| DIY Subwoofers New Passive Radiators from Creative SoundDiscuss New Passive Radiators from Creative Sound in the DIY Speakers and Subwoofers forum; New Passive Radiators from Creative Sound It seems that CSS is offering now also passive radiators. http://www.creativesound.ca/
PR1816
Fs: 4.2hz
Qms: 67.62
Vas: 1840L
Mms: 1600g
| | #1 (Link) | |||
| New Passive Radiators from Creative Sound It seems that CSS is offering now also passive radiators. http://www.creativesound.ca/ PR1816 Fs: 4.2hz Qms: 67.62 Vas: 1840L Mms: 1600g Cms: .9mm/N Sd: 1200 sqcm Xmax: 3" P-P PR1821 Fs: 3.651 Qms: 67.72 Vas: 1840 L Mms: 2100g Cms: .9mm/N Sd: 1200 sqcm Xmax: 3" P-P ![]() ![]() Prices are for the PR1816 $129 and PR1821 $139. Anyone willing to try them out? ![]() | |||
| | #2 (Link) | |||
| Re: New 15” Driver - CSS SDX15 Hey anidabi - Yeah, these PRs look pretty cool. Glad there are some more options for those interested in PRs. Here is a sim for ya, using two of the PR1821s. ![]() | |||
| | #3 (Link) | ||||
| Re: New 15” Driver - CSS SDX15 Quote:
| | #4 (Link) | |||
| Re: New 15” Driver - CSS SDX15 Anyone know if those PRs use foam surrounds? I've emailed CSS this question, but nobody got back to me. They almost do look like foam, but it is hard to tell. Thanx! Dr V | |||
| | #6 (Link) | ||||
225 Liters (8 cubic feet) is a 24"x24"x24" box. Thats not large, especially for an EBS IMHO! | ||||
| | #7 (Link) | ||||
So I try to be objective about it. ![]() PRs will continue as they've always been...a product for a smaller group of DIYers. So many DIYers, including me, don't care much about the size of their sub so it makes sense. But for someone who is looking for a single 200liter EBS sub (it can be a tad smaller or larger than 200, of course) the sim I posted would be a good option. | ||||
| | #8 (Link) | |||
| Re: New 15” Driver - CSS SDX15 For the $260 you would be spending on two PRs, you'd be better off buying another driver and building a second subwoofe.....wait a minute, yeah. Also, the thought process that using PRs saves you enclosure volume is false. I'd venture to say you may even need to go larger, as two 18" PRs may displace more volume than a 6" diameter port - the volume of the enclosure won't change whether you use a port or PRs. If you model a 300 liter ported LLT, you'd still need to make a 300 liter PRed sub to match the performance. So now you're looking at spending a lot more money, not saving any space, and maybe eliminating a couple dbs compression in the subsonic range at extreme output levels. Just doesn't make sense to me ![]() P.S. - Oh, and PRs aren't exactly guaranteed to provide clean output. | |||
| | #9 (Link) | ||||
| | #10 (Link) | ||||
![]() The 2:1 doesn't just apply to a simple ratio of # of PR vs active driver. So lets see... Two 18" PRs with 38.1mm xmax. Yeah, thats 18.28800 liters of displacement from the PRs alone. One 15" driver with 30mm xmax, 4.8 liters of displacement. 3.81:1 ratio. Would it still have a touch of compression? Quite possibly at full tilt, sure. A lot less than the LLT? I'd guess so. Now with the 5400 and the TC PRs you have, you will practically have a 2:1 ratio. Thats another story. ![]() Last edited by WillyD; 09-09-07 at 07:30 PM. Reason: .... | ||||
| | #11 (Link) | |||||
The real benefit of PRs is for drivers that are more optimal in smaller enclosures, so one can tune them low without being restricted by the port length. This obviously doesn't apply to the SDX-15, or quite a few other drivers. Quote:
As I mentioned in the post before you, since I knew what you were thinking before you posted it, with the SDX it makes sense to go big and forget PRs. There may be one case somewhere where a guy wants a lot of performance in just 200 liters and a 15.5Hz tune...this may be a route he wants to go. Then again, one could just roll with two sealed SDX-15s in 200 liters, opposed firing and all that. ![]() | |||||
| | #12 (Link) | |||
| Re: New 15” Driver - CSS SDX15 Hmm. Thinking out loud. 6" diameter port volume = (6.5"/2)^2 x 3.14 x 27" = 895"^3 Dual 18" driver volume, assuming it's roughly half a sphere = 2 x (18"/2)^3 x 3.14 x (4/3) = ~6100"^2 Now sure, a driver or PR isn't a perfect half sphere, as the driver structure is more of a skeleton, so I'll be nice and only use 1/5 of that calculated volume, giving me ~1220"^2. What I am missing here? | |||
| | #13 (Link) | |||
| Re: New 15” Driver - CSS SDX15 The volume of 6100"^3 that you've calculated is for two 18" spheres. TC Sounds had the displacement of their PR at about 2.25 L each (0.08 cu ft). This probably makes sense since a typical large 15" driver is in the 5 L range and has that big motor on the back. The CSS PRs are essentially flat discs (no additional displacement) with a basket around it. The basket is the only think that contributes to the internal volume displacement. | |||
| | #16 (Link) | |||
| Re: New Passive Radiators from Creative Sound one more good feature of a passive radiator is that onw can lower the size of the box keep a low tuning and add some eq in the bottom (it won't require as much as a small closed box) | |||
| | #17 (Link) | ||||
Apologies for not getting back to you. The surrounds are foam. Bob Reimer Creative Sound Solutions 604-504-3954 | ||||
| | #19 (Link) | |||
| Re: New Passive Radiators from Creative Sound While I understand people around here, most from the US, all you guys thinking big. In Finland people think a bit differently. All big is not so important as to you guys here(speaking of subwoofers now). All I am saying is that not everyone is willing to go for the more bigger enclosure. In Finland people are just to about use to the idea of an 300l enclosure, which is quite big. Mostly people are happy with their chorus vertigos and such small subs.So when you come to think about it 225l isn't small, but its considerably smaller than 300l. Takes even more less space when you double the subs(also the price sky rocket ). Still 225l enclosure is way too big for most people around here and only a handful would thinking of taking that thing to their home. But the nature of the PRs and some of you have a good point there, it's not practical to build one big box with way more money, because LLT takes less floor space even thought it's bigger. I guess you understand what I'm saying, right? ![]() | |||
| | #20 (Link) | ||||
While I naturally meant that they would have the same Sd, I sort of forgot that the SDX was a 15", and those PRs were 18". An Unibox simulation shows very little compression for that combination. But IF we have a true 2:1 ratio, then some compression below the tuning frequency will be present. Probably very similar to what a 15" driver has with a 6" port. | ||||
| | #21 (Link) | |||
| Re: New Passive Radiators from Creative Sound Is there a sound quality difference between an LLT and a low tuned PR such as this? Comparing the SDX-15 in a 300l LLT tuned to 15hz and a SDX-15 with 2 18" PRs tuned to 15hz. Also, excuse my newbness, but what exactly is compression and what should it mean to those choosing subwoofers? Thanks to the experts. I hope I am not starting a war. ![]() | |||
| | #23 (Link) | ||||
