DIY Subwoofers
ULS-15 or should I build my own with TC sounds
Discuss ULS-15 or should I build my own with TC sounds in the DIY Speakers and Subwoofers forum; ULS-15 or should I build my own with TC sounds Hello everyone, I am new to the shack and DIY speaker building, that being said i am a good cabinet ...
Views: 379 - Replies: 32
Old 11-03-09, 01:16 AM   #1
Alias: Brad
User: #44253
Since: Nov 2009
  Brad f is online now
Hello everyone, I am new to the shack and DIY speaker building, that being said i am a good cabinet maker and are considering building a sub that can at least sound as good or better than a hsu uls 15.
I am using this as a reference for size and sound quality. The driver I have thought of using are the new LMSR 15 from tc sounds and a 1000 watt dayton plate amp. Any comments much appreciated (design and equipment).
Old 11-03-09, 02:12 AM   #2
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: ULS-15 or should I build my own with TC sounds
I haven't heard of a LMSR 15, can you post the T/S parameters?
We're all in this together!
Members DIY Subwoofer Database
Old 11-03-09, 09:53 AM   #3
Alias: Brad
User: #44253
Since: Nov 2009
Thanks for the reply Mike. I will try to get the information from TC sounds. I am told this is a new driver
to be released in late December. I just asked for the best recommendation for high quality sub and amp that would meet or exceed the ULS 15 . I don't know if there are other combinations of amps and drivers that would work well, and be more reasonably priced. My knowledge is very low as far as reading specs
on drivers and matching amps therefore I am referring to the ULS-15 as a goal. I was going to purchase it because of price, reviews and size.
Old 11-03-09, 12:10 PM   #4
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
  looneybomber is offline
For sealed enclosures, output is a function of displacement (swept volume by the cone of the driver). Increase displacement and you move more air, move more air and you create more sound.
Using a near equal long throw 15 in a box of near equal size of the ULS-15 with near equal power, will result in near equal output.
So in order to achieve your goal of more output, you will need a driver(s) that will move more air than the ULS-15.
Way's of doing this.
1) Use more drivers than the ULS-15 with equal or more power and a larger box.
2) Use a bigger driver (18") than the ULS-15 with equal or more power and a larger box.
3) Use more drivers than the ULS-15 with more power and a slightly larger box.
4) Use a bigger driver (18") than the ULS-15 with more power and a slightly larger box.
Old 11-03-09, 01:37 PM   #5
Alias: Ryan
Ryan Anderson's Avatar
Loc: sfsd
User: #39709
Since: Jul 2009
  Ryan Anderson is offline
looneybomber wrote: View Post
IMHO, I believe this is the case with almost all enclosures, the only exception I can think of now is these horns that would be over loaded with drivers with more Xmax. Otherwise, even a pro audio sub that had more excursion, swept volume, would still have more capeable output...generally speaking.
My LLT in-car build log
Fi IB3 18 21 cubes @ 15Hz 7.75" x 19.5" sonotube
http://www.hometheatershack.com/foru...tml#post198320
Old 11-03-09, 01:43 PM   #6
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Brad, what will the sub be used for? HT, music, or both? Depending on what you are looking for, the parameters will dictate what box size will be optimum for the given application.
Old 11-03-09, 02:02 PM   #7
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
Ryan Anderson wrote: View Post
Well for sealed enclosures, the swept volume is the only thing that creates sound. With ported enclosures, there's the driver and the port...which is why sealed vs. ported discussions are so numerous, but there's rarely ever sealed vs. sealed discussions.
But yeah, in general, the more air you move, regardless of the enclosure, the more SPL capability there is.
Old 11-03-09, 02:13 PM   #8
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
All things being the same, yes. There is also the sensitivity issue to consider.
Old 11-03-09, 02:29 PM   #9
Alias: Tyson
User: #44274
Since: Nov 2009
  Tyson is offline
Build it if you can, there's nothing like the pride of having done it yourself.
Old 11-03-09, 02:37 PM   #10
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
Mike P. wrote: View Post
Well that and efficiency just dictate the amount of power required to reach a certain SPL. Whether it takes 100w to displace 1L of air at 80hz or 1000w, the same SPL will result with sealed enclosures. That's why I have in my post comments about more power but equal sized box, or equal power but larger box. The larger box increases efficiency.
If a person's goal is Xdb at Yhz and they have a limit on enclosure size, the only variables to adjust are swept volume and power. Sensitivity and efficiency are dictated by those choices.
Old 11-03-09, 03:52 PM   #11
Alias: lsiberian
Loc: Fort Worth, TX
User: #35637
Since: Mar 2009
  lsiberian is offline
You can most certainly build a better sub then any commerical one of similar price. TC Sounds drivers are fantastic so that would be a great start.
Old 11-03-09, 05:20 PM   #12
Alias: Ryan
Loc: sfsd
User: #39709
Since: Jul 2009
i agree there. on car audio forums there was a lot of talk about how the square subs only benefitted from the Sd gain in vented enclosures... either way, you can only move so much air, to me you gain just as much sealed as vented or bandpass or anything else so long as you don't begin overloading things
Old 11-03-09, 06:36 PM   #13
Alias: Mike
Loc: San Dimas, CA
User: #13466
Since: Nov 2007
  sub_crazy is offline
LMSR 15?
