DIY Subwoofers
ART Cleanbox mod thread
Discuss ART Cleanbox mod thread in the DIY Speakers and Subwoofers forum; ART Cleanbox mod thread Mod complete and case back together. The disassembly and assembly took the longest time. I had to go buy a ...
Views: 10686 - Replies: 109
Old 05-05-09, 04:44 PM   #101
Alias: fred
dynamowhum's Avatar
Loc: sulphur, la
User: #2878
Since: Oct 2006
  dynamowhum is offline
Re: ART Cleanbox mod thread
Mod complete and case back together. The disassembly and assembly took the longest time. I had to go buy a desoldering tool for this one. I had never used one before but it was straight forward no issues. The actual mod was quite easy.
Well I plugged it in and no magic smoke came out. I will play a movie tonight and will write back how it was. Thanks all for posting.
Old 09-04-09, 11:18 PM   #102
Alias: wildchild22
User: #40578
Since: Aug 2009
  wildchild22 is offline
could someone look at www.digikey.ca and tell me what caps to order. I need to order some fans for my ep2500's so I would like know the part numbers so I can order the same time.
http://search.digikey.com/scripts/Dk...me=495-1169-ND
This is what looks correct to me can someone verify.
Old 09-08-09, 08:43 PM   #103
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
I'm told by a reliable source that those are typical metal film capacitors and will be fine, as long as the size works for this project.
Old 09-08-09, 08:45 PM   #104
Alias: wildchild22
User: #40578
Since: Aug 2009
Thanks so much for your help!!!
Old 09-09-09, 04:05 PM   #105
Alias: dd
Loc: Upstate NY
User: #4892
Since: Dec 2006
  digital desire is offline
digital desire wrote: View Post
OK, just replaced that cleanbox with this:
I like much better.
http://www.thatcorp.com/datashts/1600data.pdf
Been using this for 6 or 7 months now, much happier with this than the clean box, superior in every way.
The only issue for many will be trying to make a stand alone unit, instead of integrating it like I did.
Figure 5 on this PDF is the circuit.
Old 09-09-09, 07:23 PM   #106
Alias: Collo
collo's Avatar
Loc: Newcastle, Australia
User: #5027
Since: Dec 2006
  collo is offline
Looks good, but the datasheet lists the gain at around 6dB, which isn't enough to go from "consumer" level up to "pro" level. Would not be an issue for everyone though...
Ports Rule ...
Old 09-09-09, 07:49 PM   #107
Alias: wildchild22
User: #40578
Since: Aug 2009
Isn' the difference around 12db
Old 09-09-09, 08:23 PM   #108
Alias: Collo
collo's Avatar
User: #5027
Since: Dec 2006
  collo is offline
Correct
Ports Rule ...
Old 10-21-09, 02:13 PM   #109
myn
Alias: myn
User: #2673
Since: Sep 2006
  myn is online now
It appears the images on the first post are gone.
Does anyone have these handy?
And what is the general consensus on the best caps to use from Radio Shack? the 1uf 250mv? http://www.radioshack.com/product/in...entPage=search
Old 10-23-09, 11:05 PM   #110
myn
Alias: myn
User: #2673
Since: Sep 2006
  myn is online now
So I went out and bought the Radio Shack 1uf 250v caps and installed them tonight.
I did a passive REW test before and after using channel 2 XLR as the input and channel 2 RCA as the output. This is reverse of how I run it normally but I didn't have any female to female XLR cables handy.
In any case the response plot looks the same as it did originally. Do these 2 caps only effect the channel 1 inputs (rcas)?
Also what do each of these capacitors map to? Is it 1 cap for each channel input (1 and 2) or is it just for the channel 1 with each cap representing the left/right (white/red)?
Do these metal film caps require a specific polarity? I just sat them in and didn't even think about which way they were being inserted.
Also for reference I passively tested my Panasonic XR-55 receiver and it tested out great with no decline in slope until around 9hz.
Below is the Cleanbox graph after the mod (Note rolloff below 30hz still):
Name:  art cleanbox after capacitor mod.jpg
One of the 2 installed
Both new caps installed
Testing modded cleanbox with REW wiring up to channel 2 input (XLR)
