Sub Box Design - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Sub Box Design
Discuss Sub Box Design in the DIY Speakers and Subwoofers forum; Sub Box Design Hi all Can someone with experience in Win ISD take a look at my project and explain what it's telling ...
Old 05-29-07, 02:03 AM   #1 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Sub Box Design
Hi all
Can someone with experience in Win ISD take a look at my project and explain what it's telling me. See links for project and driver files
Project file
http://files.filefront.com//;7636005;;/
Driver file
http://files.filefront.com//;7636006;;/
Thanks
Dan
Old 05-29-07, 11:37 AM   #2 (Link)
Alias: brandon
Loc: Murfreesboro, Tn
brandonnash's Avatar
User: #2533
Since: Sep 2006
brandonnash is offline
Re: Sub Box Design
When I get home from work I'll try to pull up those files and view them. Can't right now. I'm pretty familiar with WINISD.
Old 05-29-07, 09:21 PM   #3 (Link)
Alias: brandon
User: #2533
Since: Sep 2006
Re: Sub Box Design
haven't downloaded your driver file, but from looking at your project file, you need a bigger box and a lower tune. Have you already purchased your driver? I doesn't look like it's up to the task of big subwoofing. Looks like it ~might~ be alright for car audio. Let me know if you need some suggestions on other drivers.
Old 05-29-07, 10:00 PM   #4 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: Sub Box Design
I've already bought the driver, and it's to be used as a music sub. How do you alter the box size (in Win ISD). I'll upload a box design i did up when i get home.
Dan
Old 05-29-07, 11:32 PM   #5 (Link)
Alias: PHIL
Loc: SHERMAN, TX
ISLAND1000's Avatar
User: #8655
Since: May 2007
ISLAND1000 is offline
Re: Sub Box Design
When the project window box opens click on the box tab. That will change the window box and the box size and tuning frequency will be visible.
I'm afraid you're going to find that the speaker is inapropriate for use as a music sub. There isn't anything that WinISD can do for you on this one . . . .
My recomendation, just put it in a sealed box no bigger than 2 cuft or sized to fit where you want to place it and see how it sounds.
Old 05-30-07, 01:05 AM   #6 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Sub Box Design
Are you sure you have entered the driver parameters correctly? I notice there is no Pe value listed. What driver is it? Do you have a link to the driver specs??
Old 05-30-07, 11:55 PM   #7 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: Sub Box Design
Here is the link to the driver info
http://files.filefront.com//;7653294;;/
I have heard this particular driver in another setup and it sounded decent.
Dan
Old 05-31-07, 12:28 AM   #8 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Sub Box Design
The specs list the xmax as 3.5mm for a 12 inch driver????
Hakka.
Old 05-31-07, 02:14 AM   #9 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: Sub Box Design
yes thats the old version of the specs, i think there's a new one somewhere just gotta find it, all other specs are correct except it's a 4 ohm driver. It's a developmental driver
Old 05-31-07, 02:45 PM   #10 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Re: Sub Box Design
Hakka wrote: View Post
Hakka.
Very weird!even many speakers with a 6 inch woofer would exceed 3.5 Xmax....There's certainly something wrong
Old 06-02-07, 09:27 AM   #11 (Link)
Alias: Gui Lao
Loc: Shenzhen, China
phaseshift's Avatar
User: #9242
Since: May 2007
phaseshift is offline
Re: Sub Box Design
Looking at the parameters entered in the file, it appears to be a midrange / midbass driver. I am not trying to be a smart-***, but is this a guitar speaker or something out of a reinforcement application? Huge magnet, pleated (accordion) surround, shallow cone? It sure looks like it based on the data entered in the WinISD file. I could be wrong, but it sure looks like a PA speaker to me.
Old 06-02-07, 10:17 AM   #12 (Link)
Alias: brandon
User: #2533
Since: Sep 2006
Re: Sub Box Design
Probably is a PA speaker. Most of those are limited to midranges and have very little xmax. I've seen some big 18" subs that only have 6 mm of xmax.
Old 06-02-07, 05:29 PM   #13 (Link)
drf
Alias: drf
Loc: Somewhere else.
drf's Avatar
User: #3282
Since: Oct 2006
drf is offline
Re: Sub Box Design
I also agree, reading the TS that this is a P.A driver and as such will probably suffer bad HD when played below resonance. It will reproduce down to 35Hz but it won't sound as good as a sub designed for hifi enclosures with Fe's down to 30Hz or lower. If you plug the TS of that driver into winISD it will tell you you need a ported enclosure 700 odd litres to make the most of it. I would say this is because the driver looks to be designed to sit in an open back guitar cab.
"Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless
The imperative is to make a subjective study an objective fact.
Old 06-14-07, 10:34 PM   #14 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: Sub Box Design
Checked with the fella I got it from and it (the driver) is based on a Pro - audio speaker design. Also said it'll get down to about 30Hz with the right tune. Question can WinISD tell you what frequency a box is tuned at if you input the info (will try and upload a design of the box when I get home)? The efficiency of the driver is high (99db Watt/metre) and can take 600 watts so don't know if this has an effect on the sound. Might make an alright bass guitar speaker?
thoughts, criticisms, death threats :-)
Dan
Old 06-14-07, 10:44 PM   #15 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: Sub Box Design
And also I need something cheap to rolloff frequency's below tuning freq, any suggestions????
Old 06-14-07, 10:54 PM   #16 (Link)
Alias: Gui Lao
phaseshift's Avatar
User: #9242
Since: May 2007
Re: Sub Box Design
If the parameters posted earlier are correct and the 1w/1m SPL is 99dB, you got yourself a midbass driver intended for a reinforcement application. Yes, it may get down to 30Hz, but it will likely not be very strong there due to the short linear travel. Probably a good driver, but may leave you wanting more on the low end. Now that is based on the previously posted data; if that has changed or was in error, then this is all out the window.
Can you post a picture of the driver, front and back? That would clear up a lot of questions that some have in regard to the application of this driver as a reinforcement transducer is normally easy to pick out. Typically, they are going to be heavy duty in appearance, cast frames, big magnets etc... What you will also see as typical is that the frontplate will not have the thickness that you normally do in a subwoofer. Another very telling sign is a bumped backplate to give clearance for the VC on the inward stroke. Accordion surround is another telling characteristic of a reinforcement driver as well as cone angle and overall depth.
Similar Threads
Box for Tumult 15D2 MELKA DIY Subwoofers 16 04-25-07 02:14 PM
My Box Design Danny DIY Subwoofers 14 02-21-07 08:11 AM
Cylinder vs. Box nova SVSound 8 02-18-07 05:20 AM
Sonotube vs Box letzleta DIY Subwoofers - Sealed and Ported 34 02-05-07 02:32 PM
Guide to Sub box Design Danny DIY Subwoofers 12 05-13-06 10:48 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
