| DIY Subwoofers Port Length-Cut From ThreadDiscuss Port Length-Cut From Thread in the DIY Speakers and Subwoofers forum; Port Length-Cut From Thread SteveCallas wrote:
While the sims may not show a perfectly flat response with a larger enclosure, do remember to go ... |
Views: 308 - Replies: 12
| | #1 | |||||
| Port Length-Cut From Thread Quote:
I would really, really prefer not to go larger than this, but am afraid there's still not enough clearance between the port and the driver I am thinking of using 3 ports 4" wide which would give me an equivalent of 7" port (6.9 actually). Any reasons why I should not go that route? | |||||
| | #2 | ||||
| Re: Maelstrom-18" Gen II Landed This is probably not the right thread to discuss build specifics. But I'll quickly tell you that you don't want a port length longer than 36" - either increase enclosure size, raise the tuning frequency, or consider passive radiators. | ||||
| | #3 | |||||
| Re: Maelstrom-18" Gen II Landed Quote:
| | #4 | ||||
| Re: Maelstrom-18" Gen II Landed I agree to disagree with those who claim no audible degredation with port resonance that low. | ||||
| | #5 | ||||
| Re: Port Length-Cut From Thread There are a least a dozen or more sub builds here with ports that exceed 36 inches. No complaints from any of them. One with a 50 inch port was close mic-ed and the response shown to have no issues. So what are you basing your "disagreement" on? | ||||
| | #6 | ||||
| Re: Port Length-Cut From Thread Mike I have to side with Steve on this one. I've not seen the data that convinces me that a 50" port is not going to have some audible issues in the pass band. I'm interested in seeing it if you have some links. I've seen a lot of people claim that it is fine, but you know how that is. Perhaps through creative bending, placement and damping/stuffing of the enclosure you can implement one well, but I would still hesitate to recommend it. 63hz 2nd harmonic is 125hz 42hz 3rd harmonic is 125hz 32hz 4th harmonic is 125hz Distortion coud excite the port resonance and a crossover does not help with that. | ||||
| | #7 | ||||
| Re: Port Length-Cut From Thread Post #39, Andrew tested a 55 inch port. It's my understanding there are no issues as long as a 4th order 80 hz crossover is used. http://www.hometheatershack.com/foru...dations-2.html | ||||
| | #8 | ||||
| Re: Port Length-Cut From Thread I remember that thread. I also remember not being totally convinced. Andrew's measurements were from 1" and did not include a complex sum of the port output mixing with the driver output measurement from a further distance such as 1m equidistant from the port and driver. They clearly show a very large spike in the upper port output. Also his enclosure has more attention to detail and also has a many folded port. Other people may not put so much effort into it. What if it's just a straight 50" pipe with no bends and not as much damping? The resonance will likely be stronger. Someone should test this stuff... ![]() | ||||
| | #9 | |||||
| Re: Port Length-Cut From Thread Quote:
| | #10 | ||||
| Re: Port Length-Cut From Thread I changed the effective volume to 370 l and the port is now 3'4" with 169Hz resonant frequency. I'm not really worried about resonance since I'm planning on getting a BFD. A simple notch filter would put that issue to bed (Isn't this the original purpose of BFD, surgically removing troublesome frequencies?). I still don't know what's the minimal acceptable distance between the port and the driver. Any suggestions? | ||||
| | #11 | ||||
| Re: Port Length-Cut From Thread One port diameter or more. | ||||
| | #13 | ||||
| Re: Port Length-Cut From Thread For a sonotube the end of the port should be one diameter from the magnet, for box enclosures the port should be one diameter away from any side or back wall. | ||||
