DIY Subwoofers
ART Cleanbox frequency response
Discuss ART Cleanbox frequency response in the DIY Speakers and Subwoofers forum; ART Cleanbox frequency response What about the Aphex 124A? Cost quite a bit more than the CleanBox, but the specs look decent. http://www.aphex.com/124A.htm http://www.sweetwater.com/store/detail/124A/...
Views: 5844 - Replies: 55
Old 06-27-07, 04:59 PM   #26
New Member
Alias: Frank
Loc: Landover Hills, MD
User: #9696
Since: Jun 2007
  fmw63 is offline
Re: ART Cleanbox frequency response
Old 06-28-07, 02:28 AM   #27
Luke G
Inactive
Alias:
User: #
Posts: n/a
Ilkka wrote: View Post
"Slartibartfast" over at AV Talk forum has measured the SMS-1. I doubt the REW would show any different results but I can measure it when I get back home.
http://www.avtalk.co.uk/forum/index....&SQ=1182931696
Using the lowest setting...
-1.0 dB @ 20 Hz
-11.5 dB @ 10 Hz
-29 dB @ 5 Hz
So actually it's even worse than the Art Cleanbox...
That's scary. Has anyone done similar testing with a BFD?
Old 06-28-07, 04:51 AM   #28
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Luke G wrote: View Post
Yes, the BFD is much better.
-0.6 dB @ 20 Hz
-1.1 dB @ 10 Hz
-2.5 dB @ 5 Hz
-7.2 dB @ 2 Hz
Here's a comparison.
Old 06-28-07, 08:37 AM   #29
Alias: Jim
Loc: Wetumpka
User: #630
  JimP is offline
Ikka,
Can you throw in the SMS-1 into that chart?
Thanks
Old 06-28-07, 05:26 PM   #30
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
JimP wrote: View Post
Ikka,
Thanks
I can, but not until I get back home (around two weeks).
edit: See below.
Old 06-30-07, 10:23 AM   #31
Alias: Nick
Loc: Austin
User: #3194
Since: Oct 2006
  Nick77 is offline
SteveCallas wrote: View Post
Another one bites the dust and another valuable piece of real world info from Ilkka. Now imagine if someone was using a Velo SMS with an Art Cleanbox in the chain coming from a HK receiver......wow, instant HTIB subwoofer
Steve I missed previous input about HK recievers. Please give me a brief reply on findings since I am running a 635. Thanks
HK 635 Denon 1920 Onix 750 Rockets Sound Splinter RLP15 Sono
Old 06-30-07, 10:32 AM   #32
Alias: brucek
User: #6
  brucek is online now
Ever used REW software Nick? You could check your own receivers response fairly easily.
Old 07-01-07, 12:05 PM   #33
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
If the EQ settings are used at all, a highpass filter is automatically engaged based on the description of the subwoofer. There should be an option menu that asks how large of a subwoofer driver you are using, and the largest choice is a 15". I forget the specific center frequencies of the highpass for each driver size, but they were all too high for a LLT.
As long as you leave the EQ feature off, I think you will be ok.
Old 07-03-07, 09:54 AM   #34
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
This is something I posted on AVS Forum after reading this thread. Can someone advise pleas? Thanks and happy 4th to everyone!
Ok, was just browsing through and saw what the Art Clean box does to the FR and considering i'm using this for a subwoofer application -5.4db at 20hz etc. is not exactly desireable. So my question now becomes can I just hook the QSC PLX3602 up directly to the LFE line level output of my reciever by using either a RCA to XLR or RCA to TRS jack?
My reciever is a Pioneer 1015TX in which the manual indicates output specs on the RCA connections of 335mv and 2.2 k-ohms. The input sensitivity of the PLX3602 is listed as 1.25 volts rms and 10k-ohms unbalanced and 20k-ohms balanced. Will this work? Any advice is appreciated.
Old 07-03-07, 10:40 AM   #35
Alias: brucek
User: #6
My receiver is a Pioneer 1015TX in which the manual indicates output specs on the RCA connections of 335mv and 2.2 k-ohms. The input sensitivity of the PLX3602 is listed as 1.25 volts rms and 10k-ohms unbalanced and 20k-ohms balanced. Will this work?
Yes, it will work. I suggest that the spec from the pioneer of 335mvolts is the nominal output and indicates the standard consumer nominal level of -10dBV (which is ~316mvRMS). The normal maximum output of that interface would then likely be a standard +2dBV (which is 1.26mvRMS). That is consistent with the maximum spec you list for the PLX3602. Just make up your RCA to TRS (or XLR) connector and you'll be fine..
