A500 bridged mono - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
A500 bridged mono
Discuss A500 bridged mono in the DIY Speakers and Subwoofers forum; A500 bridged mono I am currently using a Behringer A500 to power a pair 12" shiva sonosubs (4ohms each). I am thinking of ...
Old 05-10-07, 02:54 AM   #1 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
A500 bridged mono
I am currently using a Behringer A500 to power a pair 12" shiva sonosubs (4ohms each). I am thinking of upgrading to a more powerful amp, I have been lighting up the clip indicator a bit since I beefed up my house curve.
The manual states that it can only handle an 8 ohm load in bridged mono. The amp is equipped with a thermanl protection circuit.
If I was to try a 4ohm load in bridged mode and the amp couldn't handle it, I'm assuming the thermal protection will kick in. Is this right or is there other dangers involved?
Eventually i will upgrade to a EP2500, but in the meantime I want to be able to push at lest one sub a buit harder than I am now.
Hakka.
Old 05-10-07, 08:06 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: A500 bridged mono
With two 4 ohm drivers, how would you provide a total 4 ohm load?
Old 05-10-07, 07:17 PM   #3 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
I am just talking about running a single 4 ohm sub.
Old 05-10-07, 08:15 PM   #4 (Link)
Alias: brandon
Loc: Murfreesboro, Tn
brandonnash's Avatar
User: #2533
Since: Sep 2006
brandonnash is offline
I may be wrong, but I don't think you'll get much more out of that amp. I would just leave it as is. One speaker to each channel. You're running a 4 ohm load for each channel so that's about the max the amp can put out.
My guess, if you were to try to hook it up mono 4 ohms, one of a couple things will happen. Either it will shut off as soon as it is hooked up either from going into thermal protection mode or from blowing a fuse (if it has any), or it may be able to play until a passage of music that dips the subs a good deal below 8 ohms and then once again throws it into protection. Upgrade if you're wanting more out of it.
Old 05-10-07, 08:16 PM   #5 (Link)
Alias: brandon
User: #2533
Since: Sep 2006
And I would ask if you'd be willing to sell that amp, but it seems we're worlds apart distance wise.
Old 05-10-07, 09:00 PM   #6 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
I will definately be upgrading, I was just keen to try it in the meantime.
Hakka.
Old 05-10-07, 09:57 PM   #7 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
brandonnash is right -- you can try it for a while and see how far it goes before it shuts down. If you're already pushing it to its limits with your current set up, it doesn't have much more to give. Plus, I think you'll get more volume out of the two subs than the one with an increased amp. Two properly set up subs should give you a 6 dB increase, while you would have to go 4x in power to get the same increase in SPL. That amp doesn't have 4x more to give.
That's just what I'm thinking. If I were you, I would do it. That's just exactly the kind of thing I would do. Just turn the volume up slowly...
-- Otto
Old 05-11-07, 02:46 AM   #8 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is online now
I tried two 4 ohm car speakers on the a500 and it didn't shut down ... just mildly warm. though the speaker sensitivities were in the 90's
Old 05-11-07, 03:21 PM   #9 (Link)
Alias: brandon
User: #2533
Since: Sep 2006
Did you have them hooked up serial or parallel? one gives you a 2 ohm load, the other 8.
Old 11-01-07, 08:49 PM   #10 (Link)
Alias: mike
mike c's Avatar
User: #147
brandonnash wrote: View Post
IIRC, I believe I was running a single 4 ohm speaker on a BRIDGED behringer a500.
and it was barely warm.
Old 11-01-07, 09:32 PM   #11 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Hakka wrote: View Post
Don't the Shiva's have dual voice coils?
Warmon - "know what I mean Vern"
Old 11-01-07, 09:42 PM   #12 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is offline
Yes they do. They are dual 8 ohm coils.
Similar Threads
Behringer A500 mgboy DIY Subwoofers 19 04-18-07 01:49 AM
Is rca mono to 1/4 stereo ok??? frockc REW Forum 11 02-05-07 11:05 AM
RB1070 bridged mono?? Hakka Home Theater Components 3 09-28-06 06:08 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
