| DIY Subwoofers Definitive technology D1LW 18 inDiscuss Definitive technology D1LW 18 in in the DIY Speakers and Subwoofers forum; Definitive technology D1LW 18 in I recently purchased a D1LW 18 in sub off the net. I did so without having seen any T/S specs. ... |
Views: 352 - Replies: 4
| Definitive technology D1LW 18 in I recently purchased a D1LW 18 in sub off the net. I did so without having seen any T/S specs. Was I in for a suprise when I measured it on wt3. The Re of this thing is 38 ohms !!!!! a tag on the magnet says it is in fact a 32 ohm speaker ! Now my question is, how do I power this? My amp is really suited for 2 or 4 ohm. Can this be made to work,or am I stuck ? Why would they make the r so high? It would take a 5kw amp to pull any spl !!!. Any and all help is greatly appreciated... | ||||
| | #2 | ||||
| Re: Definitive technology D1LW 18 in Either you find the amp that went with it or sell it on e-Bay and buy a subwoofer with known parameters and performance. | ||||
| | #4 | ||||
| Re: Definitive technology D1LW 18 in This woofer is normally driven with a custom Class D MOS amp. I have the schematic for the amp but it's a prety scary setup with the MOSFETs hanging directly of a rectified 110V/ I bought the same speaker and actually have a pair of 3000TL which use this speaker. I am still deciding what to do next. I actually have 4 of these woofers and was thinking to use them in parallel to lower impedance to get to 8 ohms. Not sure this would realy work out though... Were you able to measure all the T/S params for this speaker ? Would be interested to get these params. Thanks | ||||
| | #5 | ||||
| Re: Definitive technology D1LW 18 in These are the T/S parameters I have Re 37.5 ohm Fs 21 hz Qts .310 Qes .334 Qms 4.406 Le 10.49mh What kind of amp are you going to use on this high r sub? Do you have one of the def tec amps? | ||||
| Bookmarks |
| Tags |
| d1lw, definitive, technology |
| Thread Tools | |
