question about sub box design - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss question about sub box design in the DIY Speakers and Subwoofers forum; question about sub box design hey I've been trolling here for a while and I believe I am posting in the right section .... just ...
Old 12-09-07, 06:58 PM   #1 (Link)
New Member
Alias: hobo
Loc: columbus ohio
User: #6583
h0bo4life is offline
just had a couple questions. I am building a subwoofer for home theater in a sealed box using the dayton rss315ht-4(300 watts rms) driver and the 240 watt dayton amp. first off, I know that the amp is underpowered for the woofer. What kinds of problems might that cause??? would I get clipping??? should this matching of amp and loudspeaker be fine as long as it isn't at high volumes?
my second question and the real reason for my post is that I am wondering about box shapes for subwoofers. Most of them seem to be cubes rather than golden ratio. Why is that? Should I make mine a cube or shoot for varied dimensions to fight standing waves?
It would be most convenient for me to do a taller sub with a smaller footprint and if there is no advantage to making a box that is like 16x16x16 I would rather do 14x18x20 or something. THanks for any input guys!
Old 12-09-07, 07:03 PM   #2 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Re: question about sub box design
as long as you meet the enclosure volume requirements, and fit the driver and amp in the process ... there's no set RULE to go for a cube size. that's the benefit of DIY, build your enclosure with exactly the size you want.
but i must warn you, the standing waves are mostly resolved by non-parallel walls. a cube or rectangular box both have parallel walls.
Old 12-10-07, 10:10 AM   #3 (Link)
New Member
Alias: hobo
Loc: columbus ohio
User: #6583
that sort of answers my question about box shape...i guess I am still wondering if their is some advantage to going with a cube since that is what everyone else seems to do.
as far as my amp and subwoofer matching should i be concerned that it is underpowered or is this an ok set up???
Old 12-10-07, 10:15 AM   #4 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
if I had to guess ... it'd be because:
aesthetics - balanced look
low center of gravity - the height is about the same as the footprint, less chance of tipping over
i don't know about the amp power ... the experts here will get to that
Old 12-10-07, 10:05 PM   #5 (Link)
Alias: mrstampe
Loc: Pearland, TX
mrstampe's Avatar
User: #13368
Since: Nov 2007
mrstampe is offline
As I've begun to pick up the subwoofer building craft, these are a few of the points I have learned...
1) Sealed subwoofer enclosures generally allow for simpler construction, greater driver damping, "tighter" bass response, a higher tuned frequency, poorer power efficiency. This design seems to be favored in music applications and when space is limited for placement of your sub.
2) Ported enclosures trade driver damping and build simplicity for significantly lower tuning, higher efficiency. The majority of Shacksters favor this design, as it better suited to the Home Theater demands of low frequency response.
3) SW enclosure choice is a personal one that depends on your listening preference, music vs. HT application, driver characteristics, and space availability in your room.
4) Enclosure geometry is pretty diverse as you look over all the designs posted on the HTS. There are lots of cubes, rectangles, tubes, and even one that looks like the Smurfit-Stone building in Chicago!
Since your goal is to use this 12" driver in a home theater setting with a somewhat underpowered amp, you'd get the most out of your RSS315 in a ported enclosure. If you're looking for a smaller footprint to allow for a larger volume, take a look at the many sonosub tube designs all over HTS.
Mark
Pearland, TX (Houston)
Old 12-10-07, 10:13 PM   #6 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
Hobo, how did you arrive at that "300 watts" limit for power handling?
Assuming your 16x16x16 is external dimensions using .75" material, that's a 1.8 ft^3 enclosure. I'm also assuming the RS315-HF...based on that enclosure size. You're just at rated Xmax at 20hz with 240 watts, without taking the rumble filter into account. Naturally, excursion limited power handling rises with frequency. That 240 watts translates to 97dB@20hz, 103dB@30hz, 106dB@40hz, all 1m groundplane...boundary reinforcement ideally adds 6dB per boundary (wall) and you could/should also get some room gain below the 1/2 wavelength of your longest room dimension.
That's a complicated way of saying you're not really underpowered, IMO. If you need more SPL, you'll need a second sub or a different driver/alignment, not a more powerful amp. Doubling the power into a given driver, assuming it has available excursion to handle the increase, yields a barely noticeable +3dB gain. In your case, you've got a little excursion left with 240 watts, but no where near enough to handle double the power.
If you do try to overdrive the SA240, it has soft clipping, which should simply compress the drive signal if you clip the output. Do this long enough and it will simply shut down when the thermal protection is tripped.
-Brent
Old 12-11-07, 06:42 PM   #7 (Link)
New Member
Alias: hobo
Loc: columbus ohio
User: #6583
thanks for your responses guys!
brent... thanks for putting stuff in plain english for me. The subwoofer just says that it's 300 watts RMS and yes that is the enclosure size.
Mrstampe... most of what you said is stuff I've picked up reading here and there.... however I haven't read much about tube designs. I like that solution cause we are really short on floor space in our living room... Now i just gotta talk the wife into the idea!
at this point I would say I am ready to go ahead and build thanks again for everybody's help.
Old 03-23-08, 08:44 PM   #8 (Link)
Alias: Bryan
Loc: Victor, NY
User: #18432
Since: Mar 2008
cassb is offline
Hobo, did you finish building your sub with the Dayton 12" driver and Dayton 240W amp? I'm interested in how it sounds -- I'm thinking of the same hardware, just using their 10" model driver instead.
Thanks!
Bryan
Similar Threads
Moderno in-wall 10" - To Box or Not To Box billmd Home Audio Speakers 1 12-02-07 09:10 PM
Sub Box Design Danny DIY Subwoofers 15 06-14-07 10:54 PM
My Box Design Danny DIY Subwoofers 14 02-21-07 08:11 AM
HT speaker design question BoomieMCT DIY Speakers 4 01-24-07 12:00 PM
Guide to Sub box Design Danny DIY Subwoofers 12 05-13-06 10:48 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