Old 07-03-07, 10:46 AM   #36
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
brucek wrote: View Post
Thanks! I will probably just go pick up an adapter from radio shack. I don't know if they have RCA to XLR but i'm 99% sure they have RCA to 1/4" TRS so that's the way i'll go.
Old 07-03-07, 11:18 AM   #37
Alias: brucek
User: #6
You would need an RCA to TS adapter to convert to unbalanced......
Old 07-03-07, 11:57 AM   #38
Alias: Nick
Loc: Salisbury, Md
User: #9938
Since: Jul 2007
  NickTF is offline
Yep, that's the one, thanks!!!
Old 07-03-07, 04:46 PM   #39
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
I couldn't get XLR to RCA despite trying 5 music shops so finally had to settle for male and female XLR to female Jack adaptors then male Jack to RCA adaptors.
Here's the CX2310 active crossover frequency response.
Low frequency channel: Crossover set to 930Hz max (X1). All gain settings to flat.
Not much to worry about here:
Old 07-03-07, 06:30 PM   #40
Alias: brucek
User: #6
Yeah, very good. It seems most of the Behringer stuff has excellent low frequency response..
Old 07-04-07, 04:09 AM   #41
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
I'm just grateful the CX2310 wasn't stealing my bass.
Old 07-05-07, 07:11 AM   #42
Alias: brucek
User: #6
What would be the downside, if any, of simply using one an EQ band or shelf filter
I don't see a lot of down side. The mod to the cleanbox seems fairly simple though and even with the rudimentary tests that a few performed, it appears effective. I believe Ilkka said he would test the mod properly when he has the time, and then you could get a better idea if it was worth the effort.
Old 07-05-07, 03:14 PM   #43
Alias: Bob
Loc: Shueyville, Iowa
User: #25
  bobgpsr is offline
DS-21 wrote: View Post
I probably phrased my post badly. More succinctly, what I meant to ask was the following: what is the downside (if any) of leaving the Cleanbox as is and simply ensuring low-end response to taste via downstream EQ?
Worse Signal to Noise ratio due to loss in the Cleanbox. Better to fix the low frequency rolloff issue in the Cleanbox and not lose the real signal. Also downstream eq would be rare -- what would do it? The Cleanbox is meant to just bring the line level up to pro audio level and have a balanced output (to drive a pro amp). Would really need a pro type equalizer.
A BFD already has an input selection for consumer level line inputs -- Cleanbox should not be needed at all with it.
Old 07-12-07, 05:55 PM   #44
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Here's a little something I put together.
Frequency responses are levelled at 100 Hz except for SMS-1 and R-DES which don't have a fully by passable low pass filter. The SMS-1 had the newest v2.12 software and 5 Hz, 6 dB/oct. subsonic filter setting was used. DSP1124P is known as the older BFD (though not the oldest which is the DSP1100), and FBQ2496 is known as the newer BFD, which seems to have the least low frequency roll-off of them all. I will soon mod the Cleanbox to find out if that improves it.
Old 07-12-07, 06:16 PM   #45
Alias: Mongrel
Mongrel714's Avatar
Loc: Melbourne,Florida
User: #9120
Since: May 2007
  Mongrel714 is offline
Since I'm using a pro amp I'm gonna try a pro direct box and see how that works, if it seems to do the job we'll measure this thing and see if it is an option.
Old 07-13-07, 08:25 AM   #46
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Thankyou for sharing this graph, Ilkka.
How important, in your experience, is the bass roll off of these boxes in the real world?
Do these roll-offs just offer valuable protection to modest subwoofers?
Presumably the effect is very subwoofer dependent?
If a sub can't reach low and loud then it won't notice the high pass effect anyway.
Old 07-13-07, 02:45 PM   #47
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
I'm happy to have dual RL-P18 in 650 L each and a FBQ2496
Old 07-14-07, 12:08 PM   #48
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
"Let there be bass: and there was bass."
Yes, the mod works. I doubt I have to tell which curve is before and which is after the mod.
I used 1uF 63V polyester capacitors (two red ones in the pic).
Old 07-14-07, 03:13 PM   #49
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Chrisbee wrote: View Post
Well naturally one doesn't have to be worried about this all if his sub goes only down to 30 Hz. But if one is after a good output down to 10 - 15 Hz or lower, I would definitely think which EQ to choose. And yes, one easily gains some or actually quite a lot of (excursion) protection with some of these models. But that's actually pretty old news to most of us...
Any kind of filtering (low or high pass) of course always adds group delay, though that's pretty much the least thing one should be worried about at these frequencies.
Old 07-16-07, 03:44 PM   #50
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Thanks, Ilkka.
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
