DIY Subwoofers
Metal Grill Effect
Discuss Metal Grill Effect in the DIY Speakers and Subwoofers forum; Metal Grill Effect What effect will the use of a metal grill have on a sub? I am considering PE part #260-375, pictured ...
Views: 354 - Replies: 12
Old 03-18-09, 11:22 AM   #1
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Metal Grill Effect
What effect will the use of a metal grill have on a sub? I am considering PE part #260-375, pictured below.
Old 03-18-09, 11:35 AM   #2
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: Metal Grill Effect
As long as it's mounted so not to interfere with the cone excursion, it should be ok.
We're all in this together!
Members DIY Subwoofer Database
Old 03-18-09, 01:36 PM   #3
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Thanks Mike. It should be close, but OK for cone clearance. I may add washers under the mounting screws to make sure.
Old 03-18-09, 01:42 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Just make sure that the rim of the grill is not going to vibrate against the wood of the cabinet. Some sort of rubber gasket would help in that regard.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 03-18-09, 01:50 PM   #5
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Good Idea. I may look for rubber washers. The rim of the grill has vinyl trim on both sides. It may provide enough dampening.
Probably the worst thing is that I'm only using 3 screws. I may have to add a few more to keep the vibrations down. It won't be hard, so I'll wait and see what happens.
Old 03-18-09, 05:26 PM   #6
Alias: Sparky
Loc: North Dakota
User: #17212
Since: Feb 2008
  sparky77 is offline
Those grills are well suited for low xmax woofers, but probably not best for larger xmax subwoofers unless the front trim on the rim of the subwoofer stands out significantly from the rolled surround. I have a pair on my 10 inch woofers in my main speakers and with an xmax of 3.5 mm, there's plenty of room, but if the xmax is about 12mm, it could get pretty close.
Old 03-18-09, 08:33 PM   #7
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
I guess it depends on several factors. I'm using a 15" grill on a 12" speaker. The grill provides for .650" clearance from the baffle face. My Xmax is about .750". The surround will only be .125" above the baffle because I seated the woofer below flush.
I'm in the hole about .100" at Xmax. My design probably can't reach X-max, but I'll add a washer just to be sure.
This grill would have plenty of room for a flush mount 12" speaker with 12mm or less of travel. The Dayton HF in a sealed box comes to mind.
Old 03-18-09, 10:10 PM   #8
Alias: Sparky
Loc: North Dakota
User: #17212
Since: Feb 2008
  sparky77 is offline
In that case, don't use washers, put some gasket tape on the bottom side of the grille, and I would actually recommend using the grill clamps from Pe, unless you already have a decent plane to clamp them down, and 3 clamps are not likely enough, I've used similiar grilles on subwoofers and they rattled even with 4 clamps, in the case of subs, 8 would probably be better, lol
Old 03-18-09, 10:32 PM   #9
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
Thanks. I am totally new to this and don't have a problem taking good advice. I already poked holes in the vinyl with spacing for 3 screws.
I'll add 3 more. That will put a screw about every 8" around the perimeter. If that's not enough, I'll add more.
Old 03-18-09, 11:06 PM   #10
Alias: Sparky
Loc: North Dakota
User: #17212
Since: Feb 2008
  sparky77 is offline
the clamps that PE sells, are the best way to go, rather than putting a screw through the rubber material, if you dead set on putting the screws through the rubber, which you apparently you already did, I would go with washers that would cover to the outer limits of the rubber coating.
Old 03-19-09, 12:20 AM   #11
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
I'm using washers. It looks good. The PE clamps don't look good to me.
Old 03-19-09, 08:19 AM   #12
Alias: Mike
Loc: Perth West.Australia
User: #25685
Since: Sep 2008
  Seaxe is offline
joorge,in answer to your OP,the best grille is no grille at all,in MHO.Years of listening have led me to this conclusion.My recently completed mains have no obscuring material over them.However, if drivers need protection from inquisitive pets or children,then some form of protection is mandatory!As well,pets and kiddies need protection too;they cant be replaced as easily as an driver. Hope this helps.Mike
Old 03-19-09, 10:22 AM   #13
Bronze Supporter
Alias: George
Loc: Lafayette, LA
User: #32511
Since: Jan 2009
  joorge is offline
It seems intuitive that the grill will have some effect. I'm not fussing about a Hz or dB here and there. I interpret the comments to mean that the effect is quite small. If so, I'll proceed with the grill.
effect, grill, metal
