| DIY Subwoofers Sub box build - Attn all acoustically giftedDiscuss Sub box build - Attn all acoustically gifted in the DIY Speakers and Subwoofers forum; Sub box build - Attn all acoustically gifted Hi everyone
I'm building my sub box this weekend and will probably join two 16mm MDF sheets together to make ... |
| | #1 (Link) | |||
| Sub box build - Attn all acoustically gifted Hi everyone I'm building my sub box this weekend and will probably join two 16mm MDF sheets together to make one 32mm thick sheet. I was wondering if this is alright to do and how it will affect the sound. Thanks Dan | |||
| | #2 (Link) | |||
| Re: Sun box build - Attn all acoustically gifted I would think if you just used some liquid nails and maybe even some real nails (finishing nailer) just to provide some shear strength it would be fine. Would the whole thing be made up of joined together pieces or just the front? | |||
| | #3 (Link) | |||
| Re: Sun box build - Attn all acoustically gifted I was just going to use PVC glue. There will probably be some nails/screws in it where the sheets join. I'm making the whole thing out of joined up sheets, unfortunately when I went to the hardware store they only had 16mm thick stuff. Hmm just noticed that I can't spell Sub :-) | |||
| | #4 (Link) | |||
| Re: Sun box build - Attn all acoustically gifted I've used PVA glue in the past for front panels, IB boxes etc without any trouble. You can use a flat peice of scrap as a spreader to make sure both surfaces are completely covered without using a ton of glue. Screws are optional - a couple of clamps to hold the two peices in alignment and then plenty of house bricks for weight will do the trick! | |||
| | #5 (Link) | |||
| Re: Sub box build - Attn all acoustically gifted Joining the two together should be fine. Its important to remember not to use a glue that expands as it dries.Regular ol' elmers wood glue is known for its non-expanding method of drying. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Looking to build a sub to end all.... | thxgoon | DIY Subwoofers | 83 | 11-01-07 04:38 PM |
| Advise on Heat Build up inside TV .... | salvasol | Video Displays and Processors | 3 | 03-21-07 06:02 PM |
| custom build/design | scott | Home Theater Design and Construction | 0 | 01-21-07 11:22 AM |
| Want to build music sub | Tracy_L | DIY Subwoofers | 17 | 12-19-06 03:19 PM |
| Why You Must Acoustically Treat Your Hi-Fi Room | geekwithfamily | Home Theater, Audio and Video News | 0 | 09-14-06 03:40 PM |
