High Pass Filter / Low Pass Filter - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
DIY Subwoofers
Discuss High Pass Filter / Low Pass Filter in the DIY Speakers and Subwoofers forum; High Pass Filter / Low Pass Filter OK, I'll be the one to admit it because I know there must be dozens of us that have NO ...
Old 09-28-07, 06:05 PM   #1 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
OK, I'll be the one to admit it because I know there must be dozens of us that have NO idea...
What exactly do these things do and how are the implemented? Also what's with all the different types in WinISD?
Old 09-28-07, 06:16 PM   #2 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
Re: High Pass Filter / Low Pass Filter
Well, a high pass filter allows high frequencies through and filters out low frequencies. Low pass does the same with low frequencies. These filters can be of different "order" depending on how quickly the roll-off of the filtered frequencies is, higher order meaning a faster roll-off (steeper slope).
You can read some more here:
http://en.wikipedia.org/wiki/Low-pas...w-pass_filters
I couldn't find a nice, comprehensive reference so perhaps someone else will know where one is. I learned about them mostly in school, but as far as applications to acoustics I learned about then in Loudspeaker Design Cookbook by Vance Dickason.
Old 09-28-07, 07:39 PM   #3 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
Hey thanks Geoff. Thats a pretty good start. So now my question is; How and why would we apply them? Are they just to make sure a particular driver works in only a selected range of frequencies? Is this like passive equalization?
Old 09-28-07, 07:45 PM   #4 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Well, the reason to apply them (in reference to a subwoofer) is like you said, to have the driver work in only a certain band of frequencies. In the case of a subwoofer there would be a low-pass so that only frequencies below what the mains are playing are sent to the subwoofer and there could be a high-pass to prevent very low frequencies that have the potential to damage a subwoofer. For instance, for vented subwoofers frequencies below the tuning frequency result in very large excursion demands which could cause the driver to attempt to move further than it can mechanically resulting in what is called bottoming which can result in mechanical damage to the driver.
Old 09-29-07, 07:44 AM   #5 (Link)
Alias: matt
User: #7380
Since: Mar 2007
hddummy is offline
It should also be said that a low pass filter, when used in home theater applications, is usually implemented on the surround sound receiver. Most plate amps and dedicated subwoofer amps (ie buttkicker) have built in low pass filters. You should never have these activated or you should turn them to the highest settings so that the receiver can do it's job. If you were to use double filters, the roll off slope would be twice as steep as intended and you would have a dip in frequency responce between the mains and the subwoofer.
Old 09-29-07, 07:47 AM   #6 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
OK, so when i set my sub cutt-off to 80Hz or 120Hz, that in effect is my low-pass filter?
Old 09-29-07, 07:52 AM   #7 (Link)
Alias: matt
User: #7380
Since: Mar 2007
hddummy is offline
correct....let me preface my previous statement with the assumption that your sub is connected to your receiver with a subwoofer output. If you have your sub hooked up using right and left mains output from the receiver then you WILL need to use the built in low pass filtering on the sub amp or get a seperate filter. Which method of connection you use is determined by wether or not you receiver has a dedicated sub out and how you have the bass management settings on the receiver.
Old 09-29-07, 07:56 AM   #8 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
Yes, I'm coming off my sub outputs on my receiver. Thanks for your input Matt.
And HEY, you stole what should have been MY screen name!
Old 09-29-07, 08:07 AM   #9 (Link)
Alias: matt
User: #7380
Since: Mar 2007
hddummy is offline
My pleasure. Home theater is sort of a passion of mine. I would be happy to give advice on any related topic if I'm able.
You have just one other item to double check. Make sure your receiver is set to send LFE/bass material to just sub. You could also set it to go to the sub and mains if you have really good full range mains and depending on the balance of sound you want between the two.
Old 09-29-07, 08:12 AM   #10 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
Yeah, when I finish my LLT's I will. Right now I have the B&W 605's with built in powered subs for mains and I do have them set for sub/LFE pre-out. Once I get the SonoSubs finished the main's subs will be relegated to woofer duty and I'll send the deep stuff to the "real" subs.
Old 09-29-07, 08:15 AM   #11 (Link)
Alias: matt
User: #7380
Since: Mar 2007
hddummy is offline
Sounds like a pretty sweet setup!!
Old 09-29-07, 08:21 AM   #12 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
Well like yourself, its a passion for me. I've waited a long time and built & bought slowly (financial constraints) but I do have what for me is now a VERY satifying set-up. Thank god for audiogon!
Old 09-29-07, 11:01 PM   #13 (Link)
Alias: Warmon
Loc: Chester VA USA
Warmon's Avatar
User: #11066
Since: Aug 2007
Warmon is offline
Geoff St. Germain wrote: View Post
..For instance, for vented subwoofers frequencies below the tuning frequency result in very large excursion demands which could cause the driver to attempt to move further than it can mechanically resulting in what is called bottoming which can result in mechanical damage to the driver.
Geoff, are the frequencies below what the driver can produce still a factor? Take the graph below. It's from a driver that has a freq response of 18-400hz and a box tuned to 25. Is there any concern in the area < 18hz?
Warmon -
Old 09-30-07, 07:13 PM   #14 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
That could be a problem. It is going to depend on the Xmech of the driver as well as if you're going to be playing material through the driver in the sub 18 Hz range.
Old 09-30-07, 07:31 PM   #15 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
While i'm no expert, its been demonstrated and explained to me the starting with the losses at the output source (DVD player), you'll never get there. System power, cables, gain settings, all work to protect you.
Old 09-30-07, 07:37 PM   #16 (Link)
Alias: Geoff
User: #4919
Since: Dec 2006
Well, that entirely depends on many factors, including the power you're delivering to the driver, the tuning frequency and the driver's excursion capabilities. IME, I've only heard of natural protection from overexcursion as a result of very low tuning, like in an LLT where the enclosure is tuned in the mid teens. Tuning a driver to 25 Hz would not qualify.
Old 09-30-07, 07:41 PM   #17 (Link)
bnw
Alias: Steve
User: #10261
Since: Jul 2007
bnw is offline
Yeah, you're exactly right. I missed that (25Hz). I was remembering my LLT's that'll be tuned to 11Hz... if I ever get the time to finish them!
Similar Threads
BFD as a low-pass? niget2002 BFD Forum 2 08-02-07 10:56 AM
Pass Labs lcaillo Manufacturer and Vendor Reference Information 0 05-06-07 07:54 PM
Brand New NSD Pre and Post EQ First Pass azjimmy REW Forum 15 07-29-06 03:38 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145
