So, what's with room gain? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
DIY Subwoofers
Discuss So, what's with room gain? in the DIY Speakers and Subwoofers forum; So, what's with room gain? It's pretty impressive what room gain can contribute to the low end response of a subwoofer. Is it all just ...
Old 11-25-07, 10:28 AM   #1 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
It's pretty impressive what room gain can contribute to the low end response of a subwoofer. Is it all just trial and error, or are there features of the room that can predict how the room will respond? For instance, do all of these things matter: floor plan geometry, room volume, wall treatments, types of furniture, upward-/downward-/forward-firing SW driver, SW placement, listening position, etc?
Mark
Pearland, TX (Houston)
Old 11-25-07, 11:18 AM   #2 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Re: So, what's with room gain?
All of those things matter. Placing a sub in the corner of a room boosts room gain in most instances. A rooms dimensions drastically affects the response and gain of a subwoofer. You can experiment with REW and different placement of your sub to really get a feel for it.
Old 11-26-07, 07:39 PM   #3 (Link)
Alias: Kevin
Loc: Port Angeles, WA
User: #13393
Since: Nov 2007
Kevin Haskins is offline
Its actually two separate things. There is the boundary gain that you get from the operation in non-4Pi space. In non-technical jargon that means that the output of the driver is focused into a smaller space. Less space = more apparent output.
The other type of gain is the pressure-vessel gain. Below a certain frequency the room no longer supports standing waves. When the wavelength is greater than the room dimensions, you get a uniform pressurization of the room. You get more gain as frequency decreases so its called "room gain". This is more apparent in small tightly sealed environments. Cars are a great example and the pressure vessel gain you get inside that environment is substantial. Its occurs lower in frequency and to a lesser extent inside a room. Typical living spaces are not tightly sealed acoustic chambers and their construction varies, giving different results depending on the physical properties of the floor, wall, ceiling, etc… Boundaries that are sturdy and stiff (concrete) give more re-enforcement than does stick-built or flexible building materials that will absorb some of the energy. Think of the Three Little Pigs. ;-)
Old 12-01-07, 04:22 PM   #4 (Link)
Alias: The Dave
Loc: Nor^Cal
Avus_M3's Avatar
User: #13004
Since: Nov 2007
Avus_M3 is offline
Is there any way we can adjust for room gain before actually building our subs so we could some what account for it?
- The Dave
Check out my QUAD 18" Fi IB Build Thread (DONE) King of the 400lb Gorilla
Old 12-01-07, 04:39 PM   #5 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
Avus_M3 wrote: View Post
You can't really adjust for it before hand, but with parametric equalizer like the BFD you can cut frequencies that are boosted too much easily so it doesn't end up being much of a problem.
Old 12-01-07, 04:42 PM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Anything other than a direct frequency response measurement will be pure speculation. Of course you have to have a subwoofer which anechoic frequency response you know in order to have a successful measurement. Usually post-EQ is a very good and efficient method for handling any excessive room gain down low.
Old 12-01-07, 10:21 PM   #7 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
Ilkka wrote: View Post
Room planning before the sub build?
Is it possible to boost low end room gain with specific room attributes (mentioned above) sufficiently to make a sealed enclosure have LFE response similar to a LLT/same driver without these room attributes. In other words, can I minimize cabinet size and maximize build simplicity in a sealed cabinet, while "engineering" great LFE through proper wall construction, room geometry, furnishings, and other attributes?
Mark
Old 12-01-07, 10:30 PM   #8 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
mrstampe wrote: View Post
Rather than attempting to design a room around a small sub there is a better option - you could use a smaller sealed cabinet for the sub but choose a driver with a large linear excursion capabilities and high power handling ability. By pairing it with a PEQ and a lot of power you could achieve this end. This is a more costly solution than an LLT solution but will work better than hoping for appropriate room gain which is a hit or miss situation.
Audiopulse makes some good drivers in this regard another option would be something like the JLW7 which would be a monster in this situation.
Old 12-02-07, 08:12 PM   #9 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
avaserfi wrote: View Post
You can do the same thing with an LLT, you'll just require less boost.
Old 12-02-07, 09:50 PM   #10 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
Geoff St. Germain wrote: View Post
I was under the impression LLT stands for large and low tuned I was replying to someone who wanted a smaller subwoofer .
Old 12-02-07, 10:40 PM   #11 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
In just a couple years, I'm planning a move to a larger house with more room for everything, including a pair of LLT subs. For now, the goal is to maximize my low end response in a smaller sealed enclosure. Maybe it's too much to ask of this design, and this is more of an academic exercise...
All I'm asking is, is it possible to boost the lower lows with room gain by properly maximizing room features (in addition to parametric eq)?
If not, I'll just bite the bullet and port that thing.
Mark
Old 12-02-07, 11:31 PM   #12 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
All I'm asking is, is it possible to boost the lower lows with room gain by properly maximizing room features (in addition to parametric eq)? f
I suggest you read my above quote as it answers this situation.
Rest assured with the proper driver you will be able to reach pretty low (mid to high teens) with the right driver and proper amounts of power, but this can get costly quick. LLTs are often chosen because they are far more cost effective than the option I suggested, but the problem is, of course, they are large.
Room gain can help, but is not reliable enough to count on IMHO.
Old 12-03-07, 02:43 AM   #13 (Link)
Alias: Lobo
Loc: Finland
User: #13553
Since: Nov 2007
Lobotomy^ is offline
hello everybody, my first post.
I did found THIS useful, when estimating room gains. Just set options to match your room and speaker. Then set listening position and speaker positions. Graph gives you estimate of room gain and standing waves effects at listening post for one speaker at the time.
Old 12-03-07, 08:13 AM   #14 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
What an AWESOME tool! This match my measurements and experience exactly! Thanks a lot! What an easy way to experiment with placement. Too bad it doesn't do subwoofers, but I used a center that goes pretty deep and moved around to where the sub needs to go and fudged it that way. Awesome stuff!
Old 12-03-07, 01:26 PM   #15 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
Very cool! It looks like there are quite a few manufactured speaker lines included, but no Paradigms. Has anyone else had experience using this calc? Anything comparable out there for subwoofers?
Mark
Old 12-04-07, 12:32 AM   #16 (Link)
Alias: Looney
Loc: Topeka, KS
User: #2678
Since: Sep 2006
looneybomber is offline
To get a significant change would require a remodelling of your room. Decreasing room volume and stiffening walls would do the trick...but would require more money and work than it would to install a few 18's in your ceiling. Plus, it would be a very dumb idea.
Old 12-04-07, 12:47 AM   #17 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
looneybomber wrote: View Post
Take it easy Kansas, we're just having a theoretical conversation here.
Mark
Similar Threads
Gain and other confusing topics. wbassett Projector Screens | DIY Screens 72 Today 10:02 PM
no gain on sub amp 420247 REW Forum 4 08-18-07 08:36 PM
Room and Cabin Gain jackfish Home Audio Acoustics 4 02-16-07 03:13 PM
Porting an IB... looking for room gain... Chrisbee DIY Subwoofers - Infinite Baffle 7 01-14-07 05:26 AM
Any way to limit gain to +/-10.0 dB? maxcooper REW Forum 17 12-16-06 04:08 PM
Mach 5 Audio
