| DIY Subwoofers Behringer A500Discuss Behringer A500 in the DIY Speakers and Subwoofers forum; Behringer A500 Well, I am thinking about getting one of these from the B-stock over at Audiolines, to have 500 watts on ... |
| | #1 (Link) | |||
| Behringer A500 Well, I am thinking about getting one of these from the B-stock over at Audiolines, to have 500 watts on an 8ohm load, but I figured I should post here to see if anyone was using one to power their subs, and to see how it was. Go. | |||
| | #2 (Link) | |||
| Re: Behringer A500 I use one on my pair of 12" shiva sonosubs (1 channel per sub, 4ohms load per channel), I've had no problems with it. I'm set up in a small room, if I was in a large room I would probably want more power. At my normal listening level I often light up the light just before the clipping indicator. I do like it very loud though. | |||
| | #9 (Link) | |||
| Re: Behringer A500 Judging by the specs, I don't think so. Behringer only lists an 8 Ohm load for bridged. I'm considering getting a pre/pro next year as well as 3 A500's. One channel for each main, center and surround. 230 watts into each 4 Ohm load. | |||
| | #13 (Link) | ||||
| Re: Behringer A500 Quote:
So I'll order one this week. | ||||
| | #14 (Link) | |||
| Re: Behringer A500 Here's a great review of the A500 http://theaudiocritic.com/blog/index...Id=20&blogId=1 It shows the actual power outputs - nice write up... | |||
| | #15 (Link) | |||
| Re: Behringer A500 When an amp is bridged, the load seen by each channel is half that of the speaker being driven. This means that if you wish to bridge an amp (any amp) you need the speaker impedance to be twice that of the recommended minimum load for an individual channel. therefore if the minimum speaker load for the A500 is 4 ohms per channel, then when bridged the smallest load you can use will be 8 ohms. Sorry if I am teaching people to suck eggs, but if someone is browsing this thread for info on amp bridging I thought an explanation of why would be good. Dr F "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | |||
| | #16 (Link) | |||
| Re: Behringer A500 I am running an A500 to two Subs. I was just trying it out to begin with, but it works great in my setup so I kept it. I sit about 10ft away from both non-co located subs in a 14ft deep room, and have never had it clip or act up running at -10dB (105Db Peaks). The subs are both RS HiFi 15's in 325L each, so I don't need a lot of power in my sub setup. My Arvo mains would clip the amp though. Dual or bridged. As long as 150-180w are all you really need, it will do fine. Hope this helps. | |||
| | #17 (Link) | ||||
It sort of confuses me because clipping is caused by the level of the input signal not the speaker attached. "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | ||||
| | #18 (Link) | ||||
A more power hungry speaker clips the amp because it can never get enough. I think you could also do the same by continuing to drop impedance, thought that might be somewhat different as it may require more current, rather than voltage. I could be off, but that's what I'm thinking... -- Otto | ||||
| | #19 (Link) | ||||
In this instance we are talking about the amp clipping. Anytime a speaker tries to pull more from the amp than it can provide the amp will clip. Be it current, voltage, impedance swing, phase angle, whatever in any combination. This can happen way before the input signal becomes clipped further up the chain. As Otto mentioned, since we are talking about a standard sub application sensitivity and impedance swings are the main things to be aware of here. That is why I listed my drivers, listening area, and enclosure size. To give everyone an idea of the load I was presenting the amp. | ||||
| | #20 (Link) | |||
| Re: Behringer A500 Ahh, I see the confusion. If a may convert the lingo to laymens terms. Becasue your speakers aren't that efficient you have to push the output stage of the amp harder to get the same SPL, thus causing clipping. I was confused because the way I read your post was that the speaker was causing the clipping, not the driving signal level to compensate for the speakers. "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Behringer CX2310 Crossover | Sonnie | Classifieds - Equalization and Calibration Equipment | 2 | 12-01-07 10:23 PM |
| Behringer CX2310 | mike c | Home Theater Components | 11 | 03-08-07 05:35 PM |
