multiple constraints IB - which drivers? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss multiple constraints IB - which drivers? in the DIY Speakers and Subwoofers forum; multiple constraints IB - which drivers? Hi folks - I realize this is the wrong forum to ask about a pair of puny 12" drivers, but ...
Old 11-08-07, 07:53 AM   #1 (Link)
New Member
Alias: Lewis
Loc: Ithaca NY
User: #13213
Since: Nov 2007
lmc7lmc7 is offline
Hi folks - I realize this is the wrong forum to ask about a pair of puny 12" drivers, but there are several constraints to this setup:
Space and position: likely maximum size 12" drivers in a front corner (because of narrow overlap with venting space behind). Narrow width also seems to preclude using a manifold, so drivers may have to mount in wall (firing into room).
WAF: Two drivers near floor are out of direct sight line behind table. I might eventually add a second pair near ceiling (same vertical axis; can't put in other corner).
SPL: A non-fixed screen (for a rear projector) would vibrate with huge standing waves. I want good low-end extension but will seldom try to play really loud.
System details: The IB is to flesh out a 7.1 home theater installation. Will have six coaxials (Polk LC60s) mounted in ceiling and probably an non-ceiling center channel. [Haven't selected electronics yet so please point me to any threads on amp/driver pairing.]
Room details: 15W x 23L x 7 to 11' angled ceiling, fairly reflective surfaces. Few resonance modes owing to openings in side and front walls (but attendant imaging problems; will need acoustic treatment for partial correction). Large closet behind drivers, openable to other room if more volume needed.
Any suggestions for which drivers would work well for this setup? Thanks!
Old 11-08-07, 12:21 PM   #2 (Link)
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
WillyD is offline
Re: multiple constraints IB - which drivers?
So you want to do an IB with two 12" drivers?
That really isn't a good idea. But, you might be able to pull off an in-wall ported sub, if you know what I mean. Tell me more about the closet, as far as the dimensions of it or if you'd be willing to build an enclosure behind the drivers in the closet.
If you could do that, two Shiva-Xs in maybe a 450liter enclosure with a 30inch long 8" port would be pretty solid.
See Rodny's thread for an example: http://www.hometheatershack.com/foru...-makeover.html
Old 11-09-07, 10:33 AM   #3 (Link)
New Member
Alias: Lewis
Loc: Ithaca NY
User: #13213
Since: Nov 2007
lmc7lmc7 is offline
Hmmm, hadn't considered the alternative of an in-wall ported sub - good suggestion. I'll look into some of those threads.
Still hoping to get the benefits of IB design, though. After perusal of various FAQs, guides, and project designs, looks like I might be able to solve the width constraint with a mini faceted "line array", viz. illustration in: http://home.comcast.net/~infinitelyb...Bmanifold.html
Then I could put in four 12"s (still a little light for this size room), angled toward each other in a manifold not much taller than two in a front baffle. Haven't calculated size, but might be smaller than the 450 liter enclosure you estimate for a ported sub. I could fit either into one side of the closet, which is about 4' x 12' x 7.5'H (and openable into another room for additional venting).
Thanks for the feedback - this is fun but a bit more consuming than I expected!
Similar Threads
Multiple HT Speakers Zene Home Audio Speakers 19 11-28-07 04:35 PM
Multiple subwoofers - my first post tnargs Home Audio Subwoofers 5 10-22-07 09:45 AM
use of multiple sweeps in measurement terry j REW Forum 3 09-15-07 04:48 AM
Multiple boxes, different sizes WarrenP DIY Subwoofers 7 09-06-07 05:39 AM
Best Way to EQ for Multiple Locations Tukkis REW Forum 10 09-10-06 08:21 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
