HF vs HO - Two Camps - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss HF vs HO - Two Camps in the DIY Speakers and Subwoofers forum; HF vs HO - Two Camps Hello fellas, Another burning question: why is it that most subwoofer drivers tend to fall into one of two camps ...
Old 09-17-07, 09:59 PM   #1 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Hello fellas,
Another burning question: why is it that most subwoofer drivers tend to fall into one of two camps - high frequency or high output? I'm noticing that one large group has a frequency response that cuts off well below 1khz and another group that goes well beyond.
If the whole point of a subwoofer is to [typically] reproduce frequencies less than 150hz; in what case would one want to use a HF subwoofer?
Warmon -
Old 09-17-07, 10:19 PM   #2 (Link)
Shack City Slicker
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Re: HF vs HO - Two Camps
hmmm, a driver meant to cover a band of frequencies higher than 150hz is a midwoofer in my book. someone correct me if im wrong.
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 09-17-07, 10:28 PM   #3 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
I'm not sure I know of too many true subwoofers that would be effective "well-beyond" 1 kHz that aren't pro audio drivers. Do you have any examples?
Old 09-18-07, 03:28 PM   #4 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Geoff St. Germain wrote: View Post
Partsexpress lists several. I see them in other places as well. What y'all said jives up with what I'm reading elsewhere; that subwoofers with freq responses much above 5-600 Hz are just woofers masquerading as subs. They referred to them as pseudo-woofers; regular woofers capable of producing frequencies in the 20-30 Hz range.
http://www.partsexpress.com/pe/showd...number=290-367
http://www.partsexpress.com/pe/showd...number=297-608
http://www.partsexpress.com/pe/showd...number=296-432
So, what happens when one builds a sub using a driver that is not exactly a "true subwoofer" [and you still limit its upper freq to 150 Hz]? Let's say you have a woofer that has a freq response 30-3000, specs are otherwise good, it models okay and has been used successfully as a sub before. Think it's worth spending time on?
Warmon -
Old 09-18-07, 04:21 PM   #5 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Warmon wrote: View Post
Warmon -
Of those the Peerless is the only one I'd really classify as a subwoofer (it's frequency response is listed as 18.1 Hz to 500 Hz as well). It's a great driver too... the Xmax isn't as high as some other drivers, but it is supposed to offer great SQ from everything I've heard about it.
The Goldwood driver I would not classify as a subwoofer. With an Fs of 38 Hz and an Xmax of 3.5 mm I would definitely classify it as a woofer. The Aurum Cantus 10" claims to be a woofer anyway. It looks like a nice driver (and should be for the money).
There's no reason that a driver with response up to 3 kHz couldn't be used as a subwoofer, but IMO you could do better than a low frequency response of 30 Hz. If all you're looking for is a lower limit of 30 Hz then there's no reason not to use the driver. Of course it depends on the specific driver...
Old 09-19-07, 05:28 PM   #6 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
I guess what I should be asking is this: what characteristics define a "true subwoofer"? and do these pseudo subs sound inferior in any way. When it comes to Fs, lower is better? I have another question too, which I want to ask as a new thread.
Warmon -
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
