| DIY Subwoofers Crown XLS 602D $229 ARDiscuss Crown XLS 602D $229 AR in the DIY Speakers and Subwoofers forum; Crown XLS 602D $229 AR Hey Guys,
I went ahead and bought my Crown. This is a pretty good deal if you ask me. MAP ... |
| | #1 (Link) | |||
| Hey Guys, I went ahead and bought my Crown. This is a pretty good deal if you ask me. MAP is $499 Specifications Output Power: 2-ohm Stereo (Per Channel): 840W 4-ohm Stereo (Per Channel): 600W 8-ohm Stereo (Per Channel): 370W 8-ohm Bridged-Mono: 1200W 4-ohm Bridged-Mono: 1680W Road Dog Online is an authorized retailer, which means you get the rebate and the warranty. (I looked them up on Harman Pro's site.) Currently, they are offering the XLS 602D for $369.00 shipped. Add Crown's $135 MIR, and you are down to $234 just like that! Here is Road Dog's link: Road Dog Online And a link to the rebate valid until May 31! Crown Cash Rebate I pricematched the deal to Audiolines because, Road Dog would have to charge me sales tax. Also qualifies for a $5 Pricegrabber rebate! Final price $229 Pricegrabber Page **NOTE** I am in no way affiliated with any of these companies. I have read the rules and have posted this thread in good faith. I simply hope to share a great deal with other forum members looking for an amp. If it is contrary to forum rules, please delete this post. Cheers! Last edited by FireWalker877; 05-20-07 at 03:54 PM. | |||
| | #5 (Link) | |||
| Re: Crown XLS 602D $229 AR Hmm... That's good to know. I was thinking about driving a 2 ohm RLp15 in series. Obviously it might be a little rough on the amp thermally, but what about the driver? They say to leave the attenuators full open so that you have an equal output on each bridged channel. I don't plan on abusing anything, but of course I will be living in a house with a radio, film, and television major. You never know what kinda stuff an intoxicated roommate might pull. Obviously a configuration like this might be a little rough on the amp thermally since it is pushing out more power, but what about the driver? It would probably never even see 1680W, right? After amplifier efficiency loss, line loss, etc. I would guess maybe the sub would have around 1500W max to work with. So would this mean that I would have 500W or so of headroom? Thanks! Last edited by FireWalker877; 05-22-07 at 02:22 PM. | |||
| | #8 (Link) | ||||
| | Re: Crown XLS 602D $229 AR Quote:
JCD | ||||
| | #11 (Link) | |||
| Re: Crown XLS 602D $229 AR I've never had a problem running the crowns at 2ohms. It wasn't that model though (Amps I used put out more power) and they never shut down even when driving them hard. | |||
| | #12 (Link) | |||
| Re: Crown XLS 602D $229 AR Yeah, the XLS is their low-end model. I decided to play it safe, and power an 8 ohm TC2k. The amp was rated for 4 ohms, but I figured 1200W would give me all the output I needed without the risk of overheating. I just glued my first joint on the enclosure, I hope I used enough Titebond! ![]() | |||
| | #13 (Link) | |||
| Re: Crown XLS 602D $229 AR The Lab Gruppen Amps are good to use, run them down to 2 ohm and still no problems even at maximum output. The C series may be good as you can set them to switch on in a certain order (using your computer) and are able to make settings which other amps don't have. Really good to work with | |||
| | #14 (Link) | |||
| Re: Crown XLS 602D $229 AR Yes LAb are very good amp, but 10 X the price of an XLS so i'm not sure will fit his bill and i'm not sure people needs Lab amp in their houses anyway, QSC and Crown makes excellent amp's that will fit anybody need :-) | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Crown XTI-2000 | Tony3d | DIY Subwoofers | 17 | 06-14-07 04:55 PM |
| Crown XLS 602D? What do you think? | FireWalker877 | Home Theater Components | 2 | 05-15-07 10:14 AM |
| Peerless Downfiring XLS | technimac | DIY Subwoofers - Sealed and Ported | 4 | 11-04-06 11:23 AM |
| Chorus Vertigo XLS | Ilkka | Subwoofer Tests | 3 | 07-17-06 02:32 PM |
| DIY PA horn (XLS 12) | Ilkka | Subwoofer Tests | 3 | 07-17-06 02:28 PM |
