for a single sub and 80 liters tuned to 38 hz for 2 subs in one cabinet. For the single you'll need a port 3" diameter and 7" long. For the dual subs you'll need two 3" diameter and 7" long or a port 4" diameter and 5.25" long.
Power handling would be 75 watts 4 ohms for the single and 300 watts for the dual if they're wired in series for an 8 ohm load. They both need a Hi-Pass filter at 30 hz to prevent them from bottoming out at the lower frequencies.
Old 08-21-09, 06:37 AM   #38
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Wow Cool...Would you happen to have some preferred dimensions for the box, I shall try out the double woofer sub..what do you think. How Can I obtain a high pass filter for this..can u help. Thanks.
Old 08-21-09, 08:40 AM   #39
Alias: Mike
User: #8033
Since: Apr 2007
Using 3/4" building material it would be about a 18.5" cube. You can figure out the box volume and dimensions here:
http://www.hometheatershack.com/foru...me-calculator/
Some pro amps have a HPF at 30 hz, check the manual on the Crown XLS 602D, it may have one.
Old 09-12-09, 06:15 AM   #40
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Hi mike, I have just received the ports from PE, and they are 3.75 inches X 7.65 inches. I dont know how I miss-calculated this, can I do anything with them, as I would want to use them in a single woofer cabinet, and what are my options with a double woofer cabinet using these ports..Thanks.
Old 09-12-09, 07:15 AM   #41
Alias: Mike
User: #8033
Since: Apr 2007
A 3.75" diameter port would need to be 11.75" long for a single cabinet, and would require 2 ports for a double cabinet. Using the ports as they are would raise the tuning to 45 hz with less low end output as shown in the graph below.
Old 09-13-09, 02:36 AM   #42
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
So, I can use these ports, I just gotta put some extension to the rear end of the port, and it should get me a good bass response..The dimensions I am thinking of are 12(d)X12(W)X36(h), Is there any position that I need to maintain for the woofer and the port..as you can see I am a beginner at this, would appreciate all the minute details as possible..Thanks a lot and sorry for all the trouble.
Old 09-13-09, 06:54 AM   #43
Alias: Mike
User: #8033
Since: Apr 2007
Yes. just extend the port 4" and you'll maintain the 38 hz tuning. The ports should be one diameter (3.75") away from any wall of the sub. Mount the subs anyway you want, if down firing the legs should be 4" long.
There is no trouble, you're here to learn and I'm here to help.
Old 09-13-09, 07:18 AM   #44
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Great..thanks once again. Truly appreciate the help. What do you think of the measurements I gave you, the same applied on a 3/4 inch of MDF. Is it ok, for the driver, as I already have these boxes,and was planning to use the same, insted of making new ones.
Old 09-13-09, 07:56 AM   #45
Alias: Mike
User: #8033
Since: Apr 2007
The box can work. Green is with 2 drivers tuned to 40 hz. A single 3.75" port would need to be 5.75" long. Orange is with 1 driver in the box tuned to 34 hz. A single 3.75" port would need to be 9" long. The same power input and Hi-Pass filter applies as above.
Old 09-13-09, 08:03 AM   #46
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
I have broght some crossover, please have a look at them below..will this help or should I use them elsewhere, as I have nothing mentioned on my Crown Amp..just a subsonic filter on my Yamaha EQ.
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Old 09-13-09, 10:56 AM   #47
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Hi Mike, Attaching here are other crossovers that I have as well...please check and let me know what is the best option.
http://cgi.ebay.com/Cerwin-Vega-300-...ht_3794wt_1165
http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_500wt_1182
Old 09-13-09, 08:17 PM   #48
Alias: Mike
User: #8033
Since: Apr 2007
What is your source, a receiver? If so what make and model?
You need a subsonic filter at 30hz, can the Yamaha provide that?
Old 09-14-09, 03:17 AM   #49
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
SWITCHABLE SUBSONIC FILTER
This filter allows you to roll-off content below 15Hz, eliminating potentially harmful turntable rumble during phono play.
The above is what's mentioned on the manual.
Old 09-14-09, 08:42 AM   #50
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
It is a Yamaha EQ550, and running the power on Crown XLS602D, with a Yamaha DSP 800 processor
band, project, tang, w69-1042m
