EP-2500 problem, not loud enough - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss EP-2500 problem, not loud enough in the DIY Speakers and Subwoofers forum; EP-2500 problem, not loud enough So i just recieved a used EP-2500 from someone on ebay. looks in perfect condition and performs just fine except ...
Old 03-28-07, 04:08 PM   #1 (Link)
Alias: Steve
Loc: Shoreview Minnesota
User: #5693
Since: Jan 2007
ccdoggy is offline
So i just recieved a used EP-2500 from someone on ebay. looks in perfect condition and performs just fine except for the fact that it is not loud at all.
I have it hooked into two subs, a 8" 4Ohm sub (ported), and my FI Audio Q, wired to a 2Ohm load (not in a box but just thought i would try).
I hooked it into my Arcam AVR300 via the sub out port. I have both knobs cranked and both subs connected (to their own channel) and i get some bass. not nearly as much as i want. It seems as though the amp is not getting enough voltage and thus i need to boost it all the way at the amp and in the arcam setup menu i set the sub to +10db.
Is my arcam not outputting enough voltage to get the output in power i want? or is there some sort of adjustment inside of the amp that i can turn it up with? How do i get this setup to work?
Thanks for the help!
Edit: Looks like my Arcam outputs 2Vrms at 0db gain on the analog outputs, which is what i have the sub hooked into, the analog Sub output.
Old 03-28-07, 05:03 PM   #2 (Link)
Alias: Collo
Loc: Newcastle, Australia
User: #5027
Since: Dec 2006
collo is offline
Re: EP-2500 problem, not loud enough
The EP2500 can work with either a -10dB setting or a +4dB setting.
You may find that it's set to +4dB as normally used in "pro" environments. For driving from an AV amp, you'll want to move to the -10dB setting
This is done with the DIP switches on the back of the amp. Follow the painted instructions on the back panel. Ignore the markings on the switchblock itself
If you know for certain that the amp is OK, and your signal is still too low, even on the -10dB setting, you'll need a level shifter, such as the Art Cleanbox It also handles the RCA to XLR conversion for you.
Note that there's also a Cleanbox II, which is just used for stopping earth loops. That's not the one you want.
Old 03-28-07, 05:14 PM   #3 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
I had exactly the same problem with low output from my stereo preamp into the EP2500.
So I just boosted the input to my EP2500 by around 6dB using my CX2310 active crossover.
The twin attenuator knobs on the EP2500 are both fully clockwise.
(They aren't volume controls even though they seem to behave rather like volume controls)
Double check the DIP switches on the back aren't set for low pass filters or any other unwanted facilities. (like bridging)
Old 03-28-07, 05:36 PM   #4 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
i can get some good volume out of it if i really crank it up.
Would the Feedback Destroyer Pro also allow me to boost the signal?
Eventually i wanna EQ my room and what not. I know that most have the problem connecting to REW, how hard is it to manually do it? test with REW and then add the filters manually?
Thanks for the help, i got worried for a bit there that it would be something i couldent fix.
Old 03-28-07, 05:38 PM   #5 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
collo wrote: View Post
What you mean by that? where do i select this +4 or -10 setting?
Old 03-28-07, 07:06 PM   #6 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is online now
You cant change the input sensitivity on the EP series amps. Not with the dip switches or any other thing on the amp. The EP1500 needs +3.4dBu and the EP2500 needs +4dBu to use full power. If your receiver does not have the voltage to match that than your going to need to get a Cleanbox. It will boost the signal to a +4dBu and give you the full voltage needed to drive your proamp to full power. BTW Im also using a Cleanbox to drive my EP1500 from an Onkyo 600 receiver with great results.
Old 03-28-07, 07:14 PM   #7 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
on the back of the Behringer Feedback Destroyer Pro DSP1124P it looks like it has a -10 +4db button on the back of it. Would this unit do what i want as i figure just one box is better then two. also if it can EQ and can boost the signal then its what i need.
Anyone know if it can do both?
