SMS-1 v2.1.3 firmware update - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss SMS-1 v2.1.3 firmware update in the DIY Speakers and Subwoofers forum; SMS-1 v2.1.3 firmware update Looks like something is coming here.... http://www.avsforum.com/avs-vb/showthread.php?t=942314 I guess we'll have to see how that pans out......
Old 11-20-07, 07:15 PM   #1 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Warpdrv is offline
Old 11-20-07, 09:39 PM   #2 (Link)
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
Warpdrv is offline
Re: SMS-1 v2.1.3 firmware update
Well Curt already sent me the software, but I don't have the USB to RS-232 cable yet... so I can't install the software...
Subwoofer Management System (SMS-1) Release 2.1.3
Release Notes
This document discusses the latest release of Velodyne’s Subwoofer Management System (SMS) firmware – release 2.1.3. This firmware addresses two issues related to the low frequency management of the SMS. First, it allows the subsonic filter to be set low enough that the only remaining rolloff in the low frequency is restricted only by the hardware, and secondly, corrects some distortion that previous versions of the firmware introduced to the audio spectrum.
Figure 1: SMS-1 Frequency Response
Please refer to Figure one. This graph shows actual output from the SMS-1 with the subsonic filter set to 5 Hz. The various curves shown reflect the subsonic filter as set to 6, 12, 18, 24, and 30 dB/octave -- the steeper the slope, the higher the subsonic slope setting. As you can see, the actual point at which the curves converge is 5 Hz, and at 5 Hz, the audio frequency is down about 5 dB. The typical 3 dB down point is about 8 Hz. This point is a limitation in the hardware and the low frequency response of the SMS cannot be extended any further without changing components in the hardware. In release 2.1.3 the subsonic filter can be set as low as 1 Hz., but any setting below 5 Hz. has negligible effect on the frequency response.
Note that the low-pass crossover in this example is set to the default of 80 Hz and 24 dB/octave.
Some users of the SMS measured the low frequency performance and discovered that the SMS was adding some distortion to the lowest frequencies. Most users did not notice this added distortion due to the low frequencies affected. The distortion was inadvertently introduced as the frequency processing software, which was based on Digital Drive subwoofers, was rewritten for the SMS. The 2.1.3 firmware corrects this problem.
There was some confusion that this distortion was also present in the DD series. This is not and was never true – the distortion was introduced in the SMS only, and has now been remedied.
If you have any questions on this information, please contact Velodyne customer service at techhelp@velodyne.com.
Old 11-20-07, 11:41 PM   #3 (Link)
Loc: Lower Alabama
This should make SMS owner much happier.
Old 11-21-07, 12:17 AM   #4 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
ha, we have the same problem warpdrv!
i wish the sms-1's had USB ports!
purchasing cable now ... it's 3 bucks over here
will post again with before and after pics
Old 11-21-07, 05:46 AM   #5 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
bought me the USB to Serial cable: make sure to use COM6 port on the settings.
if the display on the SMS-1 is not flashing, it's not updating
Axiom EP500 - should be good to 18hz
measurements taken 2-3" from the driver
v2.1 lowest possible subsonic filter
v2.1.3 lowest possible subsonic filter
curious why there's barely any difference, I remembered the driver might not be producing anything below tuning
measurements taken from the port
tiny amount of difference
im pretty sure the mic calibration and sms-1 EQ output is fine because when I use the SMS-1 to output its EQ to the receiver, the DD subwoofer is outputting and measured at 15hz
Old 11-21-07, 08:50 AM   #6 (Link)
Alias: brucek
User: #6
brucek is online now
Why not simply measure the SMS response with REW?
Measure a loopback cable with REW first to ensure a flat response and then insert the SMS in the loop and measure...........
Old 12-06-07, 11:58 PM   #7 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
let me add the link so it'd be easier for people here:
http://www.velodyne.com/support/soft...x?sid=454d756r
bruce, im thinking it was a sub from the start which is why no difference was noted.
haven't had time to go into the HT though to retest with another subwoofer.
Old 12-07-07, 02:13 AM   #8 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
AVTALK has tested the new software. i don't know the rules re: linking to another forum, so I will just paste the pics instead of the thread link
before:
after:
looks like it's flat to 10hz f3
Old 12-09-07, 08:44 AM   #9 (Link)
Alias: dpl12
Loc: sweden
User: #2139
Since: Aug 2006
håkan is offline
old firmware vs new firmware
first pic the new firmware 2.1.3
second pic firmware 2.1.2
Similar Threads
PS3 Firmware 1.81 update wbassett High Definition | HD DVD | Blu-ray 0 06-17-07 04:27 AM
Firmware update 1.5 available for Toshiba A2, XA2 & A20 bobgpsr High Definition | HD DVD | Blu-ray 10 04-24-07 07:57 AM
Firmware update 2.1 for the Toshiba HD-A1 & HD-XA1 bobgpsr High Definition | HD DVD | Blu-ray 6 04-11-07 12:47 AM
Firmware update 1.3 available for Toshiba HD-A2 & HD-XA2 bobgpsr High Definition | HD DVD | Blu-ray 8 04-06-07 02:12 PM
Firmware update 1.2 for Toshiba HD-A2 bobgpsr High Definition | HD DVD | Blu-ray 1 01-23-07 05:54 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
