Judge my sub. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Judge my sub.
Discuss Judge my sub. in the DIY Speakers and Subwoofers forum; Judge my sub. It only takes up a bit over 4 cubic feet, so that's my plus for this small room of mine....
Old 09-12-07, 08:10 PM   #1 (Link)
Alias: Mike
Loc: Chattanooga, TN
User: #5740
Since: Jan 2007
mgboy is online now
Judge my sub.
Old 09-12-07, 08:28 PM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: Judge my sub.
The roll-off looks a little steep to me. Even in a closed 11' x 12' room I doubt you'll get enough room gain for that sub's FR to get close to flat.
Old 09-12-07, 10:29 PM   #3 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Re: Judge my sub.
I agree with the above post. My room roughly measures 13'x10'. I still find, that corner loading any non-eqed sealed sub may yield up to 4-5 db per octave gain, not enough to discontinue the use of EQ in this room if the goal is sub 20hz bass.
here is a nearfield measurement, taken to show the FR before the effects of room gain:
After room gain no EQ:
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
