| DIY Subwoofers Woofer PhysicsDiscuss Woofer Physics in the DIY Speakers and Subwoofers forum; Woofer Physics The woofer in the svs is a monster more on the tc2000/revo level
I guess I hadn't thought about that.
Views: 1207 - Replies: 50
| | #26 | |||||
| Re: Woofer Physics Quote:
Thanks for replying here Chris. From what you wrote on the other forum, the Kappa 12 just isn't going to do what I want it to, regardless of how good a driver it is. Thanks also for the suggestion of the JL 12 W7, I wish I could afford it. So, it looks as though, if I want to reach down to 15Hz on the budget I have (200-300CDN) for a driver, I will have to compromise on the linearity/performance of the driver. I am curious to know what all of you would recommend in my situation. Last edited by fredk; 12-21-08 at 01:15 PM.. Reason: to fix the qote | |||||
| | #27 | ||||
| Re: Woofer Physics Linearity and performance will be highly dependant on the enclosure design as well! Better to have an average driver in a good/well designed enclosure than a perfect driver in an inappropriate box. That is why modeling is very important. The amp driving the sub will be also very important. Get the best you can and run it slowly. At the end, your room might not be perfect as far as modes and resonance, decay .... are concerned, as you see the driver is important but SQ will be also dependent on many other factors! ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #28 | |||||
If you could deal with a 10 to 11 net internal volume cabinet with a folded slot port, the Dayton RS 15" driver could be used with considerable output(115dB or so in room, real world) down to 13 Hz or so. Can you deal with that size cabinet? My in room SPL estimates are presuming you have an average size room(2000 cubic feet or less), that is closed(not large open corridors to rest of house) and that you will corner load the sub. You could use the same driver in a 5 cubic foot sealed cabinet and a parametric EQ band to compensate for LF loss, but output ability would be vastly reduced in the lowest octave that you consider so important. -Chris | |||||
| | #29 | ||||||
Sonnie broke it down earlier for you: Quote:
| | #30 | |||||
-Chris | |||||
| | #31 | ||||
| Re: Woofer Physics Blaser: 1. With all the help I will get here, how can I end up with anything but a brilliantly designed cabinet? I also happen to be reasonably handy.2. I am also working on my room, but being in a concrete box doesn't help. 3. I will be carefull to give whatever driver I choose the power it needs for the designed enclosure. 4. Yes, I am avoiding modeling drivers (for now). Winisd confused the out of me the last time I tried it. ![]() | ||||
| | #32 | |||||
| Re: Woofer Physics Chris. I could probably live with something in that size range. In fact, I was looking at a couple of designs that would turn the sub into a statement, after all, its hard to hide an elephant in a small room. I do need to figure out what the maximum I can live with is though.Steve. I did take note of Sonnie's most helpful posts at the beginning of this thread. Quote:
I can pick up the Mach5 ixl 18 for $265 delivered. They list their prices in Canadian and US as almost the same so that driver seems like the best deal for me at the moment. For the most part, the 49th parallel seems to be a very expensive line to cross. ![]() As a comparison, the Kappa 12 is listed at around $220 delivered in Canada. | |||||
| | #33 | |||||
Ditto on everything Steve has already said. The kappa is a nice driver but it is not anything spectacular in the linearity/ displacement department. I've never seen any testing on it that indicated that it was .There are plenty of other 12" drivers that are comparable in the high SQ, medium duty segment. Dayton RS series, Peerless XLS, JBL W12GTI, Aura NS12, etc. Klippel testing has been done on all of those and they have comparable capabilities. | |||||
| | #34 | |||||
-Chris | |||||
| | #35 | |||||
| | #36 | |||||
Is there other reading you folks would recommend or other terms I can search on that will help me understand the topic of driver quality/performance? | |||||
| | #37 | ||||
| Re: Woofer Physics From what your needs are and the 500-700 range you gave, you could easily build a quality unit like sonnie layed out previous. The amp is going to be the most expensive part of your system if you do not go with the ep2500. Based on the specs and the other experience of the other guys on this forum the mach 5 drivers will give you all you need. The CSS would do the same. All are in the mid 200's. Try elemental designs. | ||||
| | #38 | ||||
