SVC or DVC ... again - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss SVC or DVC ... again in the DIY Speakers and Subwoofers forum; SVC or DVC ... again I am planning on building a pair of sonotubes with a 15" TC-2000, driven by a Crown CE4000, QSC RMX2450 ...
Old 07-29-07, 12:08 PM   #1 (Link)
New Member
Alias: Maastricht
User: #1814
fiksdal is offline
I am planning on building a pair of sonotubes with a 15" TC-2000, driven by a Crown CE4000, QSC RMX2450 or similar. I am new to the DIY-sub-scene so I am really confused as whether to go for SVC or DVC. I will probably start with one amp, but depending on how this sounds I could, down the line, run the tubes with one amp each in bridged-mono mode. How will that impact my choice of SVC/DVC?
I have tried to model the tube in WinISD, 9 ft^3 and tuned to 16Hz, but as this is my first try I am not sure I am doing it correctly.
When it comes to purchasing the woofer I guess it all filters down to one question:
Does the DVC model run on one VC perform any different than the SVC model??
Old 07-29-07, 08:14 PM   #2 (Link)
New Member
Alias: Maastricht
User: #1814
fiksdal is offline
Re: SVC or DVC ... again
I'd like to plan ahead, but there are still to many holes in my knowledge regarding this.
The woofer is rated as SVC 4 ohm or DVC 4 ohm. I guess the possible configurations for 2 tubes and one amp (CE4000) are:
  • 1. SVC 4 ohm, amp in stereo mode 2 x 1200W
  • 2. SVC wired in series with other tube --> 8 ohm, amp on bridged mono mode 1 x 2400W
  • 3. DVC wired in parallell --> 2 ohm, amp in stereo mode 2 x 1400W
  • 4. DVC wired in series --> 8 ohm, amp in stereo mode 2 x 600W
  • 5. DVC wired in parallell --> 2 ohm, wired in series with the other tube --> 4 ohm, amp in bridged mono mode 1 x 2800W
For 2 tubes and 2 amps:
  • 6. SVC 4 ohm, amp in bridged mono mode 1 x 2800W
  • 7. DVC wired in series --> 8 ohm, amp in bridged mono mode 1 x 2400W
So the best performance order would be (SVC is underlined, 2 amps in bold) :
6 - 7 - 5 - 2 - 3 - 1 - 4 ??
Option 5 and 2 has the added disadvantage of running an extra cable between the 2 tubes.
Unless I have misunderstood how you wire a woofer, I don't see much difference between option 5 and 2 in the 1 amp config, or between option 6 and 7 in the 2 amp config. So does it really come down to a cointoss??
Also does the DVC have the same "amount" of VC as a SVC? So if I hooked up only 1 VC from the DVC, that would equal 1/2 SVC?? If not, I fail to see why SVC would be available together with a DVC model.
Comments please, is my thinking correct here?
Similar Threads
SVC or DVC tgoode DIY Subwoofers 4 07-03-07 09:39 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195
