DIY Subwoofers
Alarmed by Modeling vs Real-world Results
Discuss Alarmed by Modeling vs Real-world Results in the DIY Speakers and Subwoofers forum; Alarmed by Modeling vs Real-world Results I've seen some issues on the 'net where folks have built vented enclosures using the latest in software only to ...
Views: 479 - Replies: 11
Old 06-26-09, 02:59 PM   #1
Alias: mosconiac
mosconiac's Avatar
User: #33117
Since: Jan 2009
  mosconiac is offline
I've seen some issues on the 'net where folks have built vented enclosures using the latest in software only to find that the results were not as expected. For example, software may tell you to cut your port at 12", but the real-world port ends up at 10" for the desired tuning frequency. Let's not forget that damping material will throw the tune off too.
This has me alarmed because I'm about to make MDF dust for a Shiva-X and I don't want to build something only to tweak it endlessly in the field until its right. I expect to experiment a little, but taking the driver out 10 times to tweak the box volume or port length or stuffing would become ridiculous.
WinISD says I should build a 5.4cf enclosure tuned to 18Hz with a 36 sq.in. port 36 inches long. Troels Gravesen's empirical data indicates that the actual port length can vary from 60-80% of predicted!!!
http://www.troelsgravesen.dk/vent_tuning.htm
In order to accomodate a 36" long port without resorting to u-turns, I need a longish enclosure which forces an end-to-end resonant frequency low enough that I'm worried it will get excited. Port resonance is 188Hz and the lowest box resonance is 144Hz! If I build the box long to fit what the computer says only to find that the real-world port could have allowed a much shorter box...well...
When I stuff the box:
1) what should I use (703? wool? foam? polyfill?)?
2) how much should I use?
3) should I build a 5.4cf box if WinISD wants to see 5.4cf?
When I fab the port:
1) should I make it 36" long like WinISD says?
2) should I start @ 29" long (80% of predicted)?
What have your experiences been with respect to real-world vs software???
Old 06-26-09, 03:28 PM   #2
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Re: Alarmed by Modeling vs Real-world Results
The results are from a 29.5 Liter box using mathematical equations from www.diysubwoofers.org. The bigger the box the more "forgiving" the port length can be. Assuming your box volume calculations are accurate, WinISD has shown to be within 1 or 2 hz from tuning frequency stated in bigger then 4 cu.ft. box volumes. Depending on how much stuffing you use, it will slightly lower the tuning frequency and port output.
We're all in this together!
Members DIY Subwoofer Database
Old 06-26-09, 05:41 PM   #3
Alias: Collo
collo's Avatar
Loc: Newcastle, Australia
User: #5027
Since: Dec 2006
  collo is offline
I assume you are using a flared port with the Shiva-X
WinISD uses the effective length of the port. Physical length will be slightly longer as shown here:
You should also try and have a clearance of one port diameter (unflared section) in all directions from the inside end of the port.
You generally do not stuff a ported box, but treat the walls that are furthest apart with something like closed-cell foam or heavy felt. If you do add stuffing, ensure you have an unobstructed path from the driver to the port.
Ports Rule ...
Old 06-27-09, 12:11 PM   #4
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is online now
I wouldn't be alarmed - I've never seen a project have a port length off by 60-80%. I've seen tuning be off by 1-2hz, but that's not really a big deal.
Old 06-27-09, 07:33 PM   #5
Alias: mosconiac
mosconiac's Avatar
User: #33117
Since: Jan 2009
OK, it looks like the experts have calmed my fears. How does this sound?
1) Build the enclosure slightly larger than 5.4cf (recommended by WinISD) so I can adjust it downward as needed.
2) Build a port (3/4" flare) with 36 cu.in., 36-3/4" long and shorten if necessary to achieve the tuning I want (21 Hz).
3) Line the furthest ends of the box with a few inches of OC 703 (no other fill) to tame the 144Hz box resonance.
Old 06-27-09, 08:59 PM   #6
Alias: Mike
User: #8033
Since: Apr 2007
Sounds like a plan.
Old 06-28-09, 07:25 PM   #7
Alias: Jailer
Jailer's Avatar
Loc: Michigan
User: #23628
Since: Jul 2008
  Jailer is offline
Don't be too alarmed with the results of the modeling software. It comes in close enough for it's intended purpose.
I modeled mine entirely with Winisd and it came in about 2 Hz higher than predicted on the tuning but it's good enough for me.
Old 06-29-09, 12:24 PM   #8
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
All of the vented subs that I have measured have come in tuned very close to what is predicted. Within 1-2hz as others have noted. It's not a big enough difference compared to some other variables to worry about it.
Old 07-01-09, 04:24 PM   #9
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
  looneybomber is offline
Way OT here, but Ricci, your avatar shows your dual SDX-15 by Funkywaves, but what is that speaker next to it with what looks like the TD drivers by AE?
Old 07-02-09, 03:30 PM   #10
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
looneybomber wrote: View Post
I wish they were TD's! and they might be in the future, but for right now they are Klipsch Epic CF-4's. They use dual neo 12's, a 2" compression driver in a tractrix horn and weigh 102lbs each. I drooled over them at my local hifi shop when I was 14 and just getting into audio. Picked up 2 pairs of them used over 10years later for right at $600pr. They aren't the most liquid and absolutely pure sounding speakers ever, but they sound good to me and will kick out the jams for HT or parties.
Old 07-03-09, 01:44 PM   #11
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
A model is only as accurate as the assumptions behind the model.
If your design is such that the assumptions are still valid, then you should get extremely well correlated results between the model and the real world. You shouldn't, however, blindly plug numbers into a program until it shows a pretty line....that's a recipe for random results.
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 07-07-09, 03:04 AM   #12
Alias: Vas
Loc: NYC
User: #35621
Since: Mar 2009
  Vasyachkin is offline
you worry too much
normal people just buy a generic box and are happy with tuning frequency two octaves off ...
ported boxes are compromised to begin with.
alarmed, modeling, real-world, results