| Re: Woofer Physics What a coincidence that you poste here. I just finished reading your amazing build thread. Your cabinets are giving me some ideas for styling/look. If I go big, the sub should make a statement. It may well be that any of the drivers already mentioned will be fine for me, but I need to go through the learning and reading process. It is as important to me as the build and the results. | ||||
| | #39 | |||||
A general rule of thumb for me is assume that the driver will do 80% of the performance the manufacturer claims unless given cause to believe otherwise. Also use general deduction and common sense logic to educatedly guess. You basically have a budget of $500-700 and no size restriction. You want to get deep effortless bass to at-least 16hz and you also want it to sound good with music. Sound about right? | |||||
| | #40 | ||||
| Re: Woofer Physics To lay the claims and requests to rest concerning Andrew's DIY sub build... I believe his sub will be among the units that will be tested during his first couple of sub testing phases. This is by no means meant to get the thread off track... just FTR and FWIW. | ||||
| | #41 | ||||
| Re: Woofer Physics Ricci. That about sums it up. I found out that the lowest stop on large pipe organs is 17Hz, so 16 Hz would be a good target. Size is not a major constraint, but given my current room, I think 12 cuft. would be the upper limit (more or less) and 8-10 would be ideal. Sonnie. I'm looking forward to the measurements. | ||||
| | #42 | |||||
DIY sub is a great project to do. I just finish building 2 other subs in my home theater. Now I have 4 subs, 12 inches drivers with passive radiator. I really go down to 16hz with no problems and I can appreciate that in many recordings like "I Love you" from Sara Mclaclan and some movies like Shooter or transformers. There are many oppinions on a forum. But to me, only one sub is toomuch "directional" I can locate where the sub is in the room. I prefer using multiple sub to extend the sweet spot. In that configuration, I chose 4 small subs instead of a big one. Here is my building thread and mesuring with the first 2 subs. Mesuring with the 4 subs have not been post yet but the result is marvelous. Hope this can help. JP Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | |||||
| | #43 | ||||
| Re: Woofer Physics Thanks for the link to your build JP. Thats impressive output for 2 12"ers. OK, I finally downloaded WINisd and did some playing. Somehow, the program made more sense this time around. I guess somthing did sink in from all the reading I have been doing. I modeled the Kappa 12, Mach5 15 IXL and MJ18 all in 10cuft boxes tuned to 15Hz. Ignoring that I have no clue what I am doing yet, I was interested in general relative performance of a 12 and 15/18" driver at given tunings and volume. interestingly, for music, up to around 95db it looks like any of these would perform just fine barely breaking a sweat. I was expecting the Kappa 12 to work a lot harder at this volume. Here are cone excursion and spl graphs for the Kappa 12 and MJ18M: ![]() ![]() If I am reading this correctly, both drivers are going to produce around 95-100db. While the Kappa 12 requires more excursion to do this, it is still only at 33% of Xmax. Add another 5 db and the Kappa tops out at Xmax while the MJ18 is only at 44% of Xmax. So, a modestly priced 18" woofer is not going to work particularly hard in the same range where a good/pricey 12"er is going to have to be pushed to the limit. If the above modeling is correct, as long as the MJ18 is a reasonable performer, I should get clean output from it over the same range as that of the capacity, but I have headroom to spare. | ||||
| | #44 | ||||
| Re: Woofer Physics A couple of pointers here Fred. See how the Infinity is peaking around 20hz? You don't want that if you can help it. It indicates that the cab is too big for the tuning/driver used. Try decreasing the volume of the Kappa box until it looks more like the MJ-18M box, which is a nice looking response. Probably more like 5 or 6ft would be better for the Kappa. Some other things to remember and these are generalities so don't take them as concrete. The bigger your airspace for your driver to work in the more efficient the low end and the shorter your port will get for a given tune. However it becomes easier to bottom your driver with less power the larger your enclosure gets. See how the excursion charts have a notch in them near the enclosure tuning and how the cone excursion increases above that? With a properly implemented HPF on your sub this is the area you need to worry about, not what happens below tuning. The lower you tune the more excursion demands are placed on your sub in this area because it moves lower in frequency. See how much power it takes to get your driver close to xmax in that area and then buy an appropriately powerful amp, or choose the amp and driver first and scale the enclosure size and tuning to make