Understanding port length and flare radius... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Understanding port length and flare radius... in the DIY Speakers and Subwoofers forum; Understanding port length and flare radius... I must be having a major brain fart today since I feel like I missing something regarding port length with ...
Old 10-03-07, 04:58 PM   #1 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
I must be having a major brain fart today since I feel like I missing something regarding port length with and without flares. I've read the WinISD help and Collo's website already. If you are supposed to add 1/2 of the flare radius to the straight tube length to get the effective port length, then why does the port length in WinISD go down when you switch from no flares (two free ends) to flared (flanged) at both ends? This makes me think that the port value displayed in WinISD (and Collo's Boxnotes) only refers to the straight tube section and does not include the length of the flares. For example, in Boxnotes if you go from zero to 2 flares the tuning frequency goes down, which suggests that the effective port length has increased.
Can someone PLEASE explain and clarify this for me?
Also, flare radius has to play a role but it seems like all of the software applications and discussions I've seen treat all flares the same, regardless of actual radius.
Thanks.
Bradley
Old 10-03-07, 11:41 PM   #2 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Re: Understanding port length and flare radius...
The reason you're confused is because the free/flanged end business in WinISD doesn't refer to flared.
The default setting in WinISD is one flanged end, which would mean one end of the port is flush with a baffle. This is the norm. Has nothing to do with whether the port is flared or not.
Old 10-03-07, 11:55 PM   #3 (Link)
Alias: Bradley
Loc: Seattleland
User: #10624
Since: Aug 2007
Bradley is offline
Really?! Oh, for the love of... That actually makes a lot of sense now. I thought it was a language/translation thing, so I equated flanged with flared. But looking at the WinISD help file and the illustrations, I can see "flanged" means inserted into a baffle.
Thanks, Will.
Old 10-03-07, 11:59 PM   #4 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
No problemo.
Similar Threads
Maximum length HDMI 1.3 cable? MikeSp Remotes | Cables | Accessories 7 11-16-07 12:54 AM
Port location and diameter with flare aceinc DIY Speakers 3 10-03-07 10:44 PM
Max cable length with REW? angryht REW Forum 4 08-27-07 10:01 AM
Help with understanding my graphs bigDvette REW Forum 16 08-01-07 02:14 PM
Minimum radius on cables muse77 Remotes | Cables | Accessories 0 12-31-06 04:32 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
