DIY Subwoofers
Newb needs some help.
Discuss Newb needs some help. in the DIY Speakers and Subwoofers forum; Newb needs some help. Hi all. Im new to this site and the world of HT and have learned so much from this site. ...
Views: 168 - Replies: 5
Old 09-03-09, 09:10 PM   #1
New Member
Alias: locolu
User: #41506
Since: Sep 2009
  unlimitedsp is offline
Hi all. Im new to this site and the world of HT and have learned so much from this site. I am slowly starting to build my own system, but am still learning, so it will be a slow process for now.
With the help of the great information on this site I have started to build my first diy subwoofer. It consists of A Dayton RSS390HF-4 and a Bash 300w amp.
My question is. I have a Pioneer HTIB (yea I know) and was wondering if it is possible to hook up my powered sub to its reciever? It has a passive sub on it now. Its Just until I finish the new system.
Here is what the back of the reciever and the amp looks like.
Old 09-03-09, 09:44 PM   #2
Alias: Mike
Loc: San Dimas, CA
User: #13466
Since: Nov 2007
  sub_crazy is online now
Re: Newb needs some help.
It looks like you will unplug the passive sub that is currently connected and run speaker cables from the subwoofer output into the BASH amps hi level input. It should not matter which hi level input you use.
I could not tell from the pictures since some RCA labels are hidden behind cables but if there is a RCA subwoofer out then you will want to use that instead.
Old 09-03-09, 11:30 PM   #3
Alias: Jerry
Loc: Iowa
User: #40576
Since: Aug 2009
  bdrrusty is offline
How's your sub build going.
I am just about done building my first diy sub with the RSS390HF-4 and Bash 300 amp. Hopefully it's a good combination.
Old 09-04-09, 12:55 PM   #4
New Member
Alias: locolu
User: #41506
Since: Sep 2009
sub_crazy wrote: View Post
No theres no subwoofer out. Thats the first thing I looked for.
bdrrusty-Its going pretty well. I got my sub in already, just waiting on the amp. Still need to tweek my design a little and I should be ready to start building. Im going with a 9cu ft ported cabinet tuned to 20hz. From what I have read on here this combo is a nice setup for a low budget.
Old 09-04-09, 02:35 PM   #5
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Mike is right. This is the correct way, by running the speaker output from the receivers sub speaker terminal to the high level inputs on the Bash amp it will work fairly good.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-04-09, 03:03 PM   #6
New Member
Alias: locolu
User: #41506
Since: Sep 2009
Thanks alot for the help. Now I just need to finish this thing.
help., newb
