| DIY Subwoofers sonosub softwareDiscuss sonosub software in the DIY Speakers and Subwoofers forum; sonosub software i found this while doing some research don't know if it will help or if anyone has already saw it.
| | #1 (Link) | |||
| sonosub software i found this while doing some research don't know if it will help or if anyone has already saw it. http://www.users.bigpond.com/bcolliso/sonosub.htm i'm not sure if i typed it correctly, i will fix if not. | |||
| | #7 (Link) | |||
| Re: sonosub software Hi there Scott, the calculator won't let you work out what is the best driver. You need to use a design package such as WinISD or Unibox to do that. Sonosub only uses the physical dimensions of the driver to work out volumes and clearances. It comes with some of the popular drivers included, but you can add your own if it's not on the list. If you don't know the dimensions yet, you can use the built in generic sizes regards Collo | |||
| | #9 (Link) | |||
| Re: sonosub software The fs is the value for the driver. The calculator uses the same formula that is available on the parts express website. There was a more detailed formula published by Adire Audio a while back, which required more information to be entered. When I compared the results between the two formulas, they were almost the same, so I stuck with the more simple one. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Designing a sub... software, etc. | Boris Yeltsin | DIY Subwoofers | 4 | 03-01-08 02:19 PM |
| Starting to build sonosub for my Ficaraudio Q15 | soloxp | Fi Audio | 8 | 09-17-07 08:44 AM |
| Budget "Stubby" Sonosub | BoomieMCT | DIY Subwoofers - Sealed and Ported | 9 | 05-04-07 03:56 PM |
| Double check sonosub info | rhino2 | DIY Subwoofers - Sealed and Ported | 5 | 12-11-06 12:55 PM |
| DIY software | Exocer | DIY Speakers | 40 | 06-13-06 07:33 PM |