the most of the available power. Also in general the larger your driver, or when you add multiple drivers the bigger the cab is going to need to be to keep a good FR or vent tuning profile. This is why you don't need 10cu ft for the Kappa. That's a huge amount of space for a single vented 12", it's just about right for a big vented 15" and it's on the small end for a vented HT 18". Try scaling down the Kappa enclosure to get a similar FR to the MJ18M enclosure and then apply enough power to get the cone excursion right at xmax above tuning for both. Then compare the xmax limited SPL graphs for both. It should make things a bit more clear. Perhaps try tuning them both a bit higher as well to 16 or 17hz. This will allow you to still get to 15hz with some authority, but give a shorter port length and also allow a bit more power handling above tuning. Last edited by Ricci; 12-29-08 at 03:15 PM.. | ||||
| | #45 | ||||
| Re: Woofer Physics Thanks for the comments Ricci. I didn't think that uptick at the bottom was good. I went back and looked at avaserfi's design and noticed the cabinet was much smaller. I did figure out the power handling/excursion stuff and with your comments I now understand what the notch is. If I understand correctly, the filter at the notch also protects the driver from unloading at lower frequencies?? In the max power curve I noticed a point at around 10-12Hz where the power requirements for excursion drop off a cliff. I take it this is where the driver is at risk of unloading without a filter? If I understand the max power graph properly, the notch shows you where you have enough power to exeed Xmax (and possibly Xmech)?? One thing modeling does not tell me is how cabinet size and venting affects the performance of the driver. A larger cabinet allows the driver to move more freely this use much less power for a given amount of travel. I wonder how this affects damping (hope thats the right term)? If a driver is able to start moving more easily, does that mean it will have a harder time stopping (mass vs resistance)? How might this affect the quality of sound? I keep thinking that there must be some way to take advantage of my lower spl requirements to reduce build costs. It looked like going to the MJ18 could shave $100 off the driver cost and maybe give some additional savings on an amp, but now I need another gizmo to keep the driver from self destructing. Where is my free lunch golly gosh geewhizzikers!! ![]() | ||||
| | #46 | ||||
| Re: Woofer Physics You probably want to use the Kappa VQ version using the Low Q configuration for modeling. I have it at home and will upload it later for you. Oh yeah... and there is an ED eQ.2 in classifieds for 60 bucks... HPF variable down to 5Hz. | ||||
| | #47 | |||||
In a very small enclosure, air compression inside the enclosure is on a higher magnitude than that of a larger enclosure - additionally, heat builds up more quickly. Since air doesn't compress completely linearly when heat is applied, and more power to reach a given excursion level is needed in a smaller enclosure, a smaller enclosure results in more distortion at a given excursion level as compared to a larger enclosure. This has been measured and confirmed by Ilkka. To Ilkka, the difference was smaller than expected - to me, it was larger than expected. On only the 105db sweep, the THD at 20hz was 10% in the small enclosure vs only 3% in the large enclosure. The difference only got bigger at higher sweeps. So to answer your question, a larger enclosure equates to better performance for a given driver.....despite what an "audiphile" may tell you. | |||||
| | #48 | ||||
| Re: Woofer Physics Thanks for the reply and the link Steve. I don't think I quite understand the usage of damping yet. It makes sense that linear distortion would increase as the power load to move the driver a given distance increases. I remember reading somewhere that distortion also happens when a driver dosn't stop moving when it is supposed to. Maybe I am using the wrong term(s)? Anyway, if a driver meets less air resistance to movement as box size increases I would think the tendancy to keep moving when its not supposed to would increase. Links or search terms to help me understand the above would be greatly appreciated. | ||||
| | #49 | ||||
| Re: Woofer Physics Thanks for the heads up Sonnie. I have been so focused on drivers, I missed that. At this point, my understanding of subwoofer design is very shaky so I have no idea where I should spend money first (or at all). I wonder if I could rig something up with sonotube that would allow me to adjust internal volume and port size so that I could do some real world playing in my room?? | ||||
| | #50 | |||||
If you want a term to search for, check air spring distortion. | |||||
