| DIY Subwoofers Find unknown T/S parametersDiscuss Find unknown T/S parameters in the DIY Speakers and Subwoofers forum; Find unknown T/S parameters I was given a 15" driver that had some very minor cone damage. A little glue and it works like ... |
Views: 540 - Replies: 5
| Find unknown T/S parameters I was given a 15" driver that had some very minor cone damage. A little glue and it works like new. The problem is, it doesn't have an enclosure. I would like to build a ported cab for the speaker but I know virtually nothing about this particular woofer. It seems to work pretty well down to about 25 Hz; I hooked it up to my amp/receiver and played some sine waves through it. Since I don't have any equipment, how would I find the T/S parameters to build the properly tuned box? Can I simply build a tuned enclosure at a low frequency such as 20 Hz and expect the woofer to sound decent? The driver came out of a JBL MS115 full-range cab. | ||||
| | #2 | ||||
| Re: Find unknown T/S parameters The JBL MS115 used the 2032H woofer. The parameters can be found here: http://www.thielesmall.com/database....orm=0&order=X# | ||||
| | #4 | |||||
| Re: Find unknown T/S parameters Quote:
To the OP, yup the driver will make a poor sub. It WILL make a good midrange however. ![]() | |||||
| | #5 | |||||
| Bookmarks |
| Tags |
| find, parameters, unknown |
| Thread Tools | |
