DIY Subwoofers
Quieter Fan Mod for Behringer EP2500
Discuss Quieter Fan Mod for Behringer EP2500 in the DIY Speakers and Subwoofers forum; Quieter Fan Mod for Behringer EP2500 Interesting idea... Ill give it a try if my rti12s overwork the amp... (unlikely)....
Views: 20144 - Replies: 147
Old 03-06-07, 11:19 AM   #26
Alias: bob
bob1029's Avatar
Loc: Houston, TX
User: #7011
  bob1029 is offline
Re: Quieter fan mod for Behringer EP2500
Old 03-07-07, 11:19 AM   #27
Alias: brucek
User: #6
  brucek is online now
Ok, i did the fan mod as well using the fan out of a computer psu. These fans are traditionally extremely quiet so i figured it would be a good place to start. The fan fit perfectly in place of the original fan, so no ninja rigging was required. I also used 2x 390 ohm resistors in parallel to make 195 ohms placed in-line with the (+) wire to the fan. The reason for running them in parallel is because they are smaller and i needed to get more to handle the heat dissipation.
But aren't computer fans 12 volts? The supply for the fan in your EP2500 is 24 volts? So, you would be at least dropping 12 volts across the 190 ohm resistors? That would dissipate about 3/4 watts steady state. So, two 1/2 watt resistors would be fine in a passive circuit, but a fan is a variable current device depending on its load.
Start up current requirements, or if the fan fails to start would place much more than 12 volts across your resistors. Start up or stall load of a DC fan is at least twice the steady state requirement. Hopefully you've spec'd the resistors wattage to accomodate this added dissipation requirement? Stop the fan with your hand and put your fingers on the resistors for a while and see if they are about to burn up......
Old 04-10-07, 09:59 PM   #28
Alias: Dan
Loc: Chesapeake, VA
User: #7007
  bigguy is offline
New information on Fan Acquisition...
Digikey.com had a wait time for ship till 10 May which eludes to "none in stock"...
After some research I found them at www.newark.com
under the part number
NMB FBA08A24L1A which is also the part number of the manufacturer.
Price was 8.71usd each and there are many in stock.
Hope this help anyone looking
Thanks
Dan
Old 04-10-07, 10:01 PM   #29
Alias: Dan
Loc: Chesapeake, VA
User: #7007
  bigguy is offline
bigguy wrote: View Post
My bad... 7.75 each... what was I thinking
Old 04-10-07, 10:04 PM   #30
Alias: Dan
Loc: Chesapeake, VA
User: #7007
  bigguy is offline
Part Number 31K9990 at www.newark.com
There Sorry for the errors... I was looking at the wrong display when I grabbed the information... too many computers at one desk... 5 computers and 4 screens... bet you cant guess what I do for a living...?
Old 04-15-07, 09:36 PM   #31
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
  ccdoggy is offline
I just bought from Newark as per bigguy's suggestion (thanks!) and it came to like $14 after shipping (2 day ground). cant wait to get it installed.
Old 04-22-07, 07:40 PM   #32
Alias: Dan
Loc: Chesapeake, VA
User: #7007
  bigguy is offline
Howdy Folks,
I finally got the fan and did the mod... there was a pre/post test and I can say that the new fan was significantly quieter... (cant really hear it running) but you can feel it out of the front of the amp... Nice.
The mod was simple however, those of you buying a Behringer now a days will have some sort of tamper proof "hot glue" on the connector so you cannot do this mod without voiding the warranty. I just cut the wire at the old fan and soldered/heatshrinked it to the new fan. I dont really care about the warranty as I got mine at a good price and suspect it will last a while. (besides I do my own repair work )
This was definitely something in the "win" category.
Thanks
Dan
Old 04-23-07, 12:20 AM   #33
Alias: Steve
User: #5693
Since: Jan 2007
  ccdoggy is offline
Thats exactly how i feel. i also just cut the wire and shrinked it to be safe.
It works great! however i did notice after along time of use, aka i was listening to rock for about an hour at pretty good volumes its does get pretty warm, almost on the verge of hot. however i am not worried as that temp should not actually happen in any reasonable volume level or movie use.
Old 05-01-07, 03:24 PM   #34
Alias: Michael
buggers's Avatar
Loc: Chesapeake Virginia
User: #3685
Since: Nov 2006
  buggers is offline
Hey Dan what's up?
Michael.
Old 05-15-07, 06:51 PM   #35
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
MOD REQUEST: On/Off switch for Behringer EP2500 fan...
I just got a EP2500 a few weeks ago. The fan is audible but not to the extent that some people say. About as loud as a Xbox or something like it. Not bad, not good for movie viewing but not too bad.
