DIY Subwoofers
Custom Subwoofer Grill
Discuss Custom Subwoofer Grill in the DIY Speakers and Subwoofers forum; Custom Subwoofer Grill I've purchased a Tempest-X2 to go into a 2.1 system for my computer. Since the sub is going to be ...
Views: 166 - Replies: 1
Old 10-28-09, 03:16 AM   #1
Alias: Greg
User: #37823
Since: May 2009
  Dark Regent is offline
I've purchased a Tempest-X2 to go into a 2.1 system for my computer. Since the sub is going to be on the floor at a nice kicking level I'd like to get a steel grill for it if possible. Does anyone know of a place that makes custom round grills for subs, like this:
I'm not a fan of the waffle pattern grills available at PE, I prefer the small round holes patterns. Also, I'd like it to have a circle of mounting screws, rather than 4 "clamps" to hold it to the front of the enclosure. I don't need it to fit the mounting holes of the Tempest. If I could get one with an inner diameter of 16" and bolt it to the front of the enclosure that would be good too. The problem is this thing will need to be 2" deep to clear the excursion of the Tempest. Any ideas?
Old 10-28-09, 11:30 AM   #2
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: Custom Subwoofer Grill
An option if you have a router is you can make a grill out of MDF. The thickness of the grill will depend on if the sub is flush mounted or surface amounted. Mine were surface mounted so the grill frame is 1.5" thick.
http://www.hometheatershack.com/foru...sub-kit-2.html
We're all in this together!
Members DIY Subwoofer Database
custom, grill, subwoofer
