Building a pr of Hometheater subs - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Building a pr of Hometheater subs in the DIY Speakers and Subwoofers forum; Building a pr of Hometheater subs Hello all, I am in the process of building a pair of 10 inch subwoofers from JL Audio 10W6v2-D4 (400 ...
Old 02-05-07, 02:10 PM   #1 (Link)
Alias: Lammy
Loc: Ontario, Canada
User: #5969
Since: Jan 2007
Lammy is offline
Hello all,
I am in the process of building a pair of 10 inch subwoofers from JL Audio 10W6v2-D4 (400 watts) for my hometheater. I was advised by the JL Audio retailer that these drivers will be fine for application as long as the receiver can handle/accept the relevant ohms of 4 ohms(paralell) or 8 ohms(series). Building the box will be a snap as I am an avid woodworker. But my questions are
A) Can I use these drivers for my intended design and if so do I need any other products for it to play efficiently.
B) If I build a powered box with the same driver are there any recommendations or subwoofer amps that you can recommend that these bad boys can handle.
Thanks for all the feedback
Lammy
Old 02-05-07, 07:53 PM   #2 (Link)
Alias: Scott
Loc: Palmer, Alaska
kano32's Avatar
User: #2576
Since: Sep 2006
kano32 is offline
Re: Building a pr of Hometheater subs
Box size, sealed or ported?
Old 02-05-07, 09:55 PM   #3 (Link)
Alias: Lammy
User: #5969
Since: Jan 2007
Lammy is offline
The box size will be
W - H - D
13.25 x 13 x 11
Sealed
This box will be built from 1 inch MDF
as will be the bracing
Thanks for the reply
Old 02-06-07, 01:57 AM   #4 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is online now
hey lammy,
I think you need an external amp for these subs (the receiver can't power these guys)
I think an external amp is better than a plate amp (box will be easier to build)
many people use the Behringer EP2500 for their subwoofers
last question: where in toronto did you get the JL Audio's? how much? who's the dealer over there? (interested to get some for myself)
Old 02-06-07, 06:33 AM   #5 (Link)
Alias: Lammy
User: #5969
Since: Jan 2007
Lammy is offline
Thanks for the info, I was checking out the power amps - do you know of any other power amps that would be able to feed these drivers...I take it the type of drivers for this project is usable. I was looking to get the amps in Canada as it would cost abit to prob clear custom... Any ideas?
I found all the authorized dealers on JLAudio site - the link is attached
www.gemsen.com/jlaudiodealers/[/url]
Thanks again
Old 02-06-07, 07:04 AM   #6 (Link)
Alias: Lammy
User: #5969
Since: Jan 2007
Lammy is offline
This guy (Chase -owner) gave me the best price of all the others I spk to......
Chase Custom Car Audio
777 Warden Ave # 11
Toronto / Scarborough
Ontario
M1L 4C3
416 750-4434
Old 02-06-07, 08:40 AM   #7 (Link)
Alias: Aaron
Loc: Albuquerque, NM
JorgenMan's Avatar
User: #2040
Since: Aug 2006
JorgenMan is offline
I think a Nady XA-900 would give you enough power if you ran the voice coils in parallel (400 W/channel @ 2 ohms), and it's about half the price of the EP2500. If you got the EP2500, you'd want to run the voice coils in series - the EP2500 does 500 W/channel @ 8 ohms.
My meager HT
It's like, how much more black could this be? And the answer is none. None more black.
Old 02-06-07, 02:40 PM   #8 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Brian Bunge is offline
How exactly are you talking about running the drivers? With dual 4 ohm voice coils you can run each driver either at 2 ohms or 8 ohms. If you are going to run both drivers off of a single amp channel then you can run them as a single 4 ohm load with a series/parallel wiring configuration.
Brian Bunge
Old 02-06-07, 08:17 PM   #9 (Link)
Alias: Lammy
User: #5969
Since: Jan 2007
Lammy is offline
@ JorgenMan - The Nady XA 900 looks good but I am going to ask my bro' to pick up the EP2500 as the power availability is giving me the option to chng the sub size based on it power output.
@ Brian Bunge - I am looking to run these drivers at 8 ohms - 500 watts for each channel. I want to have a left and right sub setup for my HT - with that in mind are there any other recommendations that I can go with to the same or better effect with the same products mentioned(drivers and amps)
Thanks inadvance
Old 02-07-07, 09:34 AM   #10 (Link)
Alias: Aaron
JorgenMan's Avatar
User: #2040
Since: Aug 2006
Lammy wrote: View Post
Sounds like a good plan to me.
I'm not quite sure what you're asking here, could you be more specific?
My meager HT
Old 02-07-07, 11:16 AM   #11 (Link)
Alias: Lammy
User: #5969
Since: Jan 2007
Lammy is offline
what I meant was - with the 8 ohm setup I am going with, do you think it will yield an excellent sound quality as opposed to the recommendation of the 2 ohms series/paralell or even with the 4 ohms config...Now that I am thinking about it - it should be pretty much the same - but is it more work for the amp or is it the same regardless of the setup....
Thanks again
Old 02-07-07, 11:40 AM   #12 (Link)
Alias: Aaron
JorgenMan's Avatar
User: #2040
Since: Aug 2006
The 8-ohm load is easier for the amplifier to drive, so it will give a cleaner signal than to a 4- or 2-ohm load (while not delivering as much power). How much "cleaner" will it sound? I don't know, really. For a subwoofer amplifier, I'm not sure it makes too much of a difference.
My meager HT
Old 02-07-07, 10:52 PM   #13 (Link)
Alias: Lammy
User: #5969
Since: Jan 2007
Lammy is offline
Thanks for all the feedback, I can't believe I did not find this site out sooner - but now I know they are right when they say "better late than never" - my next step is to get all the materials and knock this project out - I will be sure to post the progress and pics when I start until finish - to be continued,
Old 02-08-07, 08:26 AM   #14 (Link)
Alias: Aaron
JorgenMan's Avatar
User: #2040
Since: Aug 2006
We look forward to it. Be sure to post any questions, and we'll try to help as much as we can. Good luck!
My meager HT
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
