Exterior volume knob? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
DIY Subwoofers
Discuss Exterior volume knob? in the DIY Speakers and Subwoofers forum; Exterior volume knob? How hard would it be to have a sort of "exterior" gain knob, like a wired volume remote? I mean, ...
Old 11-25-07, 04:22 PM   #1 (Link)
Alias: Mike
Loc: Chattanooga, TN
User: #5740
Since: Jan 2007
  mgboy is offline
How hard would it be to have a sort of "exterior" gain knob, like a wired volume remote? I mean, I know it's possible, but what do I need, or do they sell them somewhere?
I'd like to have it in between my sub amp and my computer, so with either RCA or 3.5mm jacks (F-M) on the ends.
Old 11-25-07, 04:55 PM   #2 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
Re: Exterior volume knob?
If I'm thinking correctly, a passive potentiometer wired in series would do what you want. Although I'm not sure how it would affect sound quality. Don't know if there are any off-the-shelf products that you can just buy to do what you want.
Old 11-26-07, 04:10 PM   #3 (Link)
Alias: Mike
User: #5740
Since: Jan 2007
  mgboy is offline
Hm, that could work I think but does anyone else have any ideas?
Old 11-26-07, 05:07 PM   #4 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
MCM sells a table top volume control.
http://www.mcmconnect.com/inwall/pro...99C79207A82FC4
Old 11-26-07, 10:59 PM   #5 (Link)
Alias: Mike
User: #5740
Since: Jan 2007
  mgboy is offline
I'd really like a DIY option, so I could have something sort of built into the hot spot, to change the volume. Like a 1 knob preamp, with rca/3.5mm jacks. I only know a bit about EE work, so I can't just think of what I'd need and stuff.
Old 11-26-07, 11:55 PM   #6 (Link)
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
  BoomieMCT is offline
+1 for a potentiometer. If you are concerned about keeping impedence the same get an L-pad.
Old 11-27-07, 07:27 PM   #7 (Link)
Alias: Mike
User: #5740
Since: Jan 2007
  mgboy is offline
So I have to put the Pot between my sub and and my amp with the speaker cable, set up as shown? As setup right now, I have my setup, set up (lol) like this
Computer > Receiver = Speakers > Sub amp = Sub.
I couldn't put the Pot between my computer and receiver using the red and white/black RCA cabling? Stupid question I suppose. >_>
Old 11-28-07, 02:13 AM   #8 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
  Josuah is offline
Not really following your > = chain, but you can stick it into your line-level outputs. So that's probably between the computer and receiver for you.
Old 11-28-07, 01:45 PM   #9 (Link)
Alias: brucek
User: #6
  brucek is online now
Mike, you need to provide more information so people can help you better.
Are you trying to only adjust the volume of your subwoofer while not adjusting the other speakers?
Is your subwoofer hooked to your main speakers using what's known as ' speaker level ' connections as opposed to ' line level ' connections?
Old 11-28-07, 06:44 PM   #10 (Link)
Alias: Mike
User: #5740
Since: Jan 2007
  mgboy is offline
Well I would like the Pot to control all volume being sent from my computer to my receiver. ( The sub amp is then hooked up to the audio out jack on my receiver ) so I could control system volume while not sitting right at my computer, as that's not the hot spot.
So a Pot through the RCA cables from my computer to my receiver (line level).
Sounds good to me. Thanks guys, I'll get right on that. Just have to find a cool knob.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