Old 03-28-07, 09:19 PM   #8 (Link)
Alias: brucek
User: #6
brucek is online now
No, those switches are for operating level, not gain. The BFD is a unity gain device.
Those are extremely low levels for a PRO amp. Likely Behringer does this to satisfy most retail and PRO equipment. PRO inputs would just dial down the input attenuator. Generally receivers will output 1 to 2 voltsRMS and should be able to drive an amp that has a max input of +4dBu. That's only ~1.25voltsRMS.
Old 03-28-07, 10:17 PM   #9 (Link)
Alias: Collo
User: #5027
Since: Dec 2006
collo is offline
My apologies
I was getting the EP2500 mixed up with the BFD.
The switches for +4dB / -10dB are on the BFD, not the amp.
I run my AV into the BFD (-10dB setting) and then onto an EP2500. The level is high enough for the yellow and red LEDs on the BFD to flicker.
sorry for the confusion
Collo
Old 03-28-07, 10:44 PM   #10 (Link)
Loc: Lower Alabama
Sonnie is offline
Make sure you don't have the hi-pass filter dip switches set wrong. As Collo stated, don't follow the OFF/ON above the dip switches, rather follow the labeling. If I'm remembering correctly... "OFF" on above the dip switches is actually "ON". It that is set to 50Hz then it could easily cause you to think you have no bass.
Sonnie
Old 03-28-07, 10:47 PM   #11 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
So i think i have come to the conclusion that the bass is there and strong, but with the knobs turned all the way up (atleast music wise). which i dont like as i like to continuously vary my bass settings. so that i can turn the sub up and show it off a bit without having to turn the mains up that loud.
what do i need? the clean box looks like it would do it.
Edit: well i tested a movie and was disappointed. definetly needs to output more power.
Old 03-29-07, 07:49 AM   #12 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
ccdoggy wrote: View Post
Yes what you need is voltage gain -- not power. The ART Cleanbox is a very good solution. I use one between my cheapie Panasonic HE70 AVR and a Mackie M1400 pro amp that drives my subwoofer.
Old 03-29-07, 11:18 AM   #13 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
Sweet, thanks for the info.
one last question, on the cleanbox see that it is listed that the input rca is -10db and the XLR on the other side is +4db. will the signal be changed just by that change of "standards" so it would be +14db louder then it is now?
Thanks.
Old 03-29-07, 11:47 AM   #14 (Link)
Tech'y Shackster
Alias: Bob
User: #25
bobgpsr is offline
In general yes but there is also a dBV versus dBu conversion going on from consumer level -10 dBV to pro audio level +4 dBu. The Cleanbox actually has a gain control on it. Mine is set about halfway.
Old 03-29-07, 12:53 PM   #15 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
Thanks!
one final thing, when i get a cable to hook the cleanbox up to my ep2500 is it a standard XLR male on one end and XLR female on the other? I just have not seen any pics of the XLR side of the box to gauge exactly what i need.
my EP 2500 has a female input xlr.
Thanks again!
Old 03-29-07, 01:51 PM   #16 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
I just bought these to hook my cleanbox to the BFD and Ep1500. Your going to need 2 to hook all three together. These are short but, if you have them stacked on top of each other than there going to be long enuff.
http://www.accessories4less.com/cgi-bin/item/MCM550IX
This package is 2 XLR cables (all you need)
Old 03-29-07, 02:00 PM   #17 (Link)
Alias: Steve
User: #5693
Since: Jan 2007
ccdoggy is offline
Thanks for the heads up. i appreciate it.
Old 03-29-07, 02:04 PM   #18 (Link)
Alias: brucek
User: #6
That's -10dBV and +4dBu.
That's an 11.8dB voltage gain..........
Similar Threads
JBL home cinema exclusive small but very loud! JBL-4645 Home Theater Gallery 10 04-03-08 01:56 AM
How loud is 80dB?? surrey lad REW Forum 14 08-20-06 04:24 AM
Loud Noises at Night Mark Seaton Home Audio Subwoofers 21 08-06-06 01:46 PM
Mach 5 Audio
