| DIY Subwoofers New IB sub questionDiscuss New IB sub question in the DIY Speakers and Subwoofers forum; New IB sub question well now that sister-in-laws new speaker project is well underway I started putzing around with the notion of building a ... |
| | #1 (Link) | |||
| New IB sub question well now that sister-in-laws new speaker project is well underway I started putzing around with the notion of building a new sub for me. In the wall between my living room (a big open l shaped space that also goes into my dining room ) and the garage I have mounted an old air conditioner about 5ft off the ground. The as* end of it hangs into my garage and so long as I put it back when i move I can't see moving as any big deal as far as the landlord is concerned. I also have central air so removing it will not be an issue six or seven months from now. Would 5ft off the ground be too high for an IB sub. In theory 8" double woofer speakers produce as much low end as a single twelve and do it better with less power, is less still more when it comes to IB subs?. To go along with my 1k watt plate amp I just managed to pick up a dozen 8" 1200 watt Pyle 2 ohm subs. Any thoughts on turning those and my garage into an IB Sub? Last edited by Tiny; 11-01-07 at 06:50 AM. | |||
| | #2 (Link) | |||
| Re: New IB sub question I think you can do it! There should be no problem having an IB sub 5' off the floor of the room. Many people have them in ceilings and walls. It sounds like you are limited in the exact placement, and that's OK. Since you will be taking the drivers and amp with you, you have nothing to lose. Good luck! -- Otto | |||
| | #4 (Link) | |||
| Re: New IB sub question The location and amps sound fine, but multiple small drivers are problematic. The first is that to move serious air, you'd have to have a lot of them. Having a lot of them means a complex manifold, which means you start introducing phase cancellation delays and distort the sound- which is the antithesis of IB. The second is that since IB are free air, you need high-excursion drivers, and it would be unlikely that you can find such a creature in 8" packaging. | |||
| | #5 (Link) | ||||
| Re: New IB sub question Quote:
They are currently wired to a 2ohm 1200 car amp, I figure I will split the current wiring setup into 2 series which should make it 4 ohm, though there are several ways I could get 4 ohms by mixing series and parallel setups. | ||||
| | #6 (Link) | ||||
Now assuming I do this the question is how big to make the manifold The hole coming into the living room is 15"x24" and I have 9ft floor to ceiling in the garage. What would be the best position to mount the subs? I am an IB noob, I have never heard a home installed one, much less built one before. | ||||
| | #7 (Link) | |||
| Re: New IB sub question Yeah, right back where I started. You have the drivers, amp and wood. Try it. Make the manifold as big as your opening. I'd probably use eight 8" drivers, mounting two of them on each "wall" of the manifold, all facing in. Yeah, this is an experiment. Good luck! -- Otto | |||
| | #8 (Link) | |||
| | Re: New IB sub question I know that the recommended manifold opening should equal the area of the woofers you are using. The average 8 inch sub has 32 square inches of surface area. 12 subs would be 384 sq. in. Your 15 x 24 opening is 360 sq. in. That should be close enough. Do you know what the model number is of the Pyle subs? | |||
| | #9 (Link) | |||
| Re: New IB sub question The best position? Create a spherical shell out of ply, with all the drivers facing inwards and attached to that opening. I would send you to the 'cult' site, but you'd be told not to bother with what you're doing. | |||
| | #10 (Link) | ||||
Incidentally the subs are not 1200 watt rated they are 800 watt and 4 ohms. Model number PLBW84. Please excuse me for a while, I am gonna go fire up Zeppelin 2 and enjoy the stereo while it is still in the car. | ||||
| | #12 (Link) | |||
| Re: New IB sub question Tiny, give it a shot. If you can manage to fit and support the manifold and it isn't in your way, I don't see why you shouldn't give it a go. You may end up better off just building a more conventional box or two, but hey, where's the fun in that? I say go for it, and make sure you take lots of pics! | |||
| | #13 (Link) | |||
| Re: New IB sub question l think you'll be wasting your time and money ( because the manifold would have to be replaced later by another to accomodate larger better drivers ) .......the first serious transiet will destroy these drivers, you'd be better off selling them/using them elsewhere rather than destroying them (unless it is for music only usage )........sorry, not trying to dampen your keeness on ib's but really you need to know the specs of the drivers and go from there otherwise you'll end up with a flawed result not true to what an optimal ib is supposed to sound like....try asking here....http://ibsubwoofers.proboards51.com/index.cgi cheers ken | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| CD Question | Bob_99 | Music and DVD Concerts | 4 | 08-29-07 01:48 PM |
| Question | Bob_99 | DIY Speakers | 12 | 05-18-07 10:11 AM |
