| DIY Subwoofers Box for Tumult 15D2Discuss Box for Tumult 15D2 in the DIY Speakers and Subwoofers forum; Box for Tumult 15D2 Can anyone suggest a box type/size for Tumult 15D2 MK2? 80/20 % movies/music!... |
| | #4 (Link) | |||
| Re: Box for Tumult 15D2 3ft^3 (91Cm ft^3) would be a nice balance between efficiency and power handling. You wouldn't have to worry about exceeding Xmax, which will ensure great sound quality even up to your amplifier's maximum capabilities. ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #5 (Link) | |||
| Re: Box for Tumult 15D2 Going ported is also an option. ![]() Much larger box, but since your listening habits favor HT, why not get some free output down low from a port? ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #6 (Link) | |||
| Re: Box for Tumult 15D2 15 Hz tune with only 250 L can only be achieved either by too small a port diameter (which will lead to port noise and compression well before the shown SPL graph), or by too long a port which would be unpractical to fit!! My opinion is to go for minimum a 18 Hz tune and a six" port. Blaser | |||
| | #7 (Link) | |||
| Re: Box for Tumult 15D2 really? a 32" long 6" diameter port doesn't present port air issues until below 20hz...With a precision dual flared port, air velocity may even be lower than suggested graphs. Honestly, I don't see why one wouldn't go with a 15 hz tune but to each his own. ![]() as for length, I guess it would depend on the shape of the enclosure. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #9 (Link) | |||
| Re: Box for Tumult 15D2 Adire Tumult 15" d2 new Fs 18.00 Hz Re 2.80 Ohm Qms 8.90 Qes 0.41 Sd 736.0 cm2 Vas 188.0 l Xmax peak 33.00 mm Le 0.60 mH Le2 0.00 mH Re2 0.00 Ohm If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #10 (Link) | |||
| Re: Box for Tumult 15D2 Better yet, heres a link to the location of all the T/S for the recent generation Adire subs. ![]() http://www.acoustic-visions.com/~aco...by_brand.shtml If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #11 (Link) | |||
| Re: Box for Tumult 15D2 Thanks Exocer, Indeed going higher than 15 Hz would be just for practical reasons, nothing more.... How would you fit a 6" 86 cm long pipe in a 270 Liters box.... It is not only about single dimension (length) but the port needs 6" everywhere around to breath properly. Maybe a sonotube, but in a box I think the tube would have to go past the enclosure. Moreover, you should change the Qp to 5 (keeping port air velocity never exceed 26 m/s) to have a realistic simulation, keeping things fair. This will show port compression in the SPL graph. B Rgds Blaser | |||
| | #12 (Link) | |||
| Re: Box for Tumult 15D2 If somehow he could get his hands on a 20" diameter sonotube it could work...I Do however see it pointless now to tune to 15hz...he'll barely get more extension in a 250liter effective enclosure and it will introduce some difficulty in the overall project...but we're not stuck at 250liters either. He doesn't specify size constraints. But yeah, just throwing a little project idea out there.. ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| What SV box sub comparable to Velo DD-12? | Huck | SVSound | 14 | 03-09-07 11:01 AM |
| My Box Design | Danny | DIY Subwoofers | 14 | 02-21-07 08:11 AM |
| Cylinder vs. Box | nova | SVSound | 8 | 02-18-07 05:20 AM |
| Sonotube vs Box | letzleta | DIY Subwoofers - Sealed and Ported | 34 | 02-05-07 02:32 PM |
| Sealed 3.9ft^3 Tumult Project | Exocer | DIY Subwoofers - Sealed and Ported | 64 | 09-12-06 09:07 PM |
