Help me choose.... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Help me choose....
Discuss Help me choose.... in the DIY Speakers and Subwoofers forum; Help me choose.... Does this setup seem like a good setub. 2 TC Sounds dB-500 and a BASH Digital Sub Amp out of ...
Old 04-30-07, 07:19 PM   #1 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
gilbypoleadamson is offline
Help me choose....
2 TC Sounds dB-500 and a BASH Digital Sub Amp out of a ported enclosure with the subs in a clamshell setup?
Old 04-30-07, 08:59 PM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: Help me choose....
I don't know too much about isobaric loading, so I won't comment on that part.
As far as the amp goes, I think there are two issues. The first is that I'm not sure that that amp is rated to drive a 2 ohm load (it only lists 4 ohm in the specs), which means you'd either have to risk it or wire the drivers in series for 8 ohms which gives you probably 250 - 300 W for the drivers which are capable of handling 800 W. I would want an amp rated for 800W @ 2 ohm going to two 12" dB500s.
Old 04-30-07, 09:04 PM   #3 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
Do you have any amps in mind that would be good?
Old 04-30-07, 09:37 PM   #4 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
I'd personally use a pro amp. A Behringer EP1500 could get you 450 W to each driver (real world will be less). If you're stuck on a plate amp, then the elemental designs LT/1300 will probably get you a lot closer to 800W @ 8 ohms(maybe 650W or so) but it still isn't rated for a 2 ohm load. I don't think I've seen a plate amplifier that was. Maybe someone else is aware of something different.
Old 04-30-07, 10:17 PM   #5 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
I was recommended the Nady XA900 but from the reveiws on the website it doesnt sound too great.
Old 05-03-07, 07:52 AM   #6 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
We need more details to really evaluate your design. What net cabinet volume are you aiming for? What is the tuning frequency? Why the isobaric (clamshell) loading? It's only advantage is a 50% reduction in net box volume. A single db500 will do well in 3 ft^3 tuned to 20hz...I don't imagine you can build anything much smaller when you add in the complexity of isobaric.
As others have stated, the BASH amps don't really like 2 ohm loads and an 8 ohm config would leave you wasting a lot of excursion capability. How big is your room? What speakers are you matching it with? A single ported db500 with 500 watts will produce enough output for most people...or at least enough to get you into the hearing damage area of OSHA's safety charts.
-Brent
Old 05-03-07, 07:56 AM   #7 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
Well the problem is I dont know what to use for a cabinet. I have talked to other people and decided on a ported enclosure with two dB-500's running off a buttkicker. The only thing I dont know is what kind of design for the enclosure that i want to use. Also my room is my basement so it is relativly big. Also, as much out put as possible is always good.
Old 05-03-07, 08:02 AM   #8 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
TC Sounds has box/tuning recommendations on their db500 page. Even better, download WinISD Pro or Unibox, read the FAQs and Help files, enter the T/S parametes as instructed, and model a design yourself.
Sounds like you're approching this project without first defining your requirements and understanding what's needed to make them a reality. Not usually a good path to a satisfactory outcome.
-Brent
Old 05-03-07, 08:29 AM   #9 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
Yea, Ive never done this before so im still in the preliminary stages where I havent bought anything and im trying to figure out what i should do to get a good sub. Thanks for the advice.
Old 05-03-07, 08:38 AM   #10 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
Also the only reason i had the clamshell setup in mind is because i found a cool design using it but it looks a little to compliucated for me.
Old 05-03-07, 10:29 AM   #11 (Link)
Alias: Boom
Loc: Fairfax, Va
BoomieMCT's Avatar
User: #4757
Since: Dec 2006
BoomieMCT is offline
gilbypoleadamson wrote: View Post
If you have no space limitations and you need to fill a large space then there is no real reason you should go with a clamshell (isobaric) arrangement. Those are usually done to decrease the size of the enclosure.
Old 05-03-07, 12:28 PM   #12 (Link)
Alias: gil
Loc: princeton, nj
User: #6437
Alright, cool. Does anyone know of anywhere to find simple designs for a sub enclosure other then subwooferbuilder.com
Old 05-03-07, 02:49 PM   #13 (Link)
Alias: Aaron
Loc: Albuquerque, NM
JorgenMan's Avatar
User: #2040
Since: Aug 2006
JorgenMan is offline
You'd be best off using a custom enclosure design. If you want help with the design, or if you don't want to bother with the design at all, let us know what size you want, limits on dimensions, etc, or if there is another subwoofer you like the look of. Of course, designing the enclosure is half the fun, and it's really not complicated at all.
My meager HT
It's like, how much more black could this be? And the answer is none. None more black.
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
