finally got the subbies - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss finally got the subbies in the DIY Speakers and Subwoofers forum; finally got the subbies ok all, finally bit the bullet and found a bit of a deal at Autobarn, picked up two 15" inch ...
Old 11-14-07, 10:22 PM   #1 (Link)
Alias: hifijunkie
Loc: Gladstone Qld Australia
User: #6455
peteaimee is offline
ok all, finally bit the bullet and found a bit of a deal at Autobarn, picked up two 15" inch US Audio subs, both in their own carpeted enclosures. They sound pretty awsome, but they are as good with bassy music as they are with Pro logic sound tracks. After reading a lot on the forum, it appears you cant have both, i mean you either have good low frequency theatre bass or head banging music type bass. Because the two drivers have been fitted in induvidual boxes, (possibly too small as they are designed to fit in car boot, not a theatre room, i wonder what i could possibly gain in low end if i were to fit them in a single shared enclosure. The boxes they are in are sealed, so i would replicate this. The amp is feeding them 350 WRMS, shared. It appears to be giving them plenty. Any thoughts on this matter and is the sizing of the box all that important if they are sealed?
Old 11-15-07, 08:56 AM   #2 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
Re: finally got the subbies
Even sealed boxes require a proper sized enclosure. This is calculated using the T/S parameters of the drivers. WinISD Pro or Unibox are freeware programs that will do the heavy lifting for you, given the T/S parameters.
Not sure what you mean by the idea that you can't have low bass and musical bass at the same time. An accurate sub is simply reproducing the input signal.
-Brent
Similar Threads
Finally got HD tonyvdb High Definition | HD-DVD | Blu-ray 17 10-27-07 09:08 PM
Room finally treated... cruzmisl Home Audio Acoustics 25 09-23-07 03:50 PM
WooooHoooo Finally got my XA2 SteveB High Definition | HD-DVD | Blu-ray 2 07-26-07 07:32 PM
Finally got my IB done! canaris DIY Subwoofers - Infinite Baffle 10 02-21-07 05:51 PM
Finally some results..... Snookboy REW Forum 1 06-17-06 02:35 PM
Mach 5 Audio
