| DIY Subwoofers Pearless XXLS 12 with passive radiatorDiscuss Pearless XXLS 12 with passive radiator in the DIY Speakers and Subwoofers forum; Pearless XXLS 12 with passive radiator Hi JP,
Your works done very impressive results. How much time for building and what is the total cost for ... |
Views: 6457 - Replies: 33
| | #26 | ||||
| Re: Pearless XXLS 12 with passive radiator Hi JP, Your works done very impressive results. How much time for building and what is the total cost for your two subwoofers? I would like to build the same thing but with an 500w RMS power amplifier enclosed into the box. I will look for this with variable crossover, phase control and all the in and outputs. Do you think that is a good idea? I will compare this alternative with the AV123 MFW-15 purchase ($600 each + $210 S/H to Canada). But the box size of these is much bigger than your Peerless. Tony L. | ||||
| | #27 | ||||
| Re: Pearless XXLS 12 with passive radiator JP, Great looking setup,the Yamaha monitors look great. The sub make great stands,I can take a guess and say sound quality,bass quality using the XXLS must be very high. Again nice setup. | ||||
| | #28 | |||||
| Re: Pearless XXLS 12 with passive radiator Quote:
For each sub, the cost is arround 450 $: Peerless XXLS 12 driver - 195 Peerless passive radiator - 105 Shipping - 50 Wood, glue, etc - 100 It took me a weekend for each sub. Yes you could use an amplifier plate, with some modifications in the design. But I prefer to use an external amp. The Behringer EP2500 is not expensive ($350) and could be use with the DSP1124 FeedBack Destroyer ($85) or with the DCX2496 Ultradrive ($210) to get a flat curve and good integration with main speakers. The Crown XTi 1000 ($499) is another nice option because it have a built in parametric EQ and delivers 1400 watts bridged on 4 ohms . Actualy I drive my 2 subs with a Rotel RB-1080 that produce arround 300watts at 4 ohms and it is just fine. In a near future, I plan to add 2 other subs. I think the feeling is better with multiple subs than with a big one. JP Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | |||||
| | #30 | ||||
| Re: Pearless XXLS 12 with passive radiator I got them from madisound.com Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | ||||
| | #31 | ||||
| Re: Pearless XXLS 12 with passive radiator Hello, I just want to let you know that I am working to add 2 other subwoofers in my setup. I just recieve the drivers last friday and the building process has started yesterday. I get another RB-1080 verry cheap (for that kind of amp!) on ebay last week. Will post some pictures soon. Two subwoofer is so nice, four will be awsome I think ! Just to be clear, I do not want more power, I have plenty bass with 2 subs, but I want to extend the sweet spot and have the room balanced. JP Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | ||||
| | #32 | ||||
| Re: Pearless XXLS 12 with passive radiator Are your new drivers the same sub as before, the Peerless XXLS 12? | ||||
| | #33 | ||||
| Re: Pearless XXLS 12 with passive radiator Yes they are, same drivers and passive radiators. Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | ||||
| | #34 | ||||
| Re: Pearless XXLS 12 with passive radiator JP, may I ask you to quote which levels of active equalisation/filters you use in order to flatten the bass response of the subs? How deep are they going? When I use WinISD to simulate your configuration (40l, 18Hz) the result looks somewhat disappointing with an F3 of above 40 Hz. How about the group delay? I need one/two rather small subs, and I am thinking of building these ones. Best Regards from Frankfurt/Germany Michael Last edited by Michbeck; 02-25-09 at 04:00 AM.. | ||||
