Multiple boxes, different sizes - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Multiple boxes, different sizes in the DIY Speakers and Subwoofers forum; Multiple boxes, different sizes Hey folks, I'm going to be building a new HT soon, and the room will be pretty large. I want ...
Old 09-02-07, 06:11 PM   #1 (Link)
New Member
Alias: WarrenP
Loc: Chicagoland
User: #7954
Since: Apr 2007
WarrenP is offline
Hey folks,
I'm going to be building a new HT soon, and the room will be pretty large. I want to build some new subs for this room. I have some general sub-realted questions.
Is there any benefit to the following:
A build that has some subs in smaller enclosures, tuned a bit higher, at around 30Hz, and some other boxes that are big, really big, and tuned really low? I'm thinking of going with 4 15s (in the smaller boxes) tuned at 30Hz around the room, and 2 18s (in the big boxes) tuned low up front.
I have lots of room up front, and could redesign for room in the back. Is there a benefit to having different boxes like this, or should I just make 4 big boxes for the 18s, and leave it at that? On the flipside, am I introducing problems with the multiple box / multiple size design?
I think that in my builds I'll be going with SS drivers, so my followups will be about those drivers and related amps...
thanks!
Old 09-02-07, 08:28 PM   #2 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Re: Multiple boxes, different sizes
Wow, that's a whole lotta base!!! How much cubic feet in this room?
Warmon -
Old 09-03-07, 12:16 AM   #3 (Link)
New Member
Alias: WarrenP
Loc: Chicagoland
User: #7954
Since: Apr 2007
WarrenP is offline
The rough dimensions of the room are approx 11' x 18' x 30' so around 6000 cubic feet. Once properly framed in, and with the stage and risers, that volume will decrease a fair amount though.
Old 09-04-07, 01:30 PM   #4 (Link)
Alias: OJ
Loc: Toronto, Ontario
Owen Bartley's Avatar
User: #3144
Since: Oct 2006
Owen Bartley is offline
If you have some flexibility in your room size, why not wall off a section of the front (ie take a slice off the length of the room) and turn it into an IB? You could also mount any equipment in there if you wanted to.
Old 09-04-07, 05:11 PM   #5 (Link)
New Member
Alias: WarrenP
Loc: Chicagoland
User: #7954
Since: Apr 2007
WarrenP is offline
Owen Bartley wrote: View Post
I could do this. In fact, I've thought of building a big IB-ish box in the front, and another in the rear, for 4 18s. I'm trying to find out if there is any benefit to doing something like that, plus a few boxes that are tuned higher. If there really isn't any benefit, then I will probably just go with big boxes in front and in back.
Old 09-04-07, 07:31 PM   #6 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
WarrenP wrote: View Post
...I'm trying to find out if there is any benefit to doing something like that, plus a few boxes that are tuned higher. If there really isn't any benefit, then I will probably just go with big boxes in front and in back.
I would like to know this too. How about multiples of sealed and ported boxen?
Warmon -
Old 09-05-07, 06:26 AM   #7 (Link)
Alias: OJ
User: #3144
Since: Oct 2006
I'm not an expert, but I think that the more woofers you have in multiple positions, the more you will run into cancellation and other issues. Maybe you'll even overcome cancellation and take care of any room nulls as well with a bunch of different locations, I'm not sure. But I think the general method right now is to place a sub in the room at your listening position, and move around the room to see where you get the fullest bass, and that is where you should locate your sub (or IB). The other way of doing this is just sitting at the listening position and moving the sub around and trying it in different locations until you find the position that gives you the best sounding result.
Old 09-06-07, 05:39 AM   #8 (Link)
Alias: Sam
Loc: Adelaide
User: #11091
Since: Aug 2007
a1161979 is offline
Correct, not to mention phase interaction issues that could result in cancelation of certain frequencies
I also do not see the point in 15 inch woofers with 18 inch woofers, trying to intergrate those would be a nightmare not to mention it would be un necessary, you should be looking to buil a LLT with 18 inch drivers, ir an IB depending on which side of the fence you stand!
I presume that the reason for 15 is as a bass driver to provide the punch between 40 and 150 hz? What are you mains, they should produce enough bass to a level where the LLT/IB would take over say at around 60hz!
15's and 18's different positions/boxes = NIGHTMARE aka dont even think about it... This is home theater not PRO sound... You do not need Kick bins in your home theater and if you do you need new mains
Similar Threads
Multiple HT Speakers Zene Home Audio Speakers 19 11-28-07 04:35 PM
Video switch boxes???? EchoMike Remotes | Cables | Accessories 2 07-06-07 02:08 PM
Wiring a new home: separate meter boxes John Simpson Remotes | Cables | Accessories 21 06-18-07 09:44 AM
Best Way to EQ for Multiple Locations Tukkis REW Forum 10 09-10-06 08:21 AM
Corrected for Multiple Locations Ayreonaut REW Forum 2 06-21-06 11:33 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
