Insulation materials. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Insulation materials. in the DIY Speakers and Subwoofers forum; Insulation materials. Hello Friends! I have read that filling subwoofer walls with an insulation material has for main target to make the ...
Old 04-27-07, 02:43 PM   #1 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Hello Friends!
I have read that filling subwoofer walls with an insulation material has for main target to make the enclosure act like a bigger one (enhance LF response). From the other side, I have also read that this helps with wall resonances.
Moreover, there are many types of insulation materials: Fiberglass, Fiberfill, Dacron, open cell foam, closed cell foam.....
Here are some points I would like to discuss:
- How much bigger the enclosure will appear? what's the rule?(related to thickness, wall length?)
- Should the insulation volume be substracted from the effective volume before insulation?
- What if the enclosure is big enough (LLT for ex.), is stuffing mandatory? What about the tuning frequency if the enclosure appears bigger than it is?
- What are the differences between insulation materials? Why use one and not the other type?
- When to apply insulation or not?
If others have questions, they are wellcome to add. Those who have answers are wellcome to educate!!
Thanks.
Old 04-27-07, 03:07 PM   #2 (Link)
Alias: Michael
Loc: Chesapeake Virginia
User: #3685
Since: Nov 2006
buggers is offline
Re: Insulation materials.
This is good stuff and it won't break the bank.
http://www.knoxfoam.com/cgi-bin/Soft....htm?E+scstore
Old 04-27-07, 03:49 PM   #3 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
No no, I am not talking about prices... I am looking for scientific reasons. comparisons, whys....
Old 04-27-07, 06:00 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Here's a good article that will cover at least some of your questions.
http://www.diysubwoofers.org/talksho...ages/41415.htm
Old 04-30-07, 06:03 AM   #5 (Link)
Alias: Michael
User: #3685
Since: Nov 2006
buggers is offline
I see what your saying. I use this material simply to make the box stop ringing, to make it dead.
Old 05-13-07, 10:48 PM   #6 (Link)
Alias: Dan
Loc: Chesapeake, VA
User: #7007
bigguy is offline
buggers wrote: View Post
which is better... their egg crate or the closed cell... or rough or smooth surface?
Old 05-14-07, 09:51 AM   #7 (Link)
Alias: Michael
User: #3685
Since: Nov 2006
buggers is offline
The closed cell for deadening the box, open cell for absorbing sound. I use the closed cell to line the box and then use fiberglass to fill the box if necessary. I dont believe it is as critical for subwoofers.
Old 05-22-07, 05:00 PM   #8 (Link)
Alias: Matt
User: #6799
Chester is offline
I use activated charcoal in perforated baggies in my sub... (its a diy sub)
http://www.kef.com/technology/acoustic/aceintro.asp
Old 05-25-07, 12:15 PM   #9 (Link)
New Member
Alias: GrJohnso
Loc: Mountain View, CA
User: #5983
Since: Jan 2007
grjohnso is offline
ACE is an interesting thing... Where did you get it, and how much does it cost? How would you rate it compared to conventional dampening/fill material?
Old 05-26-07, 06:35 AM   #10 (Link)
Alias: Matt
User: #6799
Chester is offline
http://www.kef.com/technology/pdfs/acewp.pdf
well first I looked at this whitepaper for a bit, I tried to find an approximate conversion factor; how much volume x volume of carbon would add to the box. my calculations were as follows (data taken from whitepaper)
2.8 liters of normal volume
2.2 liters carbon simulating
3.6+2.2=5.8 liters;
5.8/2.2=2.636 (factor of volume increase per volume of carbon)
these numbers were derived from the text on the 6th page about the technology demonstration.
basically I get 2.6 cubic feet for every cubic ft of carbon in the box *below 90 hz (see graph in whitepaper)... anyways, KEF uses goretex fabric 'tubes' to enclose the activated carbon which is of a consistency of slightly heavier than styrofoam, 'sand granules' that will easily crumble and leave coal dust on whatever they crumble on... be sure to work outside on some grass or something if possible, or atleast an easy to clean area.
my carbon is in 'pouches' about the size of medium size zip lock baggies made of perforated plastic, normally landscaping material... the holes are just small enough that the carbon cannot get through; i will try and calculate out the volume of carbon used, i cant find my figures right now: I do know that i ordered two 40 lbs (80 lbs total) boxes of it, i have a little more than one box left over for future projects, I think it was around $66 per 40 lb box. I feel it works great as a dampener, in my sub I have noticed that due to teh vibrations, it 'settles' in the baggies very well and after while the baggies flatten and meld (is that a word? lol) together, (they take up the least space possible). I am considering putting a bit of rockwool in the sub however I dont want to open it... as far as the stuff working, I have used a dbx RTA-M mic hooked to my computer to measure the frequency response of the room (using the Room EQ Wizard program obtained on this forum), the bass response went to 15-14 hz, the calculated value with the carbon. This is including a 12db/oct cut below 37.5hz to account for cabin gain. I hope this helps a bit, I will try and find more links (i think i have a few patent links also) if you want them.
-Matt
EDIT: I found the carbon through Froogle (Google Products now?) I got the '20x40' grade (a measure of particle sizing), also, KEF's whitepaper shows differences between carcoal activated carbon and coconut shell activated carbon, i believe what I have is the coconut shell variation. cant remember why I choose that one
Old 05-27-07, 03:01 PM   #11 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
I have read good things about rockwool....what do you think?
Old 06-19-07, 09:59 PM   #12 (Link)
Alias: Matt
User: #6799
Chester is offline
i have not done any 'analysis' between rockwool and plain insulation however i have found it to work very well. looking at absorption coefficents provided other places on the net, it works great
Old 06-20-07, 04:08 AM   #13 (Link)
Alias: shr-t
Loc: Finland
User: #8851
Since: May 2007
shr-t is offline
Ilkka wrote: View Post
I actually plotted a couple of figures of those numbers a while back, also converted to standard SI-units, here's it.
I've used just rockwool or some other standard construction materials, cabinet filling materials specifically made for speaker construction are usually overpriced and too light in my opinion(i.e. they have less of an effect than regular rockwool).
Similar Threads
Room treatment materials in Aus?? Hakka Home Audio Acoustics 36 07-12-07 05:11 AM
Speaker cabinet/enclosure materials?????? drf DIY Speakers 11 04-24-07 02:02 AM
What materials............ Rodny Alvarez DIY Subwoofers 11 03-30-07 03:42 PM
Speaker Grill Materials Ayreonaut DIY Speakers 20 11-20-06 10:32 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
