| DIY Subwoofers Help with sonotubesDiscuss Help with sonotubes in the DIY Speakers and Subwoofers forum; Help with sonotubes I'm gonna build a couple of sonotube subwoofers, and would like some advice. Think I'm gonna be using the mach ... |
Views: 278 - Replies: 24
| Help with sonotube build I'm gonna build a couple of sonotube subwoofers, and would like some advice. Think I'm gonna be using the mach 5 audio ixl 18.2 driver since I live in canada. I've been doing lots of searching on here, and I'm gonna need to use a 24 inch sonotube, with a 6 inch port? 3/4 mdf for the top and bottom plate, and base? I just dont know the length I need to make the sonotube, and what length the port needs to be. This will be my first build, so any help would be appreciated. I'm going to be purchasing an ep4000 to run the two, I already purchased a bfd 1124. One other thing I'd like to know, is whats best to dampen the inside with. Tks kenny Last edited by ps3bluray; 11-07-09 at 01:25 AM.. | ||||
| | #2 | ||||
| Re: Help with sonotube build http://www.subwoofer-builder.com/WinISD.htm (This is the file for the Mach5 18.2.2 Driver) http://www.subwoofer-builder.com/sonosub.exe (This is to help with correct tube and Port size) http://www.subwoofer-builder.com/Win...20IXL-18.4.wdr (This is the Mach5 18.2.2 driver file for WinISD pro to help model the sub in given enclosure and port length) Have a play with some of the software. Mach 5's Recommended box size for the 18.2.2 is 365 litres (12.88 cu.ft.) 15hz tuning but will work well in a 200lt box with a 20hz tune. Check out some of the build threads on the site for some inspiration for your build. Happy Building. | ||||
| | #3 | ||||
| Re: Help with sonotubes The diameter of the sonotube needed will depend on the what box size and tuning frequency you choose. There needs to be enough space between the end of the port and the back of the subwoofer. Are your subs going to be used for HT? | ||||
| | #4 | ||||
| Re: Help with sonotubes Ya it's going to be mainly used for ht. Tks david, I'll try some of that software out. Can we assume though that in order to get a low tune I'll probably need the 24 inch tube. I wanna pick up the mdf this weekend, cause I have a friend whose gonna cut it for me, I wanna get the ball rolling on these. Posted via Mobile Device | ||||
| | #6 | ||||
| Re: Help with sonotubes The 24" sonotube will work. In 400 liters tuned to 15 hz you'll need an 8" port to keep the port airspeed down. ![]() Here are all dimensions you'll need to build the tube. The base plate legs need to be a minimum of 4.5" tall for the sub to breath. ![]() | ||||
| | #7 | ||||
| Re: Help with sonotubes You'll really want to use more than one 3/4" layer of MDF per endcap - luckily MDF isn't very expensive. Three layers per cap would be great, with two layers going inside the tube and the third sticking out of the tube. Screws can't bite into MDF too well, so you may want to use small sections of wood or plywood at each mounting spot. Lastly, save the driver cutouts from the bottom endcap - you can use them to create donuts for extra support of the port on the top cap - see the second attached picture. Oh, one more tip - if you put a slight chamfer on the outer edge of the inner layers of endcap, it makes it easier to guide the tube into place. | ||||
| | #8 | ||||
| Re: Help with sonotubes Awesome thanks mike. So my my mdf, 3/4 inch? I'll cut 2 circles at 24 inch, Top and bottom and 3 circles at 25 inch. Top, bottom and baseplate? Does the port need to be flared both top and bottom? What do I line the inside with? Posted via Mobile Device | ||||
| | #10 | ||||
| Re: Help with sonotubes I only used one layer on my end caps without issue. It certainly won't hurt to make more, but if you don't have tools to make the cutting easy, or the extra MDF, I wouldn't worry about it. You also don't HAVE to flare your ports. Like the extra end caps, it certainly won't hurt, but at least for my build I didn't flare and I'm totally satisfied. As far as what to line the inside with, all I did was use thick foam like you use to protect stuff when you ship it, on both end caps. Take everything I say with a grain of salt. But also don't get caught up in the you MUST do this or this or it will sound horrible. That's not always the case. | ||||
| | #11 | |||||
| Re: Help with sonotubes Quote:
| | #12 | ||||
| Re: Help with sonotubes Well sure, you can get away with not doing a lot of things. You can also get away with driving a Kia Rio if you really wanted to. If you are going to spend the time, energy, and money to build a subwoofer though, you may as well do it right the first time and not have to second guess anything later. | ||||
| | #13 | ||||
| Re: Help with sonotubes nothing wrong with a Kia Rio. also nothing wrong with my one end cap non-flared sonos. | ||||
| | #14 | ||||
| Re: Help with sonotubes I agree with Steve, when I built mine I skipped the 3rd inner layer and when I was assembling it I wished I took the time to cut 2 more inner layers of MDF. One for top and bottom, I don't have any leakage but it would have made a much better fit. Don't be afraid to ask questions we have a great bunch around here! | ||||
| | #15 | ||||
| Re: Help with sonotubes I wanna be making them the best I can the first time. So I'll be using 3 layers of mdf. I'm a perfectionist. I've been so busy and haven't gotten any time to get started on these. Will probably be picking up mdf this weekend. Twin size mattress foam from walmart to line the inside? Anyone know what kind of mattress pad or foam it is that ppl are using Posted via Mobile Device | ||||
| | #16 | ||||||
| | #18 | ||||
| Re: Help with sonotubes Is a kit like this needed? http://www.creativesound.ca/details.php?model=WOOFERKIT Posted via Mobile Device | ||||
| | #19 | ||||
| Re: Help with sonotubes Oh and I stumbled on this to, thinking that's alittle expensive http://www.creativesound.ca/details....h%20Insulation Posted via Mobile Device | ||||
| | #20 | ||||
| Re: Help with sonotubes So let me get my cuts right. Anyone know what the hole size had to be for the Mach 5 18.2? I think it's gotta be 16 11/16" but I'd like to know for sure. Also when I cut my 8" port hole, the two inner mdf gotta be cut the thickness of the sonotube bigger? Posted via Mobile Device | ||||
| | #21 | ||||
| Re: Help with sonotubes One last question before I go to bed. Lol. So I need to cut 6x25" and 8x24" circles for 2 sonotubes. How many sheets of 4x8 mdf do I need? If sheets are 4' wide. Is it possible to get 2-24" circles side by side? These may sound like silly qestions but I wanna get it right the first time. And I appreciatte all your help. Posted via Mobile Device | ||||
| | #22 | ||||
| Re: Help with sonotubes I wouldn't make any cuts until you have the driver and sonotube for port in hand, just to be sure. As for lining the subwoofer interior, no need to go any more expensive than a single roll of fiberglass batting or poly batting. | ||||
| | #23 | ||||
| Re: Help with sonotubes The subwoofer mounting kit is a good value for the price as long as the bolts are long enough for your design. Trying to get 2-24" circles side by side on 48" wide MDF is going to be tricky, it will depend on what you're cutting then circles with and allowing for the the blade thickness. +1 to what Steve said, wait until you have the driver and sonotube for port in hand, just to be sure. | ||||
| | #24 | ||||
| Re: Help with sonotubes Ah, well, now that's a totally different story. Triple up your end caps and all that good stuff. Don't forget to paint them several times so they look nice and pretty ![]() | ||||
| | #25 | |||||
Good luck with your build....I'll be waiting for pictures. | |||||