I don't want to go and find a "quieter" fan for it. I'd rather have the option of having it on or off, instead. Especially when watching a dvd I'd like to just turn it off. Even the most ridiculous movies won't heat up a beast like this too much. (I am speaking from others experience's with the Europower amps.) Now for music or some seriously loud video gaming, I'd like to turn the fan on.
Is this an easy process? I don't want anything fancy. I wouldn't mind having a little wire or something out the back with a toggle for the fan. Dunno what would really work or if your need a special switch for it.
Any idea?
Old 05-15-07, 10:49 PM   #36
Alias: Steve
User: #5693
Since: Jan 2007
  ccdoggy is offline
I wouldent do it. it will heat up with just normal use, with no movement of air it will take allot longer to cool and will only heat up more and more.
Just replace the stock one with the one suggested and you will not have to worry about it at all. it is about the same difficulty to do a switch and with the replaced fan you would never need to even think about it.
Old 05-15-07, 11:00 PM   #37
Alias: Dan
Loc: Australia
User: #359
  Danny is offline
And also with a switch you may forget to switch it on when working it hard. But I also agree with Steve in regards to it heating up too much even under low usage. With no air moving through you will likely damage the electronics.
Old 05-18-07, 03:07 PM   #38
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
The power transistors are bonded to the tubular aluminium heatsink. Without a draught through the middle the heatsink will eventually get hot. There is nowhere for the heat to go. It can't conduct, can't radiate and it can't convect in a closed box. Even with a very quiet fan like mine the heat is safely removed to the outside of the box.
Try placing the external sensor of an ordinary (cheap) indoors/outdoors digital thermometer on your heat sink with the fan disconnected. Then play some heavy rock music like Metallica. I found the Black Album at a steady 100dB+ the most serious test of cooling so far.
Old 05-18-07, 03:28 PM   #39
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
After reading all your comments I have decided to not to that. Heh. I figured it would be okay for to watch one movie with it off but I guess not.
Good thing I got paid today. I can purchase my materials for a dual RLp18 LLT I am building and I'll order a quiet fan.
Thanks!
Old 05-18-07, 05:14 PM   #40
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Scott S wrote: View Post
Don't forget you need a 24 Volt fan.
Twin 18s eh?
Old 05-18-07, 07:27 PM   #41
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
Yep!
Here's the build thread: http://www.avsforum.com/avs-vb/showthread.php?t=845994
Old 05-19-07, 03:20 AM   #42
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Some serious woofage! Should be fun.
I feel sorry for those who aren't even allowed a 1cuft box sub in their living room.
Old 05-19-07, 11:49 AM   #43
BassMaster
Inactive
Alias:
User: #
Posts: n/a
what about this crazy idea
Why not take take the top off the fanduct?
so the heat can go straight up
of course you have too cut some extra holes in the top cover
but at least its silent then
Old 05-19-07, 12:05 PM   #44
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
BassMaster wrote: View Post
The top cover is already in close contact and screwed to the heatsink.
Limited conduction will take place but I can't recommend this as the only means of cooling.
A tall chimney would be a better idea than drilling holes in the top plate of your amp. Not only would this drilling invalidate the guarantee but will make the amp dangerous to children probing your new ventilation holes. Unless you were very careful it will probably be so ugly you could never sell the amp if you needed to.
Old 05-20-07, 06:59 PM   #45
Alias: vitod
vitod's Avatar
Loc: Pocono PA
User: #1968
Since: Aug 2006
  vitod is offline
This fan mod is very much worth it. Took 10 mins and reduced the fan noise dramatically!
Old 07-20-07, 01:56 PM   #46
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
Ordered that fan from Newark earlier this week. Woke up today and found it next to my door. Looks like Ill be installing it tonight or sometime this weekend.
Should be pretty sweet...erm, well....quiet.
Old 07-23-07, 07:43 PM   #47
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
Got my fan installed this weekend. Totally worth the upgrade! So glad I did it.
Old 08-01-07, 07:25 AM   #48
kesa32
Inactive
Alias:
User: #
Posts: n/a
Hi, l've got a electronics mate installing a thermal switch in my ep2500 tommorow to turn the fan on&off .......it is adjustable too , so we'll start with 35 degrees celcius and go from there, if this does'nt do what l want l'll hunt up an even quiter fan as the one l got isnt quite enough for me.
l'll get some pics happening of the instal too
Ken
Old 08-01-07, 08:56 PM   #49
Alias: zac
Loc: stockton, ca
User: #7728
Since: Mar 2007
  zacjones is offline
just ordered mine too. thanks chrisbee and y'all!
Old 08-16-07, 03:28 PM   #50
Iggster1986
Inactive
Alias:
User: #
Posts: n/a
I have the ep 2500 and its a little loud but IMO my ps3 is louder.. So i can live with the little noise it produces. I have heard of people just disconnecting their fan from other pro audio amps, but I wouldn't recommend it.
