| DIY Subwoofers ART Cleanbox mod threadDiscuss ART Cleanbox mod thread in the DIY Speakers and Subwoofers forum; ART Cleanbox mod thread Maybe you can be the first one to actually test this modification with REW to prove its effectiveness, and post ... |
Views: 10501 - Replies: 109
| | #26 | |||||
| Re: ART Cleanbox mod thread Quote:
Ilkka posted a measuered -10.3 dB loss at 10Hz. Two independent tests confirmed a gain of ~10dB. Looks like it is proven to me. ![]() | |||||
| | #27 | ||||
| Re: ART Cleanbox mod thread Efalegalo, the first is a step down quality wise on it's own. The second is really big, but there should be room. The third is close to what I used, and are two per pack. Options 1 & 2 will put you in the 1Hz xover range, and opt 3 in the 3Hz range. Good luck. | ||||
| | #28 | |||||
brucek | |||||
| | #29 | ||||
| Re: ART Cleanbox mod thread I replaced my caps with the once Thylantry mentioned above. The following results were obtained using the SPL measured at the Sub and using Soho Audio Test DVD. Hz Before After Variance 16 76.8----------84.8----------8 17 79.5----------85.5----------6 18 80.7----------85.7----------5 19 82------------87-------------5 20 82.5----------87.5----------5 25 88.8----------91.8----------3 30 89.47--------92.47---------3 35 90.1----------92.1----------2 40 92.18--------93.18----------1 45 92.745-------94.745--------2 50 94.3----------95.3-----------1 55 92.3----------93.3-----------1 60 92.5----------94------------1.5 65 92.2----------93.2-----------1 70 91.9----------91.9-----------0 75 91.18-------- 91.18----------0 80 90.876-------91.376--------0.5 My tuning frequency was 15Hz, the mod definitely made a difference. However, I still don't know why I down 6db by 17Hz? Almost 7db at my turning frequency? The above readings have been adjusted for SPL correction found here at Hometheater Shack. I'm curious whats wrong - Did I not build my subs right? | ||||
| | #30 | ||||
| Re: ART Cleanbox mod thread remember that another component could be causing a drop in freq response. like an amp that is not as efficient that low but will put out a bit more a little higher in freq. could be a few things. could also be the natural roll off of the driver you used. im pretty sure its not going to be super flat through out the freqs and it will start rolling off at some point just because thats what happens when you go that low. the Port is (i think) basically just helping extend the response and help out that low down. That statement was purly a shot in the dark with what i know, take it as such. i used those large blue caps in mine. a pain to get mounted but work great, also need to be squished a bit in there to fit. | ||||
| | #32 | ||||
| Re: ART Cleanbox mod thread How close to the sub were you measuring? It looks like it was close, and you didn't get a good reading from the port. The port gives you a lot of the under 20Hz SPL. That is why it is hard to measure a large ported system accurately. | ||||
| | #33 | ||||
| Re: ART Cleanbox mod thread I held the SPL meter right in front of the woofer, right at edge of the base plate facing it towards the center of the woofer (in other words, really far from the port - on the opposite end, at the driver). What would be the best way to measure the sonotube design? Thanks And thanks you very very much for the Mod tips - it helped immensily. | ||||
| | #35 | ||||
| Re: ART Cleanbox mod thread here are some pics of my mod. www.ccdoggy.net/speaker/IMG_2118.jpg www.ccdoggy.net/speaker/IMG_2119.jpg www.ccdoggy.net/speaker/IMG_2120.jpg and i must say it makes an impressive difference. i watched mater and commander again and it really makes quite a bit more impact. definetly worth it. | ||||
| | #37 | |||||
I will also take some distortion measurements. | |||||
| | #38 | ||||
| Re: ART Cleanbox mod thread "Let there be bass: and there was bass." Yes, the mod works. I doubt I have to tell which curve is before and which is after the mod. ![]() I used 1uF 63V polyester capacitors (two red ones in the pic). 63V because they are much smaller than say 250V, and one doesn't need 250V caps when the operating voltage is only ~12V. ![]() ![]() | ||||
| | #40 | |||||
| Re: ART Cleanbox mod thread Tomorrow. ![]() Quote:
http://en.wikipedia.org/wiki/Capacitor#Capacitor_types | |||||
| | #42 | ||||
| Re: ART Cleanbox mod thread This is a great mod and should be available for many people to see. I'd make this a sticky ![]() If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | ||||
| | #43 | ||||
| Re: ART Cleanbox mod thread Done. ![]() Regards, Wayne | ||||
| | #44 | ||||
| Re: ART Cleanbox mod thread Sorry ccdoggy. I didn't have enough time to take any distortion graphs while I was at home. And I won't be there again until after ~1.5 weeks. I will take them then. Although I can already say that any "electronic distortion" is pretty minimal compared to any "subwoofer/speaker distortion". So I wouldn't worry about that. | ||||
| | #45 | |||||
![]() To be continued...here: http://www.hometheatershack.com/foru...html#post50977 | |||||
| | #46 | ||||
| Re: ART Cleanbox mod thread Im about to mod my Cleanbox but I couldnt find any .47 caps at RS. I did buy 1.0 Tantalum caps (35WVDC max), will these work. I also bought 4 .22 Poly Caps just in case. if the 1.0 doesnt work, how do I connect the .22s...in series? Thanks for all this great advice! Doug | ||||
| | #49 | |||||
![]() So it may be easier to use two 0.22 poly caps in parallel for a given input. You may only need to modify one channel's input (the used one) if you are lazy like me. ![]() | |||||
| | #50 | |||||
Going back to the .22 caps in parallel and I only need to modify one channel since I only use one channel. | |||||
