DIY Subwoofers
Tang Band W69-1042M project
Discuss Tang Band W69-1042M project in the DIY Speakers and Subwoofers forum; Tang Band W69-1042M project Mike P. wrote: The box can work. Green is with 2 drivers tuned to 40 hz. A single 3.75" port ...
Views: 2151 - Replies: 57
Old 09-17-09, 06:48 AM   #51
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Re: Tang Band W69-1042M project
Mike P. wrote: View Post
The box can work. Green is with 2 drivers tuned to 40 hz. A single 3.75" port would need to be 5.75" long. Orange is with 1 driver in the box tuned to 34 hz. A single 3.75" port would need to be 9" long. The same power input and Hi-Pass filter applies as above.
Attachment 15855
So, even if I have 2 drivers in 1 box, I will need only 1 port, and not 2 right..kindly confirm. Thanks.
Old 09-17-09, 03:36 PM   #52
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
That is correct.
We're all in this together!
Members DIY Subwoofer Database
Old 09-19-09, 04:13 AM   #53
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Thanks Mike..Shall let you know how it works out, Am still waiting for the speakers to come in..lets hope it come in soon so I can start, as I cannot make the cutouts before that, do u think the cutout dimensions are available so I can cut out the cabinets and keep them ready..thanks.
Old 09-19-09, 11:44 AM   #54
Alias: Mike
User: #8033
Since: Apr 2007
For cutout information you can try the Tang Band website.
Old 09-28-09, 07:57 AM   #55
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Hi Mike,
Could not get the details from the website. there is Part # w69-1042J, but there is not cut out details mentioned either.
One more questions, what is the High pass filetr used for. What if the signal going to this subwoofer is only dedicated for the sub from my Yamaha DSP-800 processor.
Regards.
Old 09-28-09, 08:15 AM   #56
Alias: Mike
User: #8033
Since: Apr 2007
Wait until you get the subs to see what the cut out size will be.
The hi pass filter set at 30 hz will block the frequencies lower then 30 hz so the sub doesn't bottom out from over excursion.
Old 09-28-09, 08:42 AM   #57
Alias: Avalon
Loc: Bahrain
User: #40825
Since: Aug 2009
  Avalon is offline
Fine. No problems. I shall wait for the subs..It has been nearly 9 weeks now, that's why I thought I'd start with the enclosures. Do you have any links of filters or website, where I can get this from. Thanks.
Old 09-28-09, 03:15 PM   #58
Alias: Mike
User: #8033
Since: Apr 2007
The Reckhorn B1 would be the cheapest.
http://www.creativesound.ca/details.php?model=B-1
band, project, tang, w69-1042m
