| DIY Subwoofers My Box DesignDiscuss My Box Design in the DIY Speakers and Subwoofers forum; My Box Design Have finally finished the design for my sub box. However could only get 16mm thick MDF, should I glue some ... |
| | #1 (Link) | |||
| My Box Design Have finally finished the design for my sub box. However could only get 16mm thick MDF, should I glue some sheets together to get a thicker piece (25mm???). Will make sure I get some pics of the building of the box when i get around to it. D. | |||
| | #4 (Link) | |||
| Re: My Box Design If you are able to locate a presentable plywood with a good veneer you can try gluing the plywood on top of the MDF. I've seen a few projects around that employ that technique ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #5 (Link) | |||
| Re: My Box Design Danny .. Why are you using mdf? It's the worst material for sub boxes. It's heavy and needs to be braced like crazy. Sure it machines well. If because it's cheap, fine, but assuming you spent big dollars on speakers and other equipment but won't spend $40 on some good ply. The rationale for mdf staggers me. "Gee, Hon I just spent $3000 on this preamp, what an incredible bargain". Zene dba Zene | |||
| | #6 (Link) | |||
| Re: My Box Design You may not like MDF for sub boxes, but I wouldn't throw the word "worst" around so casually. There are a LOT of people who use MDF with good results. In fact, I don't think it's a big stretch to assume that it's the most popular material for building boxes. | |||
| | #7 (Link) | |||
| Re: My Box Design I would agree with Jorgenman. MDF is the most widely used material for speakers and subs. Even expensive commercial brands use MDF. Of course there are exceptions, sonotubes, translam etc. People should use good ply or mdf or a mixture of both. Most large sub enclosures are going to have to be braced whether its ply or mdf. Anyway, just my 2 cents. | |||
| | #8 (Link) | |||
| Re: My Box Design Aaron/others .... I guess I should not have said worse, just one of a long list of worse. Its used because it's cheap and handy. Popularity does not make it good. A little engineering search will tell you that you need stiff to control bass. MDF is far from stiff. Once a heavy structure gets moving it obviously wants to keep moving as you know. Yes, bracing can help, but then again adds more mass. Not many want to put a lot of effort into an important component like the box. Too many think its just a shiny receptacle of the right size to house the speaker. Zene | |||
| | #9 (Link) | ||||
| Re: My Box Design Quote:
![]() ![]() MBoutte south Louisiana ![]() 2x15" TC Sounds .45Q sealed M. Boutte HT 3x15" @ 10 Hz "...peace? love?...illusions Mr. Anderson...vagaries of perception..." Last edited by kramskoi; 02-17-07 at 11:21 PM. Reason: added picture | ||||
| | #10 (Link) | |||
| Re: My Box Design Been there, done that and more. How about 60 lb density MDF 2 layers thick and bracing or two layers of 1/2" mdf with 3" of cardboard edgewise filled 100%? Concrete filled with mdf walls .... etc, etc. That said, where does it say it sounds better than ply? Dead is no guarantee it is better. All boxes "talk" and primary is to make whatever vibrations it has complimentary to our hearing. Wharfedale sand filled panels went out with Disco. Zene | |||
| | #11 (Link) | ||||
with mounting depths of 10-14" and opposite side firing drivers (which weigh over 45 lbs. each), you become limited in what you can realistically achieve with weight and expenditure...in my case, a 200 lb+ enclosure at about $400, which is quite difficult to service if problems arise...but from end to end, only 2 1/4" separates each of the (7).75" braces, right up to the front baffles on each side...i'm extremely satisfied with the results, same as the second box i had built with a 3.5" front baffle and four internal braces... MBoutte south Louisiana ![]() 2x15" TC Sounds .45Q sealed M. Boutte HT 3x15" @ 10 Hz "...peace? love?...illusions Mr. Anderson...vagaries of perception..." | ||||
| | #12 (Link) | |||
| Re: My Box Design If your drivers are mounted on opposite ends/sides of the enclosure then all of that bracing is overkill, IMHO. A couple of braces is plenty as the mechanical forces are canceled out by opposing drivers. With the quad 15" cabinet I just finished you can balance a nickel on edge placed on top of the cabinet while playing at high SPL's and the nickel doesn't fall over. There are only 3 braces in the cabinet. Brian Bunge | |||
| | #13 (Link) | ||||
...more has to be better right?![]() MBoutte south Louisiana ![]() 2x15" TC Sounds .45Q sealed M. Boutte HT 3x15" @ 10 Hz "...peace? love?...illusions Mr. Anderson...vagaries of perception..." | ||||
| | #15 (Link) | |||
| Re: My Box Design sorry, i just designed the box...a local audio store did the building...i'm pretty sure the builder used some high end equipment...they build a ton of boxes... MBoutte south Louisiana ![]() 2x15" TC Sounds .45Q sealed M. Boutte HT 3x15" @ 10 Hz "...peace? love?...illusions Mr. Anderson...vagaries of perception..." | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| dual box setup | mike c | SVSound | 14 | 05-25-07 04:38 PM |
| Cylinder vs. Box | nova | SVSound | 8 | 02-18-07 05:20 AM |
| Sonotube vs Box | letzleta | DIY Subwoofers - Sealed and Ported | 34 | 02-05-07 02:32 PM |
| Calibration file AND c-weighted box? | cnjvh | REW Forum | 2 | 01-31-07 10:26 PM |
| Guide to Sub box Design | Danny | DIY Subwoofers | 12 | 05-13-06 10:48 AM |