I did get a response from TC Sounds about the LMS 5400 series and was told it would be only available in a 18" size but maybe the LMSR 15 is a new model for them?
There new e-commerce site should be up in about a month so I can't wait to get more info.
Old 11-03-09, 06:38 PM   #14
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
lsiberian wrote: View Post
That remanins to be seen. Hopefully the quailty will be the same with their "new" manufacturer.
Old 11-03-09, 07:02 PM   #15
Alias: Mike
Loc: San Dimas, CA
User: #13466
Since: Nov 2007
I don't know this for sure but I believe they are using the same build house as Exodus. When Kevin showed pics of the new M-21 rolling off the assembly line Kyle from TC commented how that place looked like he had been there before in a joking fashion.
The LMS 5400 18" needs to be as good or better than it's predecessor for the price they are asking.
Old 11-04-09, 12:12 AM   #16
Alias: Brad
User: #44253
Since: Nov 2009
Thanks for the info, so to sum this up spl at a certain frequency can be achieved by more watts in a smaller enclosure. Less watts in a larger enclosure? If this is correct does that mean I should be able to spend less money (on amp and driver)if I fabricate a larger box and achieve the same spl?
What makes a subwoofer speaker sound better than another, is it the voice coil for speed and acurracy? Also I should let everyone know this sub is 90% home theater and 10% music. My room size is 2700 sq ft.
Old 11-04-09, 12:19 AM   #17
Alias: Brad
User: #44253
Since: Nov 2009
Hello Looney, Thanks for the input. Can you explain swept volume and power? Also how do I know how much DB output I need in 2700 sq ft room.
Old 11-04-09, 12:39 AM   #18
Alias: Brad
User: #44253
Since: Nov 2009
MIke, I am waiting to hear back from Thilo at TC Sounds. Sounds like the driver is modeled after the
Revo driver but there will be changes to the voice coil. Thats all I know for now. I assume this is a much
better driver than what is in the HSU ULS-15 as the driver is around 450.00 dollars. That being said I don't know how much it would improve the output if I put it in the same size cabinet.
Old 11-04-09, 01:42 AM   #19
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
We'll have to wait for the T/S parameters and model it to see how it will perform in the same size cabinet as the ULS-15.
Swept volume is the amount of air a sub can move. It is the Sd of the sub times the Xmax equals an amount usually stated in liters. The larger the box the less power it takes to reach the maximum amount of air the sub can move.
Old 11-04-09, 02:01 AM   #20
Alias: Ryan
Loc: sfsd
User: #39709
Since: Jul 2009
I've gotta get used to "swept volume" myself, I'm a nerd, I call it Vd :P
Old 11-06-09, 01:36 AM   #21
Alias: Allan
Loc: Austin, TX
User: #13577
Since: Nov 2007
  Allanf714 is online now
I noted on another post that the LMS-R is a "Revo with a 3inch linear VC." Lest not forget the insatiable power appetite of the 5400 series. They require upping the current capabilities of your power lines and BIG amplifiers. An expensive proposition on both accounts. The LMS-R series, if it is as stated above, would actually be more desirable to a majority of DIYers. Can't wait to see specs.
Allan
Old 11-06-09, 10:32 AM   #22
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
  Warpdrv is offline
I have a couple 15" TC-2000's and a 15" Revo just laying around if anyone is interested. I ended up with LMS's so these never saw a mounting...
I have a new 18" LMS on pre-order, supposed to be coming at the end of the month.... the new drivers are suppose to be improved, but LMS's will still be expensive at the $1599 mark...
Old 11-06-09, 11:44 AM   #23
Alias: Mike
Loc: San Dimas, CA
User: #13466
Since: Nov 2007
Man I wish I would have bought a pair of LMS 18" when they were in the $900 range
I don't know if there new pricing is worth it for me.
Old 11-06-09, 01:40 PM   #24
Alias: Allan
Loc: Austin, TX
User: #13577
Since: Nov 2007
I did actually speak with someone over at TC when the LMS ULTRA was released under the Audio Pulse name. I had inquired about differences in my LMS 5400 and the newer version. That person (cannot remember who) had described the flat wire used in the new coil but was quick to point out that it didn't really make that much difference. He implied that the newer versions had to be different in some ways to justify the price increases. Not to place any doubt at all on TC engineering prowess, but I am curious as to whether there are any real world performance differences between the older 5400 series and the upcoming version. Hopefully we can get a new one to Ikka for testing
Allan
Old 11-06-09, 01:53 PM   #25
Alias: Mike
Loc: San Dimas, CA
User: #13466
Since: Nov 2007
It doesn't make much sense to me why TC nearly doubled the price of the LMS 5400. If I recall correctly they used to do final assembly here in the US but now I believe they are being entirely built oversees. This usually brings down the cost, not doubles it.
It is too bad as I would like to support them but at there new prices I cannot justify the expense. There are plenty of others drivers which come close in performance for a lot less $$.
build, sounds, uls-15
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
