DIY Subwoofers
RE Audio xxx 18 sub
Discuss RE Audio xxx 18 sub in the DIY Speakers and Subwoofers forum; RE Audio xxx 18 sub Does anyone have any experience with th RE Audio xxx 18 sub? I'm intrested in how they perform.And what kind ...
Views: 376 - Replies: 12
Old 10-28-09, 05:37 PM   #1
Alias: BRYAN
Loc: louisville
User: #30713
Since: Dec 2008
  realtor416 is offline
RE Audio xxx 18 sub
Does anyone have any experience with th RE Audio xxx 18 sub? I'm intrested in how they perform.And what kind od enclosure they work best in.
Old 10-29-09, 02:47 PM   #2
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is online now
Re: RE Audio xxx 18 sub
Yep. They perform quite well, require huge amounts of power and they like large enclosures, but that depends on what size driver you are looking at using. Sealed is a lot easier build and implementation for them. Ported is difficult to pull off right.
Old 10-29-09, 03:36 PM   #3
Alias: BRYAN
Loc: louisville
User: #30713
Since: Dec 2008
I just saw your post on your stuff this morning.Sorry bout that i,m always short on time and dont get to look on here much.I was thinking of doing one 18 like you have for now in a sealed.Space is not a problem what size enclosure should I build to maximize performance?Thanks for your help.
Old 10-29-09, 04:18 PM   #4
Alias: Ryan
Ryan Anderson's Avatar
Loc: sfsd
User: #39709
Since: Jul 2009
  Ryan Anderson is offline
assuming you're talking 06' (new) model?
My LLT in-car build log
Fi IB3 18 21 cubes @ 15Hz 7.75" x 19.5" sonotube
http://www.hometheatershack.com/foru...tml#post198320
Old 10-29-09, 05:17 PM   #5
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is online now
Assuming that we are talking about the big 80lb 06 model. I put all of mine in 270L or about 9 cu ft and then stuffed the enclosure with poly fill pillows. 23.5x23.5x37 is roughly how big. A 26 or 27" cube would work well. Get a big amp. An EP2500 would be ok but something like a QSC PLX3602 or big Marathon would be better.
Old 10-30-09, 06:15 AM   #6
Alias: BRYAN
Loc: louisville
User: #30713
Since: Dec 2008
Yes Ricci, thats the one I'm talking about. I guess I will get this party started.Any advice on the best place to pick one up at?Cant wait to shake the foundation of my new theater.LOL
BTW Ricci,noticed you play music.My lifelong friend runs Doo Wop if you ever need a deal on something.Thanks
Old 10-30-09, 11:59 AM   #7
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is online now
I just noticed that you are from Louie too. Cool. I rented my second drumset for so long that I paid it off and that was from Doo Wop. Back in like 96. I haven't been in there in years.
I bought my drivers off of Ebay. Either MobileSoundWorks or Woofersetc has them for $850 shipped. Make sure you get the D2 voice coil driver. That's about the best deal I've seen lately on the 18". Shop around for a pro amp in the classifieds on Prosoundweb or similar. A QSC PLX3602 or older PLX3402 would be just about a perfect match. Sometimes you get lucky and find one used for about $600. There are plenty of other amps as well.
Old 10-30-09, 12:53 PM   #8
Alias: Ryan
Loc: sfsd
User: #39709
Since: Jul 2009
Ricci wrote: View Post
:-O I guess it didn't sink in you got them all that cheap! It's engraved in my head that they're about 1200 new... were they used?
Old 10-30-09, 01:02 PM   #9
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is online now
All of them were new except one which was used and I got it for about $670 shipped if I remember right. I ended up needing to recone that one though. It had a coil misalignment. The rest were anywhere from $700-$850.
Old 10-30-09, 01:22 PM   #10
Alias: Ryan
Loc: sfsd
User: #39709
Since: Jul 2009
I haven't had a chance to model yet, but what would you say has more total clean displacement, XXX or 21"? I know Xmax(2)xSd the XXX has more, but Xmech(2)xSd the MX... I'm guessing I'd be equally happy with either?
Old 10-30-09, 01:53 PM   #11
Alias: Ryan
Loc: sfsd
User: #39709
Since: Jul 2009
you got a WinISD downloadable driver data?
Old 11-04-09, 07:49 AM   #12
Alias: BRYAN
Loc: louisville
User: #30713
Since: Dec 2008
Just got the 18 d2 off ebay "new with shipping for 775.00" from audio savings
Old 11-04-09, 12:37 PM   #13
Alias: Ryan
Loc: sfsd
User: #39709
Since: Jul 2009
realtor416 wrote: View Post
:-O
pics!
audio
