first subwoofer - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
first subwoofer
Discuss first subwoofer in the DIY Speakers and Subwoofers forum; first subwoofer Hello everybody, I've been lurking here for the past few days and other sites over the past few weeks reading ...
Old 03-30-07, 08:20 PM   #1 (Link)
Alias: foam
Loc: Sherwood
User: #7788
Since: Mar 2007
foamfan is offline
first subwoofer
Hello everybody,
I've been lurking here for the past few days and other sites over the past few weeks reading about DIY subwoofers. It seems like DIY has the best bang for the buck and if engineered right they could surpass anything commercially available.
These some of the things relative to my situation:
1. I have a HT which is approx 4500 cubic feet but since I have an open-house plan it has multiple large openings to approx 12-13,000 cubic feet (LR, DR, Kitchen, bedroom and bathroom hallways, etc.). HT is used for 90% DVD/movies & 10% music using only moderate levels.
2. Budget $1000 If possible spend less but using quality components so I dont end-up doing it again for at least 5 years. I've heard the DD18 & JL F113 & am thinking that it would be cool to approach the sound quality of these subs but their prices make me lose bowel control.
3. I would like a small footprint, nothing more than 6.75 cubic feet on external dimensions. I've been communicating with SteveCallas (who has been extremely, extremely generous in helping me) since the LLT probably is the most elegant engineering solution in my mind but it would require a 50" length X 22" diameter according to him and this is just too big for me. Thanks again Steve.
4. I am considering the 15" rythmic kit but am open to suggestions if there is a proven build out there.
I dont have the technical know-how to tune a sub so i'd like something simple where there is NO or very minimal tuning. Carpentry skills are almost non-existent but I'm willing to give it a shot.
5. A twin SoundSplinter RL-p15 D2s w/a Behringer EP2500 amp and a Behringer Feedback destroyer was mentioned by Steve but he suggested seeking other opinions too.
I am looking for a KISS solution to my problem and emphasize sound quality. Please tell me if I am out of my mind since this is not possible for a newb like me to accomplish or fire away with your suggestions.
Thanks
Old 03-30-07, 08:55 PM   #2 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Re: first subwoofer
Hey -
5 reminds me of this: http://www.htguide.com/forum/showthr...5&page=1&pp=35
And this is a neat build too: http://www.htguide.com/forum/showthr...ghlight=rl-p15
Old 03-31-07, 10:21 AM   #3 (Link)
Alias: foam
Loc: Sherwood
User: #7788
Since: Mar 2007
foamfan is offline
Re: first subwoofer
Thanks for those links Willy.
Those were really cool builds and very pretty finish specially on the piano black subs. I'm a newb so i'd like to keep it as simple as possible. The tuning after the build is pretty intimidating for me and "modeling" subs is like a foreign language. I'm doing a search on successful builds, single or dual drivers and reading everything I can about them hopefully gain some insight.
Old 03-31-07, 12:01 PM   #4 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Re: first subwoofer
By "tuning" I believe you mean EQing?
Old 03-31-07, 03:48 PM   #5 (Link)
Alias: foam
Loc: Sherwood
User: #7788
Since: Mar 2007
foamfan is offline
Re: first subwoofer
Yes.
That and making sure that what I build is sonically of good quality
Old 03-31-07, 04:26 PM   #6 (Link)
Loc: Lower Alabama
Re: first subwoofer
Generally required eq'ing is going to be due to your room boundaries and acoustics. I don't think there is a lot you can expect to do in order for the sub to help you a tremendous amount in that area. It might not hurt to take some measurements of your room though, if you have a sub to measure with.
Sonnie
Old 03-31-07, 08:17 PM   #7 (Link)
Alias: foam
Loc: Sherwood
User: #7788
Since: Mar 2007
foamfan is offline
Re: first subwoofer
Sonnie wrote: View Post
I'm willing to do this but need some guidance on what to buy (due to the rapid development of technology and constant turnover and update of equipment) and how to do it correctly.
Is this the same as using REW and then using BFD to compensate for both the room and sonic characteristics of the sub?
Isn't this usually done AFTER you build the sub or can the sub be designed to compensate for the characteristics of the room?
BTW, I have an old 8" sub (really, really old ).
Thanks
Old 04-02-07, 10:46 PM   #8 (Link)
Alias: Brian Bunge
Loc: Palm Bay, FL
User: #63
Brian Bunge is offline
Re: first subwoofer
So far I've built 2 of the quad RS 15" HO subs which are pictured in the second link WillyD posted. Both customers are extremely happy with the results.
Brian Bunge
Old 04-03-07, 11:27 AM   #9 (Link)
Loc: Lower Alabama
Re: first subwoofer
foamfan wrote: View Post
Thanks
You will have lots of friends over in the BFD | REW Forum to help you with using REW and setting up the BFD, if it is even needed. It probably will be, but I've seen a few that don't have to have it, so I'd build the sub and then measure and make sure before spending the money.
It may be hard to tell a lot about the room with respect to frequencies below 25Hz or so with the 8" sub, but it might help some and definitely worth a try. It really just depends on how much it will output in the lower octave.
To start with you will need an SPL meter... do you have one? If not, consider the Galaxy CM-140. I believe Musicians Friend is still selling them for $99 shipped, which is a good price. You can use the GALAXY140.cal file from the Downloads page.
You will also need to download REW and read the Help files thoroughly to learn how to use it. Again, the BFD | REW Forum is your friend...
Sonnie
Similar Threads
New Subwoofer in the works! Brian Bunge DIY Subwoofers 23 04-05-07 03:03 AM
New Subwoofer Technology Robert_Gibran Home Audio Subwoofers 74 10-19-06 07:28 PM
New subwoofer woohoo eddthompson Home Audio Subwoofers 8 09-28-06 04:41 PM
IB Subwoofer Absorbtion Ayreonaut Home Audio Acoustics 4 09-28-06 12:46 PM
subwoofer settings evan BFD Forum 2 04-20-06 08:13 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
