| DIY Subwoofers Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70?Discuss Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? in the DIY Speakers and Subwoofers forum; Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? Taking the displacement of the driver into account. Thanks
Posted via Mobile Device... |
Views: 179 - Replies: 13
| | #2 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? The RSS265HF-4 has a Q of .7 at 3 cu.ft. Assuming 100% stuffing equals a 25% increase, then the box would be 2.4 cu.ft. Add whatever the displacement of the sub is to that and you have the total internal volume. | ||||
| | #3 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? Hmm? Are you sure you modeled the 10"? I have never used WinISD before, but I entered the driver data into it and it says Q of .703 = 1.098 cu ft. sealed. Now, subract 25% of that volume for 100% stuffing = .82 cu ft. (+ air displaced by driver itself). Is this wrong? How do I determine how much air the driver is displacing? Thanks for all the help! | ||||
| | #4 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? Here is the WinISD file for the sub. Check these parameters against the ones you entered into the program. Dayton 10_ Reference HF (RSS265HF-4).wdr. | ||||
| | #5 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? That is the file I saved to the drivers folder. I chose that driver, in a sealed enclosure and I chose the .7 Q selection. When I clicked on the box tab, it read 1.098 cu ft. 75% of that (for 100% stuffing) is .82 cu ft. Posted via Mobile Device | ||||
| | #7 | |||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? There's a problem somewhere. Not sure where though. Hopefully someone else can verify which is correct. Quote:
| | #8 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? The driver files we're using are different. Yours has ohm's as being 6, vs. 4 and a couple other diffrences. ![]() Last edited by costanza; 11-06-09 at 10:23 AM.. | ||||
| | #9 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? The box I have already built is roughly 1.6 cu ft. I subtract .4 for an internal amp enclosure and subtract .10 for an estimate of the driver's displacement, which gives me just at 1 cu ft. +/- 10% (no stuffing). This sound good? | ||||
| | #10 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? How weird is this?! My box's internal volume just happens to be 1.64 cu ft (14.5 x 13.5 x 14.5) with the amp enclosure removed. Winisd's recommendation for vented enclosure for this driver is 1.43 cu ft (bb4/sbb4) w/ 1 vent 4" x 31", which itself equals .22 cu ft. Subtract the volume of the port's tubing from my box's volume, and you have 1.42 cu ft.!!!!! | ||||
| | #11 | |||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? Quote:
| | #12 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? | ||||
| | #13 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? Your file is correct. Some how mine got corrupted. The parameters in mine were way out, not sure how that happened. | ||||
| | #14 | ||||
| Re: Smallest sealed box w/ 100% stuffing for RSS265HF-4 ohm 10" w/ Q of .70? Yeah I checked the file I submitted vs the PDF and it looks good. 1 cu ft is good for sealed. 1.5 is good but small for vented, one problem with venting these small drivers is for a very low tune in a smallish box the ports get real long real quick. A 4" port needs to be liked 35-40" for a low tune in a 1.5 cu ft box. Try fitting a port that long in a box that small... ? Anyways either way good luck with your build, let us know where you end up. Last edited by evilskillit; 11-07-09 at 11:21 AM.. | ||||
