IB and LLT in one - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
IB and LLT in one
Discuss IB and LLT in one in the DIY Speakers and Subwoofers forum; IB and LLT in one Hi guys, my new house is almost finished and now it's time to start planning/building the HT.The room is located ...
Old 08-27-07, 08:13 AM   #1 (Link)
g75
New Member
Alias: Gus
Loc: Finland
User: #11105
Since: Aug 2007
g75 is offline
IB and LLT in one
Hi guys, my new house is almost finished and now it's time to start planning/building the HT.The room is located in the basement and is about 6*10*2,7 (w*l*h) that is in meter. All walls, floor and ceiling is concrete.
The problem is i can't decide what to build a LLT or a IB, so i thought if it could be possible to build both of them in to the same box.
The plan is to build two large LLT's about 3m3 each with a plug for the port so it could be sealed off, this would then fulfill the requirement for a IB setup (10*Vas).
How does this sound to you? i mean is this sane or insane?
As drivers i am thinking of FI audios Q.18 Dual2
Old 08-27-07, 08:30 AM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: IB and LLT in one
A ported sub in a volume of 10*Vas is going to be too large and you're going to get a resurgence in the output at the tuning frequency. Are you planning 3m^3 for each driver? What tuning frequency?
Old 08-27-07, 07:29 PM   #3 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Ilkka's testing and Rodny's measurements and subjective impressions go a pretty long way to show that the LLT is superior in performance to any sealed enclosure - I don't have to end that sentence with "in my opinion" anymore either I'd set it up as a proper LLT from the get go.
Old 08-28-07, 02:16 AM   #4 (Link)
g75
New Member
Alias: Gus
Loc: Finland
User: #11105
Since: Aug 2007
g75 is offline
The problem is that i only have experience from 'normal' sealed and vented boxes. And in my own opinion a sealed sounds better than a vented, now i do not know the changes in quality with bigger volumes thats why i would like to experiment with both types.
At the moment i thinking of building the left sub as a 600l LLT, and the right one as a IB. Then by listening decide what to do?
Geoff that is true i did a small error in my simulation i had a 3m^3 box each and the tuning set to 8Hz and the plot was from 10Hz up, so i missed the bump at 8Hz. I guess the optimal for a LLT would be around 600l for the Q.18
Old 08-28-07, 04:25 PM   #5 (Link)
Alias: thxgoon
Loc: colorado
thxgoon's Avatar
User: #6924
thxgoon is offline
If you are going to build one of each for comparison's sake, make sure you position them in the same place in the room and recalibrate to remove all other variables. I for one would be interested in your findings.
Old 08-28-07, 05:10 PM   #6 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
g75
You have PM.
Look up to the right under Private Messages.
Regards
Chrisbee
Old 08-28-07, 08:12 PM   #7 (Link)
Alias: Steve
User: #263
Why do you want to tune it to 8hz?
Old 08-29-07, 01:41 AM   #8 (Link)
g75
New Member
Alias: Gus
Loc: Finland
User: #11105
Since: Aug 2007
g75 is offline
SteveCallas wrote: View Post
I don't, it was a error i did with the simulation with the 3m^3 box. If i go for the 600l the tuning should be somewhere around 14Hz.
At the moment it looks like i will go for the solution with one LLT and one IB, and then see what design will be the winning one. I guess it's a bit of extra work but
Old 08-29-07, 02:17 AM   #9 (Link)
Loc: Lower Alabama
It may be a little more work, but nothing wrong with trying both and seeing which will produce the better results. Rodny did it with his IB and SLLT, so can you. I do recommend that you use REW and take measurements of both so that we'll all have a another good comparison between IB and LLT. If you don't already own one... I also recommend the Galaxy CM-140 for the SPL meter to measure on down pretty low for better results... possibly a Volcraft SPL Meter in your area OR the Behringer ECM8000 with mic amp. Please keep us updated with your progress... pictures and notes...
Old 08-30-07, 02:48 AM   #10 (Link)
g75
New Member
Alias: Gus
Loc: Finland
User: #11105
Since: Aug 2007
g75 is offline
Sonnie wrote: View Post
It's been a time since i done any speaker building, so i am i bit outdated on the measurement tools, back in the days i used 'Speaker Workshop' with a Wallin jig and a DIY mic and amplifier.
I have moved two times since i last used the tools and now i can't find the mic or jig or anything, so i need some suggestions on what is recommended to do?
I am too lazy to build a new mic so i guess the Behringer ECM8000 is a good choice.
But what SW to use, or is the Speaker Workshop still a good choise?
And of course pictures and notes when there is anything worth to show.
Old 08-30-07, 04:17 PM   #11 (Link)
Loc: Lower Alabama
For speaker box design modeling... check this thread.
For measuring your response after the speaker is finished... it's a no-brainer, get REW, it's free and right here at the Shack. See the BFD | REW Forum where you can get all the help you ever dreamed of for REW.
As far as mics are concerned... yeah, the ECM8000 and a mic amp (with phantom power), along with an SPL meter is all you need. We provide you with correction values for that mic. Or if you can find the equivalent of the Galaxy CM-140, which I believe is made my Voltcraft in your area, it's a good mic and SPL meter combined that might be a little less expensive than the separate mic, amp and SPL meter.
Similar Threads
LLT Explained SteveCallas DIY Subwoofers - Sealed and Ported 145 05-30-08 12:33 AM
Mach5Audio MJ-18 LLT kano32 DIY Subwoofers - Sealed and Ported 36 02-10-08 05:07 PM
Sonosub LLT on its side? coctostan DIY Subwoofers - Sealed and Ported 14 09-13-07 09:00 AM
Which is ultimately better, IB or LLT? bonehead848 DIY Subwoofers 3 06-16-07 11:42 PM
An LLT with two AE IB15s? Chrisbee DIY Subwoofers - Sealed and Ported 57 05-22-07 05:19 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
