Problems tuning Passive Radiators with Built Box - Home Theater Systems - Electronics and Forum - HomeTheaterShack
DIY Subwoofers
Discuss Problems tuning Passive Radiators with Built Box in the DIY Speakers and Subwoofers forum; Problems tuning Passive Radiators with Built Box I'm having problems tuning my two 12" XLS Peerless passive radiators. I have one 12" XLS driver in a small ...
Old 12-23-07, 01:56 AM   #1 (Link)
Alias: Sam
Loc: Brisbane, Qld, Australia
Blueeyedfrog's Avatar
User: #14375
Since: Dec 2007
Blueeyedfrog is offline
I have one 12" XLS driver in a small 50.78 ltr box (1.79 ft^3) with a 240 (8ohm) amp.
My question is, how critical is it to have the PRs tuned to exactly the design fb (in my case 20hz) once the box has been built? Specifically, is it ok to be within the ballpark of the design fb +/- 0.5 - 1 hz (i.e. within 19-21hz range)? If not, what are the possible drawbacks if my tuned fb is not exactly right?
I built my sub using a DIY design that recommends adding 365gms of mass to each the PRs. However, I have also found a spreadsheet for another forum which assists in calculating the approximate starting amounts - this spreadsheet recommends 338grms for each radiator but also to start at about 10% less than the recommended amount and work up to the suggested mass.
To measure my sub's Fb I am using a RS meter and Room EQ wizard. I have the meter less than a 1/2 inch away from the cone and set the measurement level for 76db (cal corrections file for meter is loaded into RoomEQ). Sub is 3 metres away from any walls.
I have a definite low point/drop near my target Fb of 20hz, However, it is in the form of a 'u' shape rather than a 'v' (see attached photos). Is this a problem?
With the radiators massed at 307gms each, the lowest db is at 20.5hz (top graph). At 335gms two low points appear in a flat horizontal line from 20.14 - 19.78 (middle graph). At 350gms the lowest point is at 19.8 (bottom graph). I have also noticed that the slope of the bottom of the 'u' shape changes as I add mass. At 307gms it slopes down from left to right. At 335gms the slope is flat. At 350gms the slope drops from right to left. Is this normal? Could it be that I have not got the PRs weighted exactly the same (I don't have electronic scales - just cheapo cooking ones)?
Which mass should I use? A present I have decided to use the 335gms which give the 'flat' response across the Fb of 20hz. Is that correct or should I use one of the others?
Suggestions please, I have been changing weights for days!
Cheers
Blue
Old 12-24-07, 07:54 AM   #2 (Link)
Gold Supporter
Alias: Jean-Pierre
Loc: Beaumont, Quebec, CANADA
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
Re: Problems tuning Passive Radiators with Built Box
Hello, I think first that your spl meter should be at the listening position, not so close to the driver. Am I wrong ?
Old 12-24-07, 09:59 AM   #3 (Link)
Alias: Geoff
Loc: Winnipeg, Canada
Geoff St. Germain's Avatar
User: #4919
Since: Dec 2006
Geoff St. Germain is offline
To measure the tuning frequency you want the mic as close to the driver as possible so that you only measure the output of the driver and not of the PRs in this case.
Blue, part of the problem you are running into with what you are doing is related to the resolution limits of the measurements. The minimas look like a "U" because the resolution isn't high enough to resolve the bottom of the minima so you get a smoothed over look to the measurement. For all three of your measurements the actual minima looks like it is probably near halfway between the two points forming the bottom of the "U". The two bottom graphs show an almost identical tuning frequency, likely within .1 Hz, which makes sense since there is only a 15g difference in the mass added to the PRs. I'd go with either of the bottom ones (335g or 350g) and be happy. It is unlikely you'll be able to hear a difference between the two.
Got any pictures of your enclosure? I've been toying with the idea of picking up an XLS and a couple of the PRs and doing a small subwoofer for the bedroom.
Old 12-25-07, 07:33 PM   #4 (Link)
Alias: Sam
User: #14375
Since: Dec 2007
Many thanks Geoff. I feel much more at ease now! Please find attached photos. The design can be found here: http://www.geocities.com/adrian_mack/
I'm really pleased with the finish however, I did rush things a bit - the finish is contact vinyl and I didn't wait long enough for the filler to dry over the screws before covering the box - so I ended up with a few raises and dips. However, I found two layers of contact film made for a better finish, hiding some of the imperfections. Still, when it's sat in the corner it looks great from the listening position (keep having to remind myself to watch the move sometimes...).
I changed the design slightly and put an internal vertical brace in because the top was only 25mm think and I was worried about flexing. I also changed the dimensions slightly so I could use some offcuts from the timber suppliers rather than buy an entire sheet - saved about $100 Aust. Only problem was that I couldn't fit the radio control unit on the front however, I prefer it in the back because the sub looks cleaner from the front. I also don't know if I changed from the 'golden dimensions' (if the design even used those dimensions).
It's an excellent small sized box with punch.
Cheers
HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector
Old 12-25-07, 07:37 PM   #5 (Link)
Alias: Sam
User: #14375
Since: Dec 2007
Photos...
Old 12-25-07, 07:39 PM   #6 (Link)
Alias: Sam
User: #14375
Since: Dec 2007
More photos...
Similar Threads
Tuning a port relative to fill dreamofinsanity69 DIY Subwoofers - Sealed and Ported 3 12-08-07 06:47 PM
Moderno in-wall 10" - To Box or Not To Box billmd Home Audio Speakers 1 12-02-07 09:10 PM
New Passive Radiators from Creative Sound anidabi DIY Subwoofers 33 12-02-07 03:08 AM
Problems with 25hz tuning? StephenP DIY Subwoofers 6 05-18-07 01:58 PM
what tuning? masterxela SoundSplinter 2 05-11-07 06:25 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
