DIY Subwoofers
Bash Amp HPF Change
Discuss Bash Amp HPF Change in the DIY Speakers and Subwoofers forum; Bash Amp HPF Change Mike P. said "The IXL 12.2.2 would work well in a 3.5 cu.ft. box and with a 500 watt Bash ...
Views: 405 - Replies: 2
Old 02-14-09, 04:04 PM   #1
Alias: Xipe
XipeTotec's Avatar
Loc: Boise, ID
User: #32853
Since: Jan 2009
  XipeTotec is offline
Bash Amp HPF Change
Mike P. said "The IXL 12.2.2 would work well in a 3.5 cu.ft. box and with a 500 watt Bash amp. The high pass filter on the amp would need to be changed to 18.7 hz, the default on the amp is 30 hz. With a slot port 3" x 6" x 36.75" long the air speed is under 26 m/s. The port would take up .5 cu.ft. SPL would be 109 db at 20 hz, plus room gain. The sub is $192, shipping included."
I found direction on how to change HPF to 18.7 Hz, but the direction show different bass boosts of 1db, 3db, and 5db for the 18.7 Hz. Does it matter which one I use? How will these different "boosts" affect my project?
Old 02-14-09, 04:34 PM   #2
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: Bash Amp HPF Change
The 18.7 HPF that you need is from the ""1 db of Bass Boost"" table, which I should have stated. In your case the best HPF was at 18.7 hz, you don't need any boost, but the HPF comes with it. If you had a sub that the frequency rolled off at 25 hz, then the 3db of boost at 20-24hz would be a benefit. The down side to using boost is that a 3 db boost requires twice as much power and it taxes the amp.
We're all in this together!
Members DIY Subwoofer Database
Old 02-16-09, 02:16 PM   #3
Alias: Xipe
XipeTotec's Avatar
Loc: Boise, ID
User: #32853
Since: Jan 2009
Thanks again!
bash, change
